Question about Hotpoint Aquarius WF000 Front Load Washer
How do i fix mo hotpoint wf740 when it says test
  • mohican Aug 22, 2008
    how do i remove test from the display
  • scott-hump Apr 25, 2009
    My Hotpoit WF740 displays the word test & runs a dry cycle, how do i stop this?
    An expert whose answer gotĀ voted for 100 times.
  • 100 Answers
Turn the machine on while pressing the on and start buttons at the same time until dOFF appears
Posted on Jan 28, 2009
This really worked m/c off hold on & start buttons down then turn back on at mains and hold until dOFF appears should now be back the normal
Posted on Oct 23, 2012
Wf740 hotpoint aquarius won't stop doing test
hold the power and start buttons
and see what happens
May 27, 2014 | Washing Machines
Where is the filter on my wf740 hotpoint
Maybe something jambed in pump, lint , coin or similar. Just fixed my LG machine coin in pump..Unsure of layout on Hotpoint but simply follow drain hose to pump.
Apr 17, 2013 | Washing Machines
Hotpoint wf740 aquarius 1400 v noisy banging during spin = dust
It could be a broken drum restraint spring, or a worn or broken. or loose shock absorber.
To check the springs, remove the top cover, and you will see the springs.
Another possibility is the concrete weight could be broken or loose.
You need to remove the lower rear panel of washer to check the shockers and concrete weight.
Please rate my solution.
Jan 31, 2010 | Hotpoint Aquarius WF000 Front Load Washer
How do you change brushes on a hotpoint aquarius washing machine
I have a Hotpoint Aquarius WF740. This does have brushes. Tilt the washing machine backwards & look underneath. The brushes can be seen on the motor housing, they are secured by two screws each.
Nov 11, 2009 | Hotpoint Aquarius WF000 Front Load Washer
My WF740 is also flashing F-05...unable to unlock door!!
The error F-05 indicates that no drain or pressure switch
jammed on full.
Sep 02, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint Aquarius Wf740 F-08 just before rinse and spin.
Hi my Hotpoint WF740 keeps flashin H20. Does anyone know why please?
Jan 15, 2009 | Hotpoint Aquarius WF000 Front Load Washer
Hotpoint wf740 washing machine
An F-05 error message means that the pressure switch is jammed on empty or a problem with pump.
The fault is associated with drain out (pump blocked or restricted in some way).
Small panel at rear of machine reveals the pump, pull of the two pipes (Plastic clips hard to get off, slide them sideways), remove wire and unclip pump from base of machine by lifting locking tab and sliding to the left, pump can then easily be cleaned.
Oct 01, 2008 | Hotpoint Aquarius WF000 Front Load Washer
Hello again update on error f05 was a sock blockage in the black rubber tubing that connects from bottom of drum to the pump it was a easy fix just plastic clips holding it on make sure you turn off electric first lol !!!! all working fine now.
thanks daddonk
Oct 22, 2007 | Washing Machines
Hotpoint Aquarius WF000 Front Load Washer Logo
686 people viewed this question
Top Hotpoint Washing Machines Experts
Todd Arndt
Todd Arndt
Level 1 Expert
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
