Question about Polaroid I533P Digital Camera
My Polaroid i533 digicam won't turn on
Whenever i turn my i533 digi cam on, the lens pop out and i can see the green light blinks. However, the LCD has no display and i hear 3 beeps. The camera would automatically shuts off, but sometimes it wouldn't, leaving the lens out. No matter how i try to press the on/off button, the green light keeps on and the lens wouldn't retract unless I remove the batteries. When I inspected the unit, I noticed that the lens is slightly misaligned.
Pls help me with this problem. Thank you.
  • eneidaperez3 Aug 19, 2008
    when i turn the cam on, it will blink but won't come out the lens.
It's not working.. you think polaroid is stupid?
Posted on Nov 21, 2008
Try checking to see if the lens is a little crocked, look at it real closley.If it is then try and pop, or bend the lens back into place, and then turn your camra on and the camra may work propelry.
I had the EXCACT smae problem, and it worked for me.
So it may hlep you too.
Posted on Aug 17, 2008
Popping noise and now won't power up. Red and green indicator lights blink on front of tv.
start by checking the power supply in the set and if not able to do that consider taking it to a shop for an estimate.
Jun 16, 2012 | Toshiba 52HL167 52 in. LCD HDTV
Whenever i turn my i533 digi cam on, the lens pop out and i can see the green light blinks. However, the LCD has no display and i hear 3 beeps. The camera would automatically shuts off, but sometimes it...
You've got to clean the contacts on the battery, the battery compartment and you charging station. This can easily be done using a Q-Tip "dampened" not soaked, in rubbing alcohol. Clean them all well and then if you can find a drinking straw blow dry the battery compartment and wipe down the battery with a fresh cloth or paper towel. Do the same to the station. If all this fails, replace your battery. The battery indicator on these cams is "not" always accurate.
Sep 06, 2009 | Polaroid I533P Digital Camera
Not turning on, light blinks once that's it
hi try to reset ur camera...To do such reset, turn on the camera and hold the menu button down for longer than 5 seconds. A message should hopefully come up on your LCD asking if you want to reset the camera. Select Yes...thank u!!!
rate me!!
May 29, 2009 | Polaroid I533P Digital Camera
Polaroid camera i533
well sure u just go to
Chandrakanth
+(91)-9346340947,9392416633
1-8-3/23/7 1st Floor, Hotel Sunanda, Chikkadpally, Hyderabad - 500020
Oct 24, 2008 | Polaroid I533P Digital Camera
Polaroid i533
Lens failure. There is no way to fix it.
Jul 24, 2008 | Canon PowerShot A520 Digital Camera
It Turns On Then It Turns Right Back Off
I put Rechargable Duracell Batteries in and now it takes pictures and turns on without a blank screen or shutting back off.
Jul 12, 2008 | Polaroid I533P Digital Camera
Makes 3 beeping sounds then turns off
what happen if you put another memory card in it?
Dec 02, 2007 | Polaroid I533P Digital Camera
The lcd screen on my polaroid i533 digital camera went out
your screen is broken, some one must have accidentally put pressure on just the screen. The smae thing happened to my screen now i am looking to buy a new screen
Oct 27, 2007 | Polaroid I533P Digital Camera
Lens is broken
My daughter just had this problem with her camera. The camera was off with the lens barrel extended. When I looked at it closely, I noticed that the inner part of the lens barrel was at a slight angle to the camera. I pushed firmly on the low side of the inner part of the barrel, and it popped the rest of the way out. Camera works fine now. Good luck!
Oct 03, 2007 | Polaroid I533P Digital Camera
Polaroid I533P Digital Camera Logo
226 people viewed this question
Top Polaroid Cameras Experts
Greg Cann
Greg Cann
Steven Wander
Steven Wander
Are you a Polaroid Camera Expert? Answer questions, earn points and help others
