Question about SanDisk Sansa c250 (2 GB) MP3 Player (SDMX7-2048)
Sansa sandisk express froze
I plugged my mp3 player into my laptop to charge and I forgot to unplug when I left. There was nothing in the window so I unplugged it and now it won't work.
  • deviruu Sep 27, 2008
    This happend several times, the first time it didn't work i took it to the service center...n it (i dunno how) work again....n the next morning it start to froze again...but when i charge it, it work properly again. And now,I plugged my mp3 player into my PC to add some music and when unplugged it , it won't work. I plugged several times but it said the device unknown......
  • 8,596 Answers
Try this: disconnect the player from the computer, turn it off, hold in the volume + button, and reconnect the player to the computer while holding the volume + button in. Keep holding the volume + button for an additional 5-50 seconds. Windows should eventually go into recovery mode and revive the player- it will pop up a window that says Found New Hardware Wizard.
These are the most common methods for recovering Sandisk's Sansa Mp3 Players. I have been almost universally successful in recovering Sansa players using one or a combination of these methods. These methods do not work if you are having synchronization or music format issues - they are for recovering a player that will not power up, freezes, flashes, is not recognized by the computer, and a host of other issues.
Reset the Sansa Player first. On most models, restart is done by holding the power button in for 15 seconds or longer. Check your specific manual to be sure. The manuals are available from the Sansa website if they have been misplaced.
Download the Sansa Recovery Tool from the Sansa website.
Format - Erases Everything: Connect your Sansa player to the computer and open Windows Media Player. Click on the Sync tab. Pull down the drop down menu underneath the Sync tab by moving your cursor over the Sync tab and left clicking on the little black arrow underneath the Sync tab. Highlight "Sansa 1GB" (wording may vary slightly), and then select "Format." - this should erase everything.
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/DriverDownload/driverList.asp
If these fail, then:
If you get the problem where MTP Device keeps popping up continuously, uninstall the “MTP Device” by going to Start à Control Panel àSystem à Hardware à Device Manager (you computer may vary slightly, depending on Windows Version).
You may have to restart your computer after each of these methods to get them to work properly. Disconnect your Sansa player BEFORE shutting down your computer.
-Tha Mp3 Doctor
Posted on Aug 14, 2008
Sansa express won't turn on
Normal 0 Press and hold the Volume Up (+) and Select buttons at the same time for about 20 seconds
Make sure that the player is charged up.
Try to power reset the device by pressing and holding the center and volume up button at the same time, while connecting it to the PC.
If power reset fails, charge the device for at least two and a half hours. The computer should not be in sleep or hibernation state while charging.
You may need to update firmware.
Feb 07, 2010 | SanDisk Sansa MP3 Player
My mp3 will charge but when unplugged doesn't work
Make sure the hold/lock is not engaged
Reset the player
Run the Sansa Recovery Tool from Sandisk's website
Nov 24, 2008 | SanDisk Sansa e250 MP3 Player
Sansa mp3 player screen turns white
May be hardware, but:
-Tha Mp3 Doctor
Nov 18, 2008 | SanDisk Sansa e250 MP3 Player
SanDisk Sansa Express (2 MB) MP3 Player QUIT WORKING
hii
just re plug it and see what happens or.. if you have wall mount charger with a usb connect .. then us it ... and if all fails... open ur player and disconnect the batter for a minute and reconnect it and then put it to recharge...
let me know what happnes..
tc
May 28, 2008 | SanDisk Sansa MP3 Player
Won't charge
Go ahead and do this, in case the DB is corrupted:
Firmware Upgrade- Erases Everything: Get the latest firmware upgrade from Sansa - it updates the firmware and erases every song in the player all at once. Note: this method doesn't work if already have the latest firmware. Go to this website and click "Firmware Updater" to find out: http://www.sandisk.com/Retail/DriverDownloads.aspx
Mar 05, 2008 | SanDisk Sansa e250 MP3 Player
Frozen MP3
For Sansa or Sandisk problems, contact http://www.sansacommunity.com/ This site is dedicated to Sandisk products and can help you. Good Luck
May 12, 2007 | SanDisk Sansa c140 MP3 Player
SanDisk Sansa  c250 (2 GB) MP3 Player (SDMX7-2048) Logo
67 people viewed this question
Top SanDisk Audio Players & Recorders Experts
Gyula Lacz
Are you a SanDisk Audio Player and Recorder Expert? Answer questions, earn points and help others
