Question about NetGear WGR614 Wireless Router
User name and password
I did the set up for netgear, but it is asking for a user name and login.
what can i do to get that info?
  • 477 Answers
Hello
you can find it in your manual.
you can also look here
http://www.cirt.net/passwords?vendor=Netgear
so try with
username: admin
password: password
Posted on Aug 14, 2008
NetGear router WGR614 v9. No manual, don't know user name and password so can't login to your site. Need an encryption key for this router. Cannot get a wireless connection to internet otherwise.
plug computer into ethernet port of router
Via blue ethernet cat5 patch cable
try user name admin
and password as password
try 192.168.1.1 ( later version of router ) or 192.168.0.1 for router ip address in an internet browser.
then look at the wi fi settings for wi fi security encrption key or add one if not set .
https://www.lifewire.com/netgear-wgr614-default-password-2624841
Oct 16, 2017 | NetGear Computers & Internet
How to find out netgear router password
All netgear routers have the same default user names and passwords, so unless you have changed it you should still be able to use the default one set by the manufacture.
IP address: 192.168.1.1
User name: admin
password: password
This is the default info for netgear.
If you are looking for your wireless password it will be found in wireless settings of the router on the admin page for your router.
Jun 29, 2014 | NetGear WGR614 Wireless Router
Forget router password
the default login for netgear routers is user name = admin and password = password. for older devices it is 1234.
if you are unable to login. you can reset your router to factory settings by holding the reset button in with a paper clip for 30 seconds with the power on.
Feb 15, 2012 | NetGear DG834G Router
I am trying to install a netgear cg814wg wireless router manually. I am going to http://192.168.1 but its aking for username and password. I have tried admin for the username and 1234 and password for the...
You can try resetting your netgear router to default settings. the reset is button located on the rear panel of your gateway to reset all settings to their factory defaults.
Here's the router default configurations settings:
User login URL: http://192.168.1.1
User name (case sensitive): admin or superuser
Login Password (case sensitive): password
You can also check and download your router manual & user guides here:
http://documentation.netgear.com/cg814wgv3/enu/202-10297-01/pdfs/FullManual.pdf
Good luck,
Ryan
May 26, 2011 | NetGear CG814M Wireless Cable Modem...
I need to reset or find my origional password. Please help. Thanks
If you have changed the default password, you need to reset the router to the factory settings to get in with the default user and password (user admin and password as password, or if that doesn't work try 1234 - these are the default password for NetGear routers). Note that you will lose the ISP settings and wireless settings when you reset the router.
Here's a video on how to reset the router to the factory default settings: http://kbserver.netgear.com/media/flash/training/Troubleshooting/NG_WGR614V9Router_TS_LostPassword.html
Feb 17, 2011 | NetGear DG834G Router
I cannot access the netgear settings.
to access the router you will need to open up your web browser and type in 192.168.0.1,it will then ask you for a user name and password ,the user name is admin,the password is password,that will get into the netgear utility for the router,that info can also be found on the bottom of router,if that doesnt work then you will have to reset the router to the default settings by holding in the reset button for about ten seconds located on the back ,you will have to use something that is small enough to depress it,you have to reset it while it is on,if you got it used then you should reset it anyway so that you can configure it according to your situation,ok have fun and good luck,you can get detailed info from netgears website.
Feb 01, 2011 | NetGear DG834G Router
Cannot connect wireless device to netgear router lost password
when you try to log in to your router I assume it aske for a user name and password. If that is the case, then in the user block type in : admin
and for the password, type in : password
these are the default logins for most netgear routers, other brands have other defaults.
I had to use these myself, as I have a netgear router as well.
I hope this info offers you some assistance.
Jan 07, 2011 | NetGear WNR2000 Wireless Router
I forgot my user name and logon domain
If you've forgotten the Router password, then press the Router Reset button (a small point) located next to the Ethernet port on the Router to restore the Router to factory settings.
After resetting the Router to factory defaults, use the default name and password.
Router Login: http://192.168.1.1
Login Name: admin
Login Password: password
Jul 02, 2010 | NetGear WNR2000 Wireless Router
Can't connect to the internet
You need to changed the channel number of wireless router, for that you need login to netgear router.
open internet explore and type there www.routerlogin.com then press enter,it will ask you for user name and password
typed user name as "admin" and password as"password"
now click on wireless setting which is under setup
now you can change channel into 09
now try to reconnect wireless
Thanks for using Fixya
May 17, 2010 | NetGear WGR614 Wireless Router
Net gear router ask for additional log on info that i dont know
there is no way to get for get password but u can restore at factory setting then u have re configer your router see the image i have show u in read mark this is reset button put the pan needle press 2 min your router will be reset on factory setting then the default user name and password is router admin admin
Nov 14, 2009 | NetGear DG834G Router
NetGear WGR614 Wireless Router Logo
91 people viewed this question
Top NetGear Computers & Internet Experts
Prashant M
Prashant M
Are you a NetGear Computer and Internet Expert? Answer questions, earn points and help others
