Question about Olympus Cameras
Olympus e10 problem. Even with new batteries, could only take a couple of shots before the low battery icon came up & camera shut down. Would work fine using mains supply. Fixed by buying new battery holder. Now 3 weeks later doesn't work again - low battery then switch off both using batteries or mains power supply. Any ideas appreciated as it's a great camera when working. Thanks
You didn't say what type of batteries you are using. Best are CR-V3 lithium which should give 500 shots. 2300 mAh Ni-MH rechargeable batteries should give 200 shots. Worst are alkalines which Olympus do not recommend.
Have you checked the contacts in the bottom of the battery chamber for cleanliness?
Posted on Sep 24, 2008
What could be the cause and solution to battery drain on my Olympus FE-110?
You've likely got a problem with the internal battery sensing hardware. I had a similar problem with a small Canon and solved it by getting a new camera for way less money that having the old one fixed.
Jun 10, 2014 | Olympus FE-280 Digital Camera
Even with fresh batteries installed, I only get a few shots before the "battery empty" icon appears. Then, if I remove and then re-insert the same batteries, the initial result is a green...
Hi, well this is a pretty common problem, with this and many other cameras of a similar sort, what happens is that inside there is a power conditioner circuit, components, usually a "pass" transistor in this circuit partially fault, and increase the current draw from the battery dramatically, and this causes it to go "Flat" very quickly.
There is little that can be done DIY, what has to be done is to take the camera to an Olympus service center, and ask for a "Quote" for the repair.Then you can make an informed decision as to what to do, repair or replace.
Feb 09, 2011 | Olympus SP-560 UZ Digital Camera
Olympus MJU 760 Battery dies after a couple of
First step to trouble shoot. Connect a low voltage ohm-meter to the battery contacts inside the camera. Try to turn camera on. If you get a reading, write down the number of ohms. If possible, compare this with a brand new one, if store will let you. Or call the USA distributor. If ohms number is way low, you have problems inside the camera. If number is normal, the battery is no good.
May 14, 2010 | Olympus Stylus 760 Digital Camera
Battery drainage
20 to 30 shots on "fresh" batteries! Do you use the flash on all shots. That really drains them. I would try to set the camera to "factory default settings" in case you changed something that is causing a drain. I hope you just bought some bad batteries.
The best thing I EVER bought for my Olympus was the Re-chargeable Lithium Ion batteries. The worst thing I did was buy an off brand. That was a waste. I ended up getting the more expensive brand Olympus recommended and all was GREAT again!! 1,000's of pictures later and they still work great.
Good Luck
Oct 03, 2009 | Olympus SP-550 UZ Digital Camera
What type of rechargeable batteries are the best. batteries even when fully charged can only take 2 pictures .
The problem is not in the batteries....
I have the same problem, after two pictures the camera shuts off even when new batteries have been installed...
Aug 26, 2009 | Pentax Optio E10 Digital Camera
Pentax e10 shuts off The pentax optio e10
You probably set the auto power-off for energy saving
Jul 12, 2009 | Pentax Optio E10 Digital Camera
Batteries fail in very short time
I had the same problem but I fixed it by buying 2 rechargable CRV3 batteries and the charger. At the time such batteries were not common, so although I got a brand that I never heard of (CTA) and they have been great, They last a long time and power is no longer an issue.
Mar 22, 2009 | Olympus SP-350 Digital Camera
Olympus c-160 battery problem
Check your user manual to see exactly what type of batteries you can use. Not all AA batteries will work in all digital cameras. Some require a specific brand of batteries or specific number, even though, they may be physically the same size. Hope this helps :)
May 16, 2008 | Olympus Camedia C-160 Digital Camera
Automatic zoom
recharge battery after full charge install it what are changes ,does it works? If not clean battery teminals.
Dec 26, 2007 | Olympus FE-280 Digital Camera
Zooming lens on Olympus FE 110
are u using recharchable bateries??? if don´t use that ones (over 2000mAh ones) that camera just drains batteries.
Jan 05, 2007 | Olympus FE-110 Digital Camera
Cameras Logo
136 people viewed this question
Top Olympus Cameras Experts
Willem.
Willem.
Steven Wander
Steven Wander
Are you an Olympus Camera Expert? Answer questions, earn points and help others
