Cartridge erro I have put a new cartridge in, but still got the erro " Cartridge Erro" Regards Tonni Pleace Help
  • riedel Aug 14, 2008
    It's a HP PSC1340 All-in-one, and It's a fresh cartridge. Yes the lights for is blinking for Check Print Cartridge. And the display for Copies is and E
    Regards
    Tonni
  • Bob Headrick May 11, 2010
    We will need more information: What is the printer model? Is the cartridge a fresh OEM cartrdige or is it a refill/reman? Are there any other indications such as blinking lights or other messages?
If it is an HP inkjet 940c best course is to throw the printer away and go out an buy something reliable.
Posted on Sep 08, 2008
    Scholar:
  • 137 Answers
HP's troubleshooting guide for this error is available here and has several causes for the cartridge light blinking, including an open door, a cartridge not properly seated, tape left on the cartridge or a defective cartridge. See the guide for troubleshooting steps.
If troubleshooting indicates the cartridge is defective try cleaning the cartridge contacts as shown here. (This is for a different series of cartridge but the same principle in cleaning applies).
Regards,
Bob Headrick, Microsoft MVP Printing/Imaging
Posted on Aug 15, 2008
Geting erro of 59.00 in 4250 printer
hi
HP LaserJet 4250n Printer - (Q5401A)
replace the fan --- erro 59.00 is failed fan.
on right or left of printer
Fan RK2-0278-000CN In stock
Cooling fan - Located on left side of printer (FN101)
RoHS: Modified
93.60 0.00 93.60 RK2-0280-000CN In stock
Cooling fan - Located on right side of printer - Provides air to the print cartridge area (FN103)
RoHS: Modified
Aug 01, 2011 | HP LaserJet 4250n Printer
Hp photosmart d7200 erro Oxc18a0001
Filling your cartridge with non-HP ink won't cause an error. There are basically two reasons for ink system failure, The cartridge is no good or the ink system has failed. Some of these machines can be reset. But, try replacing cartridge first.
Jul 16, 2009 | HP Photosmart D7460 Printer
Get error: check ink u059 col
For me, this meant that I put it an ink cartridge that wasn't compatible.
May 22, 2009 | Canon PIXMA MP180 All-In-One InkJet...
Machine erro 71 new scanner moter still giving me erro 71???
sometimes people use different names for these two items, but "scanner" to me as a tech, is the assembly with the light under the glass. the error 71 points to your "laser" unit which is pretty deep inside your machine and most likely, only a tech would be able to replace it. once replaced, the code will automatically reset.
hth,
razors
Mar 12, 2009 | Brother MFC-8440 All-In-One Laser Printer
ERRO
The following solution was found at;
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&taskId=110&prodSeriesId=446153&prodTypeId=18972&prodSeriesId=446153&objectID=c00314875#A9
Cut & pasted here it is;....
10.0003 Yellow cartridge e-label error Error message 10.0003 supply error alternates with Reinstall c00381084.jpg with a ? under the Yellow print cartridge gas gauge Description E-label cannot be read or print cartridge is not properly installed. Action
  1. Open the front cover of printer and remove the toner cartridge exhibiting error.
  2. Inspect the print cartridge to ensure the e-label reader is attached to print cartridge and is not damaged.
  3. Inspect the inside of printer to verify the e-label does not have any product packing tape still attached.
  4. Inspect the e-label reader to ensure the gold contact points are not damaged or bent. Also inspect the black plastic on e-label reader to ensure it is not bent or broken.
  5. Reinstall the print cartridge.
  6. Power cycle the device.
  7. If reinstalling the print cartridge does not resolve the issue, replace the print cartridge.
  8. If the problem continues, contact HP Customer Support Center for technical assistance at http://www.hp.com/support/clj2600n or see the flyer that came in the printer box for additional contact information.
Nov 28, 2008 | HP Color LaserJet 2600n Printer
Epson Aculaser C1100 erro message install C tnrcart
You need to remove the cyan cartridge, and thoroughly clean the inside of the printer (please use proper printer cleaning kit, not a damp cloth!). The sensors can get crudded up with loose toner inside the machine.
Oct 28, 2008 | Epson Aculaser C1100 Printer
Cartridge erro
hi,
try to clean the printer contacts of the left.before you do that unplug the powercable first.used a cotton swab to clean the copper contact of the printer..after cleaning insert the ink cartridge..if the error is still occuring this is now an issue of the printer..the printer needs to be replaced/serviced...
Jul 17, 2008 | HP Officejet 6310 All-In-One InkJet...
Hp 5550 dtn 10.00.00 supply memory erro
the chip is faulty on the black cartridge, change the black and it'll work, alternately you can out it diagnostic made and run without the cartridges being monitored
May 09, 2008 | HP LaserJet 5550 Printer
321 people viewed this question
jasbo
jasbo
