Scanning does not start
KM1650 Kyocera copier
I want to scan a document to my computer but it does not want to
  • bnj766 Sep 04, 2008
    Scanning sends to only a few of the pre-programmed addresses in our network. The ones that do not work are ones that have worked in the past. What could have changed to make these addresses non-functioning? Do I really have to uninstall and re-install? We can't be shut down for that long!
    Sniper:
  • 66 Answers
Hi
if you are running DHCP configuration on your networked pc's you will have to use the host names of your computers as the destination addresses.
The reason for this is that the ip addresses  can change periodically.
another solution is to make all ip addresses on your computers static so the destination address for your scans will not change
please take the time to rate this fix
Posted on Apr 23, 2009
Document scan to SMB for w8.1 pro for
That model does not support scan to smb
the only scanning it support is
TWAIN (scan-to-Pc and Scan-to-Email only via Software QLINK
Aug 19, 2014 | Kyocera Mita Olivetti D-Copia 163Mf...
KM-5050 Scanning Issue
the 5050 uses a file scan utility which is basically an ftp utility. you need to download the scanner file utility on each workstation. HERE is the link for the utility and instructions file.
Jul 18, 2013 | Kyocera Office Equipment & Supplies
How to scan in kyocera 1820
check the connection on the computer and try it agian.
Apr 02, 2013 | Kyocera Copystar CS-1820 Black and White...
C0410 km1650 kyocera
A C-0410 error is a communications error between the document feeder and the machine. The manufacture did an update to the circuit board of the document feeder that sometimes corrects the error.
When I have had this problem it has been ether a bad harness or loose connection between the document feeder and copier or a bad circuit board on the document feeder.
Jun 09, 2011 | Kyocera Copier
I have a Kyocera KM-2560 printer/scanner/copier that is accessible via LAN for a number of computers. When the vendor intially installed the system he assigned "scanning" to only one computer...
It sounds like the vendor set up only one scan destination. That destination is accessed by other computers on the network. You would have to have to create a different scan destination for each computer if you want to be able to scan documents while that computer is off. This is a link to instructions for doing that.
http://usa.kyoceramita.com/americas/jsp/Kyocera/resource_details.jsp?pid=18154&rid=19484
Feb 28, 2011 | Office Equipment & Supplies
How to resolve error code c3200 on km1650,fs1118 copiers
c3200 is related to the optics. in km1650 the scanner may be derailed. check and realign the wire. clean the lamp and the entire optics.
Aug 11, 2010 | Kyocera Mita KM-1650 All-In-One Printer
Can't send fax from Kyocera KM1650. It won't send a fax to a 202 area code, you get the start beep and then it's a steady tone that does not sound like a good fax noise. The fax will send if I use another...
Try turning off the ECM mode when sending to that number. The instructions are in the Fax user manual. If you dont have it go to www.gfbm.net and yo can get a link to Kyocera manuals.
Jan 20, 2010 | Kyocera Mita KM-1650 All-In-One Printer
I have a Kyocera CS 1820 copier, scanner, fax machine and I can't figure out how to geet it to scan to pc. I have installed the drivers from the kyocera site and still no luck......
Make sure that you downloaded the correct drivers....Etc... (x64) vs (x86) also make sure you have the proper script # driver ... Etc... #5.1 vs #6. You will want to completely uninstall all the old drivers, shut down your computer --- do not just reboot, reinstall all the new drivers,and after your computer is done rebooting – shut it down and restart. Also make sure that you and the designated file set up on the computer, it needs to know where to scan the document and send it to.
Dec 23, 2008 | Kyocera Copystar CS-1820 Black and White...
Kyocera FS1118 mfp
FS1118 scanning issue - this may sound like a long process but its easy...
Just create a folder called scans in your c:/ drive right click and share the folder
Go to the kyocera command centre (type the ip address of the machine into your browser, taking note your machine must be networked)
Once in kyocera command centre
Click on basic
on the left menu select address book, contacts
create a new contact and under SMB
only insert your computers IP address in the host field
and insert the file name scans in the path field.
Click submit...
Once complete go to your machine
insert a page to scan, select the send button
press the address key
select the contact you created
select ip address press enter
now press 2 on the keypad
press enter
press 2 again
enter again
and then press the green start button once complete..
The scanned document will appear in the scans folder
Aug 01, 2008 | Office Equipment & Supplies
178 people viewed this question
jasbo
jasbo
