HP Compaq Presario V2000 PC Notebook
Problem for HP Compaq Presario V2000 PC Notebook
Compaq Presario V2000 Notebook Won't Boot Up...
By imp_squared on Aug 14, 2008
It won't even pass POST. What happens when I press the power button on the laptop is the power led lights up solid orange and the Num lock and Scroll lock leds keep flashing orange.
I've already replace the motherboard with a new one that I order from eBay and same thing is happening. So right now I'm totally 90% heading toward replacing the CPU as it probably burnt out. (Grr... probably should've replace the CPU first.)
Any other thoughts people before I go out and order a CPU replacement.
Comments:
Aug 15, 2008
- It's an AMD...
I ordered a replacement AMD CPU for the laptop... hopefully that fixes the problem...
Aug 18, 2008
- Not my laptop.. it's for a client of mine. If they are willing to pay for it, then so be it. I told them it would be better to purchase a new one.
Same Problem
Dec 16, 2008
-   I'm also having the same problem as "imp_squared". Mine is Compaq Presario V2000 (model V2616TN) Intel Centrino. I have done what "Ray Phillips" has suggested:
1. Swap the RAM ~ bought a new one from ebay
2. Unplug/plug all the cables
3. Remove and assemble all the devices as shown in the manual http://h10032.www1.hp.com/ctg/Manual/c00444244.pdf
4. Connect to external display
However, it's still the same... Only power indicator can be seen.. What should I do? Change the CPU first or change the motherboard first?
Many thanks
~Mizie~-   tarm121
Oct 19, 2008
-   same thinig here only with v2552. power indicator on, scroll and cap locks blink. nothing else. was told it was motherboard and too expensive to fix. bought a toshiba but would like to get compaq working if possible. -   rsfinney
Best Solution
posted on Aug 28, 2008
Very Helpful)
Guest
Rank: Apprentice
Rating: 0%, 0 votes
Being that a new motherboard did not fix the problem, I would try these things next:
1) Swap the RAM and try again. Faulty memory will stop a PC dead in its tracks.
2) HP's and Compaq's are known to have issues if ANY of the cables are not plugged in all the way, or are in cocked at an angle. I have "saved" at least 4 HP/Compaqs just by unplugging and plugging the internal cables (like keyboard, mouse, power button board, LCD, etc). This is a lengthy process... but, hey; if it fixes it, why not? (don't forget to check the connector on the back of the LCD itself!
3) Unplug the battery and A/C power. Hold the power button for 30 seconds. On most laptops, this resets the charging/power circuits and can revive some dead laptops.
4) remove all non-necessary devices from the laptop and try booting again. These include: Hard Drive, CD-ROM, WiFi Card, Modem board, Keyboard, Touchpad, and anything else that isn't needed to boot. If it starts up with them removed, start putting them back in one at a time until it fails to boot again. That's your culprit.
Good luck, I hope that helps.
-Ray Phillips
Microsoft Cirtified Professional (MCP)
Solution #2
posted on Aug 17, 2008
Not Helpful)
hockeyguyJC
Rank: Wiz
Rating: 78%, 63 votes
With all the trouble you are having to go through determining the issue , might be a better idea to head out to a store and get a new laptop (Cant stop laughing over that future shop commerical with the funny names the robot calls the customer)
Was this helpful?
Yes
No
Solution #3
posted on Jul 02, 2009
Not Rated)
paziyer
Rank: Apprentice
Rating: 0%, 0 votes
I have a Compaq Presario V2000 Noteebook, that is two years old.
It stopped working and I called Compaq. After diagnosing thee problem, they advisedc me that my hard drive had crashed and I need a new hard drive. so I bought a new hard drive and replaced the old one. I cannot get the notebook to bootup. I get the following message when I try to boot it up:
PXE-E61: Media Test Failure, check cable
PXE-MOE: Exiting PXE ROM.
I have checked the cable and there is nothing wrong there.
Any suggestions?
Was this helpful?
Yes
No
Solution #4
posted on Aug 15, 2008
Not Rated)
scaledemon
Rank: Apprentice
Rating: 70%, 1 votes
what is amd or intel
Was this helpful?
Yes
No
Popular Solutions for HP Compaq Presario V2000 PC
Questions and Unsolved Problems for HP Compaq Presario V2000 PC
Do you recommend HP Compaq Presario V2000 PC Notebook?
Answer
Answer
2 months ago, expereinced sudden power lose, system shut down immediately due to that. solution back... (More)
Answer
when i load a cdr is show 0 free space 0 used space and i can't burn a cd
Describe your problem:
Select a Category:
Ask our Experts
Solve Your Problem Now!
Chat Live with an Expert
Chat Now
Top PC Laptop Experts
Top Computer & Laptop Repairmen
in , CA
(952) 890-7770
Zkarlo.com provides discount and used laptop parts...
Zkarlo.com
(877) 934-6198
Send your laptop to us and we will diagnose the...
A+ Rated Oceanside Computer Sales & Service, LLC
Chat Now
Insert Link
Insert Image
Insert You-Tube clip
Insert List
Insert List
Spell Check
What is this?
Select
