Question about HP Office Equipment & Supplies
HP laserjet 3050 comm Error 223 - HP Office Equipment & Supplies
I succeeded by:
a) changing the Error Correction Mode (ECM) to OFF
b) disabeling V.34 option
steps for
a) Fax setup -- All faxes -- Error correction -- OFF
b) Fax setup -- All faxes -- V.34 -- disable
Posted on Oct 27, 2008
WHEN I SENDING A FAX IT SAS COMM ERROR 363
It's a communication error between the printer and the sender or the receiver.
Unplug the fax phone cord from the wall. Plug in a telephone into that outlet and see if you can make a phone call.
Plug your fax back in, and try it again.
Jan 25, 2011 | HP LaserJet 3050 All-In-One Printer
Comm error 232
This is the common cause and solution: A communication failure has occurred between the two machines. On the other hand, the user at the remote machine may have pressed the Stop button. Alternatively: the power at the remote machine has been interrupted, or deliberately turned off causing the fax session to be interrupted.
Solution:
1. Re-attempt the fax reception at a different time when telephone line conditions have improved.
2. If the error persists, and error correction is in use for the fax session, disable ECM . (See Error 222)
Good luck
Jun 12, 2010 | HP LaserJet 3050 All-In-One Printer
I keep getting comm error 242 when people are faxing to me
The "sender's" fax machine is attempting to RECEIVE a fax. This happens because they don't have the document fully inserted into the scanner before dialing. (According to HP's error code listing for "comm error 242" - http://h10025.www1.hp.com/ewfrf/wc/document?cc=us&lc=en&docname=buu02549) This is not a problem of a bad connection. Bad line condition codes are 223, 224 and most of the codes starting with 23.
Apr 28, 2010 | HP LaserJet 3050 Printer
I receive 1 page of an incoming fax but then the next page is a fax call report saying comm error 232
Try this...
steps for
Mar 31, 2010 | HP LaserJet 3050 All-In-One Printer
I cant send faxes over voip with the hp laserjet 3050 fax machine....really at a loss of what to do keep getting comm errors.....receiving faxes just fine
I found a blog on the Ooma site that said this can be fixed by prefixing your fax send number with 99. There were several comments from people who tired this fix and it worked for them!
Nov 23, 2009 | HP LaserJet 3050 All-In-One Printer
Fax comm error 232 problem
Hello sir ; Why don't try to replace a phone cable or check the wall jack.
Aug 28, 2009 | HP LaserJet 3050 All-In-One Printer
HP 3050 Engine Comm error
I have a HP 3050 three in one and I keep getting a engine comm error
Aug 02, 2009 | HP LaserJet 3050 All-In-One Printer
Fax error 344 - HP officejet 4255 all-in-one
fax error is remote machine not responding to your fax.the other fax has stopped communicating.this is a comms error.
Jun 29, 2009 | HP LaserJet 3050 All-In-One Printer
Hp laserjet 3050 fax report
The error 244 results from a fax machine communicating and trying to 'Poll" your fax. (receive information you have loaded into the fax memory for all to receive) The error comes in when your fax has no information or is not set up to be polled.
Look in your menu for the "ECM" setting on the printer menu. If this error is getting persistent change the ECM setting to the opposite of what it is set now. More than likely your fax will say ECM=On, change to off.
If you have problems locating where the ECM section is, print a "settings report" or "printer menu".
Hope that helps you.
Sep 02, 2008 | HP LaserJet 3050 All-In-One Printer
1,119 people viewed this question
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
