Question about Baby Trend Snap-N-Go LX Double Stroller
Need straps I need replacement straps - the plastic snap part is broken on one of the straps. I am referring to the straps that keep the car seat secure to the frame
  • Anonymous Sep 18, 2008
    One of the clips from my strap broke, so I need to find a replacement.
  • Anonymous Apr 18, 2009
    the clip on the strap broke on my snap and go and its very important to have it as my model of my chicco car seat does not lock into the snap and go by itself
Try REI or other camping store.
Posted on Oct 12, 2008
You can get plastic replacements at any fabric store. Bring in the strap and ask a clerk for help. You will probably have to replace both plastic pieces.
Posted on Dec 01, 2008
How to remove front dopr panel on 1995 Lincoln Town Car
Front Door Panel - Town Car - Removal
CAUTION: To avoid breakage of door pull cover(s), insert a screwdriver diagonally between pull strap and chrome bracket. Snap out both sides then remove.
Snap out two door pull strap retaining screw covers. Remove screws.
Remove two screws on front and rear side of front door trim panel.
The following procedure must be used during removal and installation of the door armrest and trim panel. Refer to the appropriate illustrations for component and vehicle model identification.
Using the Trim Pad Removing Tool from Rotunda Windshield and Moulding/Trim Removal Kit 107-R0401 or equivalent, pry the trim panel retaining clips from the door inner panel.
NOTE: Do not use front door trim panel (23942) to remove trim clips from door inner panel. Replace any bent, damaged or missing push pins.
Remove window regulator control switch housing from back of front door trim panel . Lift up housing, remove retaining screws and disconnect all connectors.
Disconnect driver seat regulator control processor switch (driver door only) if equipped.
Twist out interior lamp wire assembly and remove the front door trim panel.
Installation
Ensure plastic watershield is secured to door panel.
Position front door trim panel to door. Connect interior lamp wiring.
Position the window regulator control switch housing and connect switch connectors. Install the retaining screws.
Connect driver seat regulator control processor (14C708) (driver door only) if equipped.
Align door lock side to its mating slide on the sheet metal (front doors only).
Snap in front door trim panel. Ensure all retainers fit properly.
Install two retaining screws on front and rear side of front door trim panel .
Install two retaining screws and pull strap covers.
Good luck Remember rated this).
May 31, 2010 | Lincoln Town Car Cars & Trucks
Straps on back of carseat seem to be put together incorrectly
Those go a certain way and no other. For future reference the way to remove the belts is to release the metal oval under the seat and bring it up thru the holes in the bottom of te seat, then out thru the back. You have to undo the clasp and chest snap. Now....you have quite a problem as the straps are responsible for saving a life in the event of a motor vehicle accident. This being said you can try and slip the doubled over ends thru the end that is most narrow, slides into the track and the wider part snaps over the keeper on the seat itself, a little snapping plastic button. Next it goes under the lockdown and up into the first hole. You will need to compress the adjuster of the locking mechanism to get it up thru. If you can do this the next step is down thru and out the end of the locking mechanism. If the holes are too bound up and wont let the end of the belt thru, you may need to cut off the very end and re-thread it, then fold over the material and resew the end over itself to reform the stop. Cutting a belt is a last resort so make sure you are careful and that it is working properly. Otherwise, go buy a new seat. Good luck
Apr 09, 2010 | Evenflo Aura Elite Travel System
Winnie the pooh graco car seat how to put the arm straps back together after washing
I had the same problem, so what I did was look at the first picture from walmart.com's page with this car seat.
http://www.walmart.com/catalog/product.do?product_id=10843110
I noticed where the straps went through the restraint systems, and remebered that I took the bottom ones out last, so I'd put them in first.
Then I threaded the straps through the buckle parts that snap to the bottom buckle, up through the buckle parts that snap together, then back through the holes in the cover and seat at whatever height your infant is. After that you secure it in the back like the sticker at the side indicates :)
I hope that's clear enough!
Jun 17, 2009 | Graco Nautilus 3-in 1 Car Seat
Clean my car seat
Those pieces WILL snap out, it just takes a bit of effort. Both my son and the boy that I nanny for have this car seat and I have taken them apart for washing the cover a couple of times. Just make sure to remember where everything goes back to.
If you're having difficulty prying them up, try using two spoons. Wedge either the handle ends or the spoon ends under either side and use them to leverage the piece up.
Hope this helps!
Mar 23, 2009 | Eddie Bauer Deluxe 3-in-1 Convertible
How to work restraint latches
Do you mean the little straps that hold the front of the car seat in? On each side of the pushchair there's a short strap with a plastic thing at the end. These line up with the open-ended slots on the sides of the car seat. If you pull the strap straight, the plastic thing can just be tugged around the end of the slot on the seat so that the strap now goes through the slot and the plastic thing holds it on. It's tricky the first couple of times but gets easier. Sorry if that wasn't the question...
Mar 16, 2009 | Graco Quattro Tour Deluxe Travel System...
Cosco Buckle Broken
Bought a new car seat
Sep 26, 2008 | Cosco 02-442
I took the cover off to wash it but now can't figure out how to put it back on. I think it is a 5 point connection system model 8465wsr3
Its a GREAT seat! I have the same one!
Assuming you removed the harness.
The easiest way I have found to do this is , place the seat on the ground and put the cover on the seat. There are some elastic fastners that are loops on some models, that go onto small plastic poles. IF you don't have this, it is ok.
Then clip the harness together at the chest clip, and at the buckle. This helps you not get so twists.
Put each of the top shoulder straps through the hole in the seat cover AND the plastic of the shell of the seat. For this rear facing seat, the straps should be At or BELOW the shoulders of the infant riding in the seat. When both straps are through the plastic shells, you slide them onto the metal flat mushroom shaped piece on the back of the seat that is attached to the adjustor strap.
Pass the middle strap (the buckle) through the hole in the seat cover and shell. Pull to ensure it catches.
NExt, take the small metal cliped bottoms of the harness, and pass them through the seat cover and seat shell in the bottom of the seat, they are in the crease of the side/bottom of the plastic shell. Once they are passed through, give them a good pull to ensure they catch. Repeat for the other side, and you are good to go!
If you washed the harness, in the machine, it needs to be thrown out, call Graco for a replacement.
Jun 17, 2008 | Graco SnugRide - Giselle Infant Car Seat
Baby Trend Snap-N-Go LX Double Stroller Logo
453 people viewed this question
Top Baby Trend Baby Gear Experts
Jennifer Rock
Jennifer Rock
Mike
Dennis Crouse
Are you a Baby Trend Baby Gear Expert? Answer questions, earn points and help others
