The computer doesn't know what the camera is without the software. You can download the software from the nikon website. Easier fixes are available. If it is a notebook (laptops arent laptops anymore more) you should have a card reader slot on the left side of your computer. Remove the SD card from the camera and plug it into their computer. Then you'll have the option to import the pictures.
does your camera has a usb port? if it does try finding the appropriate usb cable, if it doesn't check if it has any bluetooth or some other connectivity devices.if it does you will have to install a bluetooth device to your computer in order to transfer photos and videos.
Plug in your webcam thru the usb cable and see if your computer detects it? If it doesn't detect it then the camera is bad and you'll need to replace it. Other thing you can try is hooking up the camera to another computer. If it detects it on another computer then you might have a usb port problem on your original laptop or a windows problem. Also if your camera is detected on another computer then install the software for it and see if its useable.
Copy and paste this address in your browser. It will take you to the pdf of the owner's manual that you can download to your computer.
http://www.dxgusa.com/CustomerService/Manuals/DXG305VE.pdf
The best way to download pictures from your camera to your computer involves removing the memory card from the camera and plugging it into a card reader (either built-in to the computer or connected via USB or FireWire). This is likely to be faster than connecting the camera to the computer, and won't run down your camera's batteries.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Picasa.
Consider NOT connecting your camera to your computer.
Once the card is plugged in, it will appear to your computer as a removable drive. You can use the operating system's drag&drop facility to copy pictures from the card to the computer's hard drive, the same way you copy any other files. Or you can use any photo cataloging program such as Nikon Transfer.
i also have this problem when i plug my usb in my laptop..it wont find it so i open kodak easyshare as that is starting to run enter your usb in it should find it straight away and start downloading files
The camera doesn't care what operating system you're using on your computer.
It doesn't matter to the camera what operating system you have on your computer.
