Question about Car Audio & Video
V12 MRV-1507 or Xplod? Amplifier - XM-ZR1252 good quality sound
How to distinguish of 2 ampl. the good high power? and good quality sounds
V12 MRV-1507 Xplod™ Amplifier - XM-ZR1252
P3,500
Brand new V12 MRV-1507 (2008 improved version) *From 3600 watts it's now 3800 watts
Amplifier TypeDual Channel
Bass BoostWith Bass Boost
BridgableBridgable
Power Output
RMS Power at 4 Ohms225 W x 2
RMS Power at 2 Ohms450 W x 2
Performance
THD at Rated RMS Power0.08 %
Signal to Noise Ratio105 dB
Frequency Response10 Hz - 50000 Hz
High - Pass Frequency30 Hz - 200 Hz
Low - Pass Frequency30 Hz - 200 Hz
Dimensions
Depth20.88 in.
Height2.38 In.
Width10.19 in.
Other Features
MOSFET ampYes
Input Voltage11 volt
P 6,999.00 Amplifier
Power supply
MOSFET
Max power output at 4 ohms
2 Ch x 280W, 1 Ch x 800W
Max power output at 2 ohms
2 Ch x 400W
Rated power output at 4 ohms
2 Ch x 125W, 1 Ch x 340W
Rated power output at 2 ohms
2 Ch x 170W
Low pass filter (selectable)
Variable 50Hz-300Hz, -12dB/Oct
Signal to noise ratio
97dB
Frequency response
5Hz - 50kHz
Dimensions (WxHxD)
321 x 55 x 200mm
Weight
3kg
  • Anonymous Mar 20, 2014
    No powee,Power Output is 50-60 Hz 110-125 V
Alpine is just a better brand in general. I have the older MRV-1507, sounds GREAT, i have had friends who has had the Explode line, but it was always a temporary system until they got something better, like the alpine or kenwood.
Posted on Aug 16, 2008
I Have a Sony Xplod 800 watt amp and 2 12 inch Sony Xplod subs
You should definately bridge them. Firstly, lay the 2 speakers face down next to each other. Note the connections +- +-. The first + will go to the amplifier. The next terminal(-) will be connected to the next speaker(+). Take the last(-) and connect to amplifier. Please note that your amplifier has a bridge section which is normally the first + and the last- on the two channels. Connect your woofers on the bridge.
May 28, 2010 | Sony XM-ZR1252 Car Audio Amplifier
I purchase sony cdx-gt49um but very low bass & av. sound qulity what can i do to improve?
Nothing sony is a good name but when it comes to car audio they have nothing but their name. I had a thump amp from the 80's that worked better than my sony xplod that had more power. If you want better quality try rockford fosgate, clarion or kenwood
Mar 22, 2010 | Sony Xplod XM-554ZR Car Audio Amplifier
My SONY XM-ZR1252 fuse keeps blowing
hi
maybe you have defective mosfet power transistors thats why your fuse is blowing...
Thanks!
Apr 25, 2009 | Sony Xplod XM-554ZR Car Audio Amplifier
Kicker l7 dvc 2 ohm wired to sony xplod xm1652z amplifier isnt pushing the sub
it is not the way how get most wattage from your amp. If it is rated to drive a 4-ohm load then it should be ok for a 4-ohm load. If it is rated for a 2-ohm load, then you should not be loading less than that impedance. I recommend a 4-ohm load.
Take note: it is the sound quality from the source that makes up all the total quality of your audio system. If you are overdriving the amps it will give distortion too.
There are many factors to consider when it comes to quality of a car sound system- speaker enclosure design, choice of speaker or driver, equalization, etc...
One more thing, try to get at least no voltage drops if you are wiring the subwoofer amp away from the car's battery.
hope this helps.
Oct 17, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
MRV - 1507 Question ...
The MRV-1507 is a two channel amplifier, below I've pasted important info from the manual:
Battery Lead (Sold Separately)
Be sure to add a 80 amp fuse as close as possible
to the battery’s positive (+) terminal. This fuse will
protect your vehicle’s electrical system in case of a
short circuit. If you need to extend this lead, the wire
gauge should be AWG8 or larger.
MRV-1507 ... 80A amp fuse
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
You can find a manual for this amp here:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=mrv-1507
Jul 07, 2008 | Alpine MRV-1507 Car Audio Amplifier
Sub power hadling capacity
Yes. If the rated power is 380W and the Max power is 1000W then it will handle it. Subs fry when clipping occurs. Clipping is when the amplifier is pushed past its capabilities and the output to the sub gets "dirty". The better quality the amp, the safer it will be on your speakers. It is also important to remember that the gain control on the amplifier is NOT a volume control to boot the sound, it is only to match the output from the headunit to the input handling of the amp. Cranking the gain up too much WILL CAUSE CLIPPING.
Jan 04, 2008 | Sony Xplod XM-1652Z Car Audio Amplifier
V12 / xplod issues questions
sounds to me like you have a poor ground, which is causing the amp to overheat. make sure you have as large a gauge wire for the ground as you can and make sure it has a good connection to metal this should solve your problem.
Dec 19, 2007 | Alpine MRV-1507 Car Audio Amplifier
Car Audio & Video Logo
603 people viewed this question
Top Car Audio & Video Experts
xxxxxx xxx
Are you a Car Audio and Video Expert? Answer questions, earn points and help others
