Question about Garmin Edge 305 GPS Receiver
Garmin 305 edge
I bought a new 305 edge and installed the software - the first download and upload worked perfectly but after that the garmin wont connect to my coputer with an error that says - 305 cant connect - make sure Garmin is connected to computer- when I look at the gstart in the bottom right it says Garmin connected.
Please help
  • 385 Answers
Re-register it, Re-update it at Garmin
Should be good
Hope this helps
Regards.
Posted on Apr 17, 2009
Used my garmin edge 305 today on the ride, it worked fine, powered off after the ride. Got home turned on to review my stats and then powered off and went to upload and wouldn't upload, so tried to turn it...
Edge 205 or 305 often crash, then impossible to power on again.
Here is the way to reset the Garmin edge :
Soft reset : hold mode and lap/reset buttons for 10 seconds
Hard reset : device should be powered down, hold start and mode buttons for 3 seconds then pulse press the lap/reset button.
After soft reset, you need to hold start button for up to 10 secs before it starts.
After hard reset, you will loose all your data, including profiles.
Jan 30, 2011 | Garmin Edge 305 GPS Receiver
My garmin edge 305 will not upload my rides, the training center software stalls at 2% the declares an error.
I have similar problems that have only just started.
Together with Training Centre crashes after uploads forcing rollbacks by deleting a history tree file and using a backup...
Tres frustrating...
Am thinking seriously of ditching it...
Nov 29, 2010 | Garmin Edge 305 GPS Receiver
My edge 305 doesn't always pick up sallelite. I
Hi If you have the time and patience then log onto garmin and download the webupdater then join the garmin site and plug in your 305 garmin dashboard will update for you and possibly fix it, other than that you will have to send it to garmin, if its still in warranty, 75 dollars if its out of warranty nty
Nov 18, 2009 | Garmin Edge 305 GPS Receiver
Garmin 305 charges but wont upload to PC or MAC - have changed the cable but still not upload last training sessions
The Garmin fitness units are unreliable. I don't know the answer but the first place I'd look is in the Motion Based Forum.
Nov 04, 2009 | Garmin Forerunner 305 GPS Receiver
Uploading info from the Edge 305
Apperently my unit had some old data prior to my purchase, (amzon selling returned equipment I imagine)
Anyway, I did a hard reset, (turn the power on while holding the mode button down) Erases all history. I then paired up my accessories again, tested it in 1 second mode and smart recording mode. The hard reset seemed to work for me. My 305 edge is now downloading map and graph data to my PC. Hope this helps anyone with the same problem.
May 08, 2009 | Garmin Edge 305HR GPS Receiver
Garmin 305 Edge and GSC 10 not receiving one another
Solution copied from Garmin
Pairing the Edge 305 and sensors
Once you have installed the Garmin Edge 305 and the cadence sensor they need to be paired. As they communicate wirelessly with each other the Edge needs to connect to each sensor before it can receive input from it.
The initial pairing needs to be done away from other wireless systems this allows the Edge to pick up the sensors it is supposed to be monitoring. This is a little like black magic, but it seems to work quite easily.
The cadence sensor has a small press contact which puts the sensor into pairing mode. The HRM just seemed to connect by itself.
Subsequent pairing is much faster as the Edge 305 seems to remember which sensors it is paired with. If you have problems or need to change one of the sensors then you can use a setup feature to either turn the sensor off or to re-pair it.
Feb 22, 2009 | Garmin Edge 305HR GPS Receiver
Garmin Edge 305 HRM problem
Try to pair his unit with your strap and it won't work, you have a bad strapl
Feb 16, 2009 | Garmin Edge 305 GPS Receiver
Garmin ege 305 will not connect with computer
You have to (re)install garmin gstart software on the computer. The driver is installed together with the application.
If it appears as new hardware this is because the driver is not installed.
Check also if gstart is started before connecting device.
Jan 01, 2009 | Garmin Edge 305 GPS Receiver
False elevation reading with garmin edge 305
perform a software download from Garmin.com by logging onto the site and downloading the webupdater
Aug 23, 2008 | Garmin Edge 305 GPS Receiver
Date not changing
After my ride I needed to stop the timer and reset the device. Then connect to the computer and download the history. It appears that that information I was downloading was from a previous ride.
Jun 26, 2008 | Garmin Edge 305 GPS Receiver
Garmin Edge 305 GPS Receiver Logo
187 people viewed this question
Top Garmin GPS Experts
SHARCNET-USA
SHARCNET-USA
TO Lady
Are you a Garmin GPS Expert? Answer questions, earn points and help others
