Question about HP DeskJet F380 All-In-One Printer
All lights are on
My printer cannot be switched on initially. So HP gave me a new transformer. Now with the new transformer, it is permanently on with all the indicator lights on. It cannot be switched off using the power button, only by switching off the main supply.
  • jebiga Aug 17, 2008
    all lights constantlyh flicking, printer status is 'offline'. Have checked that thre are no paper jams. all doors are closed etc.
    Master:
  • 638 Answers
Check it it must be faulty.if you will do such thing regularly it will damage your printer totally.as direct off will make your printer completly dead because off the short circuit failure.
Posted on Aug 16, 2008
  • jaker3439
    jaker3439 Jan 20, 2011
    check the flexible circuit between the switch and the board.....but make sure you disassemble it properly to avoid breaking the flex-circuit. It takes an experienced technician to check the flex-circuit connector with the board. There might be some broken path or circuit line going to the connector. Use jumper wire if its possible and don't forget to use multimeter to check for continuity of the circuit. (that's the same problem with my f380...all lights are on....and that's the same solution i did..and it works).
How to reset printer setting
Turn off the HP LaserJet 2840.
Press and hold down the "Enter" and "*" keys on the printer's control panel, and turn the printer back on.
Hold the "Enter" and "*" keys until you see the "Permanent Storage Init" message on the device control panel. Release the two keys to perform the NVRAM initialization. The NVRAM initialization takes just a few seconds, and the "Permanent Storage Init" message remains on the printer's display until the initialization is complete.
Ensure that the "Ready" message on the printer's control panel is visible. You can now connect the printer to your computer and print your documents. If the "Ready" message is not displayed and your printer is still stuck in a loop, turn off the printer and contact HP customer support (see Resources).
  • To reset an HP 2840 from your computer, open the HP Toolbox program, click "Device Settings," click "Service," click "Restore" in the Resets section and then click "OK" to confirm the action and restore the printer to its factory defaults.
Sep 26, 2013 | HP LaserJet 2840 Printer
Printer is stuck on initializing
to many reasons can do that
1- Formatter board
2- Firmware corrupted
if you would like gave more detail so can gave you the solution
Mar 21, 2013 | HP Office Equipment & Supplies
Initializing
NVRAM Initialization:
1. Turn the printer off.
2. Press and hold down CANCEL (X) and Start Copy (button just below the X button) buttons at the same time while powering on printer. *Keep these buttons press while you power on the printer*
3. Continue to hold down buttons until the printer display reads PERMANENT STORAGE INIT.
4. Release the buttons when "PERMANENT STORAGE INIT" is displayed. Printer will return to Ready automatically.
Dec 12, 2012 | HP Hewlett-Packard - LaserJet Pro M1217nfw...
Hp lj2420 errcode 68.2
The printer permanent storage is
full. Some settings might have
been reset to the factory defaults.
1. Press the SELECT ( ) button
to continue.
2. For 68 errors, turn the
printer off, and then turn the
printer on again.
3. If a 68 error persists,
initialize NVRAM. See the
caution and note in To
initialize NVRAM.
4. If this error message persists,
replace the formatter (see
Formatter).
Apr 04, 2011 | HP LaserJet 2420 Printer
Error 68.2 permanent storage write How do you fix the error?
all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem
Feb 16, 2011 | HP LaserJet P4014n Printer
HP 1280 PRINTER PROBLEM
Hi there there is this you can try it works with some
Step 1: Manual Temporary
1. Turn off the printer. And disconnect the printer cable.
2. Press and hold the POWER button, turn on the printer.
3. The indicator (L.E.D.) should be green.
4. Press and release the RESUME button , the indicator (L.E.D.) should be orange.
5. Press and release the RESUME button again, the indicator (L.E.D.) should be green.
6. Release both buttons.
step 2 : Software for Permanant
1. Reconnect the printer cable.
2.Open General Tools software and select (USB PORT2_bing.gif)
3.Choose (SET DESTINATION 1) And it should be reset.
Sofware Download "After service mode Pls use software for permanent reset
Please come back and just gave a vote, it will gave me some satisfaction to know am helping some one so I will keep on helping.
All The Best: Pineworks
Feb 10, 2010 | HP DeskJet 1280 InkJet Printer
Error 68.2 permanent storage write fail (Hp laserjet P4014n)68.2 permanent storage write fail. (for help press ?, to continue press ok) if i press ok it will print what ever job was sent but you have...
Hi! I will be glad to assist you in this issue.
Usually all you have to do is initialize hard disk even if you do not have one. Just turn off the printer. Turn the printer back on and when the memory starts to count hold down the menu key until all three lights come on. When all three lights are on solid release the menu button and press the arrow back button and initialize disk should appear in the menu. Just hit the check mark button again and it should take care of the problem.
here is the lin for additional solution:
http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
Oct 26, 2009 | HP LaserJet P4014n Printer
My hp laserjet P4014n is giving an error message 68.2 permanent storage write fail what can i do to clear this massage?
Here is the link just incase you need more solution:
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} http://h20000.www2.hp.com/bizsupport/TechSupport/Document.jsp?lang=en&cc=us&objectID=bpl12422&jumpid=reg_R1002_USEN#A46
HP LASERJET 3055 Manual IP Address not saving
Switch off the printer and press * & enter key together &switch on wait till you see " permanent storage int"
then release button your printer comes back to original defaults
then re-configure printer as you require
Murali,
PALLAVI INFOTECH
BANGALORE
Jul 16, 2008 | HP LaserJet 3055 All-In-One Printer
Dead printer?
I assume the transformer has 2 wires coming out of it. My guess is that the wire from the transformer is working however the wire leading from the Transformer to the printer is not.
You may need to purchase another power unit.
But on the bright side, a transformer is cheaper than a new printer.
Hope this helps.
Feb 15, 2008 | Computers & Internet
HP DeskJet F380 All-In-One Printer Logo
Ben Johnson
mukhtar21 shaikh
mukhtar21 shaikh
