I have a HP Professional Deskjet 1220C. It starts off printing full colour images ok but about a quarter of the way through it starts printing in red. Please help me.
  • 659 Answers
Try the following below if it continues to print in red half way through then either your ink carts have expired or something is wrong with them if you are using coral draw to print images there is know problems with that I have listed the solution to that as well. please tell the results of the test page as well please. and also I have included a few other tests please run through these. The sample page can be used as a quick check of the image quality from the black and color print cartridges. Unlike most printing, this page prints from the bottom of the page to the top for user viewing during printing.
  1. Turn the printer off and then turn it on again by pressing the POWER button.
  2. Press and hold down the RESUME button and release it when the Power light starts to blink.
The sample page can also be printed from the Toolbox (provided the Toolbox is installed) to verify that the printer is connected to the computer properly and that the printer and printer software are working properly.
  1. Double-click the Toolbox icon on the Desktop or run it from the HP Deskjet 1220C Printer program group.
  2. Select the Printer Services tab and click Print a Test Page
Printing the diagnostic page The information displayed on the diagnostic page includes the printer model, serial number, service ID (born-on date), firmware revision, total page count and last error code (see Figure 2). If an error code (hex) number is displayed, it represents the last error that occurred regardless of whether the problem that caused the error has been fixed and the printer is presently operational. To print a diagnostic page see the following:
  1. Turn the power on.
  2. Press and hold down the POWER button.
  3. While holding down the POWER button, press the RESUME button four times.
  4. Release the POWER button.
Running the pen recovery diagnostic test If printouts have incomplete text or graphics that are not corrected by cleaning the print cartridges, use the pen recovery diagnostic test. The pen recovery diagnostic test is a three-level cleaning procedure that attempts to clear blocked print cartridge nozzles. The tests can be run either from the Toolbox under Printer Services or by pressing the button sequences below. The Level 1 print cartridge cleaning is a light cleaning mode. Use this level first to clear blocked nozzles.
  3. While holding down the POWER button, press the CANCEL button twice.
After running the Level 1 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 2 pen recovery. The Level 2 cleaning is an intermediate cleaning mode to be used if the Level 1 mode does not recover the nozzles.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button once.
After running the Level 2 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If there are irregular gaps in the printout, run the Level 3 pen recovery. The Level 3 cleaning is the most intensive cleaning mode that takes about two minutes to complete. Use this level as a last resort in recovering clogged nozzles. This routine uses a considerable amount of ink.
  3. While holding down the POWER button, press the CANCEL button twice and the RESUME button twice.
After running the Level 3 print cartridge cleaning routine, run the nozzle pattern test explained in the "Printing the nozzle pattern test" section below to verify that the cartridge has recovered. If no irregular gaps are present on the printout of the nozzle pattern test, the print cartridge has recovered. If irregular gaps still appear in the printout, replace the cartridge. NOTE: Do not use the pen recovery tests unnecessarily or the life of the print cartridge will be shortened. Printing the nozzle pattern test This test prints a pattern to determine which nozzles, if any, are clogged or not firing and can be used to verify a successful cleaning routine (see Figure 3). Look for irregular spaces or gaps in the test pattern; these indicate faulty nozzles.
  3. While holding down the POWER button, press the CANCEL button eight times and the RESUME button four times.
Printing the calibration page This test provides calibration of the print cartridges. Calibration includes print cartridge alignment and optimizing the turn-on energy for the installed color print cartridge.
  3. While holding down the POWER button, press the RESUME button three times.
Eight green checks, one on each line of the printout, signify that the calibration was successful. ----------------------------------------------------- Printing the infinite H test This test prints continuous pages of the letter H and is useful for troubleshooting paper feed problems or other intermittent problems that are difficult to replicate.
  1. Turn the printer on.
  3. While holding down the POWER button, press the RESUME button eight times.
  5. Press and release the POWER button to terminate the test.
Posted on Aug 14, 2008
  • Wesley Gardner
    Wesley Gardner Aug 14, 2008
    CorelDRAW v 6.0, 7.0
    1. In CorelDRAW, select View and Color Correction .
    2. Choose the Accurate setting.
    3. Go to the Print Dialogue box by selecting File and Print .
    4. Deselect Use Color Profile or the Generic CMYK Color Printer setting.
    CorelDRAW v 8.0
    There are two options for this version, either should improve the color quality.
    To deselect the Generic CMYK Printer profile:
    1. Click File , then Print .
    2. Select the Miscellaneous tab.
    3. Select the Set Profiles button.
    4. For the Composite Printer, choose None .
    5. Click OK , then Print .
    To disable the Use Color Profile option:
    3. Deselect the Use Color Profile option.
    4. Click Print .
Hp dj 1220c printer driver refused to install on my windows 7
Try to reset the factory settings: Go to Settings tab and press the Resets option. This will change all the settings to default factory settings. Try to print using another OS and check if there is a difference in the print quality. Try to print in draft mode and in FastRes 1200 mode. Tip and tricks for all deskjet setup
https://123hp.co/hp-deskjet-printer-models
Oct 28, 2013 | HP DeskJet 1220c InkJet Printer
HP Deskjet 1220C has started printing a series of vertical blotches and misaligned text in the same three places. Same problem with black or colour. Have aligned cartridges, cleaned fluff, etc, to no...
there might be a problem with the encoder: remove it, observe it closely with a magniying glass, and you have to see a vertical lines pattern all along the enconder, without no blurs or missing or erased parts on it. Try to clean it with alcohol and a cloth but be careful no to erase the patterns i described early. If there are missing lines in the pattern you'll need to replace.
What is the encoder? a strip of semitransparent plastic that goes in the back of the cartridge carriage.
Sep 04, 2010 | HP DeskJet 1220c InkJet Printer
Colour printing not coming
try to make uninstall the printer drivers and install again the drivers or go and find the Printing Preferences then try to make a resets the printing..Thank You...
May 09, 2009 | HP DeskJet 1220c InkJet Printer
Not a colour printing
Please make sure that you are using the correct driver for this printer.
HP releases a monochrome (Black only) driver and a full driver.
My HP 1220C cant print in colour
check printing preference on color tab.
Feb 27, 2009 | HP DeskJet 1220c InkJet Printer
My hp deskjet 1220c not printing, the cartridge indicator blinking continuously .
try cleaning the print heads on cartridge lemon juice n warm water. with a cloth
actionman
HP 1220c double image
plz do a nozzel chek and head cleaning (go to control pannel > printer and faxes > right click on your printer >click on properties>click on maintenance and performed the above test)
May 17, 2008 | HP DeskJet 1220c InkJet Printer
Colors Murky... HP DeskJet 1120c
REPLACE COLOUR CARTRIGE.IF THE CARTRIDGE IS DAMAGE ON THE INSIDE THE THREE COLOURS SOMETIMES MIX CREATING A COLOUR WHICH LOOKS BLACK
May 11, 2008 | HP DeskJet 1220c InkJet Printer
HP 1220 c printing is Blue
the printer uses a tri color cartridge seems like the cyan is finnished.install a neww colour ink cartridge
Mar 13, 2008 | HP DeskJet 1220c InkJet Printer
892 people viewed this question
jasbo
jasbo
