Question about Acer Aspire™ T180 PC Desktop
Acer Aspire T180 Won't turn on--
The fans on the computer run and the red light on top flashes for a minute then nothing happens, it won't boot up at all. Before I had this problem it went straight to the Acer screen and wouldn't go any further so I unplugged all the usb cables and it booted up. The Cd-rom works fine when I turn the comp on, which gave me the impression that the hard drive was working, but I don't know for sure. I also tried taking it apart and that didn't work to my advantage either...any suggestions????? Thanks..
  • 6 more comments
  • Blondesooner Aug 14, 2008
    No, everything stays on the fan continues to run, the red light on top goes off after 5 sec and the monitor is just black...nothing appears..
    Okay I tried hitting delete, but the problem now is the monitor displays "no signal", but the comp turns on and the fan runs...?? I did unplug my comp from the power source without restarting it first./.could I have crashed it??
    No beep..I can just hear the fan..before it beeped oncee and then the acer screen would come up, but I can't even get it to boot because the monitor stays black and also my keyboard doesn't work now either..so where do I go from there?
    Okay I took the CMOS battery out and did what you said, but it's still doing the same thing..monitor still says no signal along with the keyboard still not working..thank you btw for trying to help me I really apprecite this!! Keep the help coming!! =]
  • Anonymous Nov 11, 2008
    AS SOON AS I PLUG THE CORD ON BACK IT TURN ON BY IT SELF CANOT TURN OFF LIGHT ON CDROM IS ON.
  • wayne dennis Feb 16, 2009
    I have the same problem. No beep on startup. Fans run slow. DVD runs can be opened and closed. Nothing on keyboard, mouse or monitor. All dead except monitor says no signal for a couple seconds and then black. Pressing power shuts fans off. A few times holding power button increased fan speed which I thought was good but not so everything else same. All what changed was fan speed and when fan speed increased DVD light was on but couldn't open drive. Please help
  • scottfulcher Feb 17, 2009
    computer just beeps when switched on - no signal to monitor
  • Joe L.
    Joe L. May 11, 2010
    What do you mean by nothing happens? Does the computer power off? Fans go off? or Fans stay on lights are on but blank monitor?
  • 56 Answers
There is a similar problem posted here: http://www.fixya.com/support/t344696-acer_aspire_t180_ub72_not_boot
Unplug all USB devices as it may be trying to boot from a USB drive.
If you don't have USB drives plugged in try booting into the BIOS to see if the computer is booting that far. Restart the computer and keep hitting the DEL button, that should get you into the BIOS.
Posted on Aug 14, 2008
  • 1 more comment
  • Joe L.
    Joe L. Aug 14, 2008
    Is there a beep sound from the computer when you boot it up? If so how many beeps? These beeps tell you if the computer is booting up properly.
    I want to make sure the computer is not booting up at all, if it is booting up, then it means something is wrong video wise. Giving you a "no signal" on your monitor.
    If there is no beeps, that means it would be a hardware issue.
  • Joe L.
    Joe L. Aug 14, 2008
    Reset the CMOS/BIOS.
    1. Shutdown, power off, and unplug the power cable from the computer.
    2. Open case up the computer.
    3. Look for the CMOS battery. As circled here:http://www.technibble.com/articlecontent...
    4. Remove it and leave it out for about 1min or more.
    5. But the battery back in and try to boot up again.
    I'm trying very hard to cover the small things. Hopefully saving you from replacing a big part on the computer.
  • Joe L.
    Joe L. Aug 14, 2008
    What do you mean by the keyboard not working? No lights lit up? Try hitting the Num Lock key to see if you get a led light.
    Sorry about all the questions, but it gives me a better idea of what is going on with your computer.
    As of right now with everything said... I believe it is the CPU that might be the main problem. If I computer has no cpu or a dead overheated cpu, the computer won't boot up and won't go to the BIOS.
