Question about Kodak EASYSHARE 5500 All-In-One InkJet Printer
Printing problem the best way i can describe the prints is that they look color negitives very sureal looking and not much black in them. i thought the problem was that my ink was low but i just replaced the cartrages with new ones but the prints still look the same
Contact Kodak All-in-One Printer customer support at http://www.kodak.com/global/en/service/contactKodak/aioPrinters.jhtml?pq-path=10747 or call them at 1-800-421-6699. The Kodak technician will guide you through reinstalling and testing of the printhead and ink cartridges. If found defective, Kodak will provide a replacement print head, along with replacement ink cartridges. The number is staffed 24/7, and if you press option "04" at the voice prompt, you will be connected to a live support technician promptly. It is definately worth the call!
Posted on Aug 16, 2008
Black and white prints are not black
Sorry, steve, that you are experiencing this problem.
According to canon.com's website regarding the i9900 InkJet Photo Printer:
Why color ink may be used when printing in black and white Even when printing in black and white, color ink is used for the following reasons:
  1. Automatic cleaning of the print head.
    To prevent the print head nozzles from clogging, the print head is automatically cleaned periodically. At that time, a small amount of each color ink is consumed.
    Therefore, although printing in black and white is performed, color ink is also consumed.
  2. Color inks may be used to create black.
    When printing in grayscale or on photo paper or when duplex printing, although printing appears in black and white, the color black may be created using the three (cyan, magenta, and yellow) color inks. Printers without a pigment black tank / cartridge will print black / grayscale will create a composite black using color ink even on plain paper.
    Therefore, although printing in black and white is performed, color ink may be consumed.
  3. In order to keep the heavy black ink from smearing on the page or in the printer, color ink is used when duplex printing to help create black text.
I might suggest taking out the color ink cartridges leaving only black there, but some printers don't take kindly to this. So, you may have to further experiment with magenta, cyan, and yellow to make it at least seem b&w to your best eye's judgment.
Good luck on this.
Jul 13, 2010 | Canon i9900 InkJet Photo Printer
HP 722C has quit printing black in color draft
WORKAROUND: Select EconoFast or Draft as the print quality setting in the printer properties. This will prevent the color cartridge from being used. - Or - Try another color cartridge. The color cartridge is used to print grayscale images in Normal or Best print modes, so if one color has run out, the printout will have the wrong tint. With a full color cartridge, the colors can be properly combined to create a composite black. CAUSE: When printing with Normal or Best as the print quality setting, the HP Deskjet 710C or 720C or 722C series printer will use the color ink to improve print quality output, even when printing a grayscale image.
Sep 07, 2007 | HP DeskJet 722c InkJet Printer
Describe your Ricoh Aficio 1232C Error Code SC481 Problem
Defective main motor
• Image transfer belt out of position
• Belt mark blurred or absent
Right from the service manual
My best guess is belt mark blurred or missing
or image belt out of position
Feb 01, 2010 | Ricoh Aficio 2027 All-In-One Laser Printer
Double vision on color only
I like the Tech Most likely did a Color Configuration , Go into the Menu and Use the Arrow keys to scroll and look for " Color Calibration " run the test make sure you don't have " Bleeding" this is a term used by Color Tech's like myself to describe that Color are mixing together which is causing your current problem.
Do calibration First.
Mar 09, 2009 | HP Color LaserJet 2600n Printer
Samsung printer printing half positive color and half negative
remove all the cartridges from the printer and shake then all 1 by 1 for 5 minutes.and then reinsert it will work properly.as all the powder in the caRTRIDGE is got collected on 1 side so this type of printout is comming.
thanks.
Dec 13, 2008 | Samsung CLP 300 Laser Printer
My HP printer stopped printing in color
sure...it is most likely a print settings issue on your word application, maybe. Check that print settings to ensure it's looking for color and not greyscale
Dec 12, 2008 | HP Office Equipment & Supplies
Lexmark X1100 printer will not print black
I came up with a work around for printing black.
I changed the black cartridge with the color cartridge.
Then when I have a letter to print, I change change (or write) the letter text to yellow, red or blue.
Then I can print out a letter.
By printing the text as yellow, red or blue the cartridge will try to print with only 1 color, but will print out black.
If you do not use one of these primary printing colors the out put will be unusable.
I can not of course print out pictures.
Oct 04, 2008 | Office Equipment & Supplies
Hi, I have an Epson Stylus 4000 printer at home. I had no problem printing high quality prints untill now. I thought that my nozzles were clogged (I haven't use it to print for a several months), so I...
print head clogged..if you remove it try cleaning it...or sink it in a boiled water to released clogged.....used tissue on cleaning...maybe its effective coz i repaired same printer you have...
Aug 27, 2008 | Office Equipment & Supplies
Kodak EASYSHARE 5500 All-In-One InkJet Printer Logo
Top Kodak Office Equipment & Supplies Experts
Michel Smith
Sajid Najmi
Sajid Najmi
Level 1 Expert
Are you a Kodak Office Equipment and Supply Expert? Answer questions, earn points and help others
