Question about Acer Computers & Internet
How do you open up an acer extensa e210 pc to look at the RAM. Iv undone the (black) screws at the side of th Pc and tried to slide it off but it will not move. Do i need to undo anything else? Or could you just tell me what ram can work in extensa.
  • Acer Master
  • 3,051 Answers
Try to the front cover there should be tabs at the bottom presws them in and pull the bottom of the cover out then is should be able to be taken off then there should be a screw behind the front cover for the side cover
Posted on Aug 14, 2008
Acer Extensa E210 totally death
Computer does not boot up The problem maybe the RAM, it is faulty or just needs reseating to make proper electrical contact.
Reseat the RAM and then boot up your laptop. If it still does not boot up then remove the RAM module/s and take them to your friendly computer repair shop and get them to test the RAM for you.
Aug 15, 2012 | Acer Computers & Internet
C'ant open the case of my pc
Look in the back of the PC. there are often several easily accessible screws on the outside edge of the steel backing. Remove all the ones close to the edge and attempt to slide the side of the computer back, depending on the method they used to build it you should just have to pull back and up when it comes loose.
Mar 07, 2011 | Computers & Internet
Acer Pc Tower Extensa E210, p4p800vm motherboard connection probl
So I have found the answer myself ;o)
I removed the front panel of the computer, behind the panel the wires were labelled, I connected the cables to the connectors that I required and connected them to the MoBo, works like a dream!
Jan 05, 2010 | Acer Computers & Internet
HOW DO I install new memory in acer aspire L320
First step would be to lookup your system specs either in your manual or at the Acer website. See what RAM is compatible with your system. Once this is done purchase what you need. Open the case and you should see the RAM modules & slots. If you are replacing RAM you will need to remove the old first. If you are adding to empty slots just line it up properly and seat it in the open slots. Close the case and reboot. System should automatically recognize the new specs. Make sure you disconnect power and properly ground yourself before touching anything inside your case. Hope this helps.
Oct 16, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
Install new ram in Acer aspire L320?
Sorry- I have to disagree, One screw at the back releases the lid. Inside, the dvd/hdd sub-chassis has one screw holding it to a brass post on the mobo. Undo that, then lift the chassis slightly with it's plastic strap handle, so you can detach the two connectors from the SATA drive, and the ribbon cable to the DVD (careful you don't bust the latch).
Then the whole lump simply lifts out- and you can see the 2 memory cards. The one I've just looked at appears to have 2 x 512mb simms- so you could replace these with 2 x 1024mb DDR2 SDRAM simms, to give 2GB of ram, which is what Acer say is maximum.
Cheers- AL (Luton)
Apr 03, 2009 | Acer Aspire L310 - Core 2 Duo E6300 1.86...
I want to upgrade the ram on my acer extensa 5220 laptop
that is sensible..those need to be slightly tucked in(squeezed from two side) like a slide, to be released..be careful..it will come loose..
Nov 21, 2008 | Computers & Internet
How to open Acer Extensa 5420 hard drive bay.
Actually since the Acer Extensa is more of a home use computer, it is not quiet as simple as working on business laptops. With the Extensa you have to remove the large panel on the bottom of the laptop that is held by 7 screws. The panel has 4 sets of vents in it and a 1 inch square rubber foot in the center. The screws do not completely come out as they appear to be fastened to the panel. Once you have loosed all 7 screws, there is a small place to insert your finger nail on the side close to the Windows Vista Certificate sticker. Just lift up on the panel easily as there are plastic tabs holding the panel still. Once you remove the panel, there is is only two screws holding the hard drive in place. Remove the two screws and slide the hard drive toward the back of the laptop. Done.
Apr 09, 2008 | Computers & Internet
Computers & Internet Logo
100 people viewed this question
Mohammed Ebrahim M
Mohammed Ebrahim M