    New Friend:
    Problem Solver:
  • 7 Answers
I had a customer come into the shop with the same problem, I pulled everything out of the machine and left nothing but the essentials and still had no luck, I went back to the customer and asked what he was doing to it before it happened and he told me that he had hoovered all the dust out of the machine and that he also pulled out the fan covering the cpu to clean it but what he failed to tell me was that when he pulled out the cpu fan he also pulled out the cpu itself, so when he put the fan back in (with the cpu still stuck to the bottom of it) he had actually bent all the pins on the cpu, so after a time consuming job of straightening all those little pins I managed to get the machine up and running. Just hope none of you guys were dumb enough to make the same mistake.
Posted on Nov 23, 2012
I would remove all usb devices espesially front connecetions. If you mange to get into the bios, check priority of booting options
    Genius:
  • 1,011 Answers
Try with unplugging all other devices except hard drive if it still not booting properly then the problem is caused by the hard drive.
try to boot is with dos cd or win98 cd and the do a format to windows and reinstall it if u can..
may be the problem is with the C drive containing windows.
remember to save you data to other drive in dos mode ...
regards,
The power went out here at work and my acer desktop wouldn't log into anything (ie email, internet) when the power came back on. So I clicked shut down and it turned off but now it won't turn back...
try taking out all peripherals like mouse printer keyboard leave screen pluggged n then press and hold the power button for 2 minutes then plug in your mouse and keyboard and see if it boots hope this helps
Sep 14, 2011 | Acer Aspire™ T180 PC Desktop
Hi. When I turn on my Acer aspire t180, only the red button light up, but the green button does not light up . And then nothing happens. Please help me as im having the same problem for months already.
Im guessing the PC starts up flashes the lights turns off and repeats?
If so the hard drive boot sector is gone or damaged. Try to boot from the Windows disk.
Nov 03, 2010 | Acer Aspire™ T180 PC Desktop
I have a Acer Aspire T180 that doens't boot. The problem: When I hit POWER for about 1 second a red led is burning. After that; silience at all.. I don't hear any fan or noise from the powersupply. Nothing...
first you have to check if the power supplyof your CPU is not defective.or your power the one that is connected to the AC outlet. replace the power and try to turn it on if still not working purchase a new power supply that fits to your PC ....its up to you how many wattage your going to buy
Oct 09, 2009 | Acer Aspire™ T180 PC Desktop
Acer Aspire T180 wouldn't turn on...
Hi again.
It's the memory thats the problem, continuous beeps indicate a memory failure, take the system memory out and clean the contacts and the slots with a dry, clean paintbrush. Re-seat the memory and re-start the machine. If you still get beeps post back.
Good luck!!
Feb 15, 2009 | Acer Aspire™ T180 PC Desktop
Acer T180 will not boot or power on. It has a bad attitude!
Try tapping F2 as it is booting to get in safemode. If that works we're in business.
Dec 29, 2008 | Acer Aspire™ T180 PC Desktop
Acer t180
sounds like your fan is not running. Open the box and have a look to see if your fan is disconnected and if it doesn't appear to be turn your PC on and see if it works and if no result replace your CPU fan. Its a easy fix but im not sure how much replacement fans are so look into that and find out
Nov 06, 2008 | Acer Aspire™ T180 PC Desktop
ACER T180 does not boot up
check the fan of your cpu is it working fine also check the RAM, do it by putting some other RAM which is working
Sep 10, 2008 | Acer Aspire™ T180 PC Desktop
My ACer T180 does not boot boot up
sound like the hard drive. do you hear the drive spinning?? you may need replace or reformat.
what OS are you running....?
Won't boot..
dear,
u unplugged everything and it booted up finely.
its mean that there is something wrong with the drviers.
check it one by one. just plug hard driver first and let is boot. if its still behaving the same as after plugging all then the problem is caused by the hard drive.
regards,
Aug 14, 2008 | Acer Aspire™ T180 PC Desktop
Acer aspire t180
plz check the hard disk and ram
Jul 20, 2008 | Acer Aspire™ T180 PC Desktop
Acer Aspire™ T180 PC Desktop Logo
2,709 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
