Question about E-Machines eMachines Desktop PC
No start up , button lites up - cd-rom wont open , noticed no fans on for 3d card or big one on mother board
Push power button on - lites up. monoter wont start up , cd rom wont open, moniter no start up- tryed the original output " has 3d card, still no start. i did notice that the fan on the motherboard isnt turning on . I think the issue is in the power supply - i have another set up thats just like the one i have now accept for a 4 wire plug - 2 yellow and 2 black that runs to center of mother board.
    Novelist:
    Scholar:
  • 141 Answers
If the cpu/heatsink fan isn't turning then most pc's will shut down to avoid further damage to cpu & board. I would first replace the fan if it's the one over your cpu. Try replacing power supply. If your board has the 4 pin plug, you must have that plugged in. But keep in mind if that fan isn't running a new power supply isn't going to make it start working. You have to have that fan working. Then go from there. If once it is working & other devices like video and/or roms aren't, check your memory. The best way to troubleshoot devices are to plug one at a time in and power up until the problem starts. Hopefully you won't have to go to that step.
Posted on Aug 14, 2008
Gateway 450ROG, will not start. Red DVD/CD ROM
I have the very same problem, the Drive light turns red, the screen is "black" and the battery charging light indicator on the front is off. No differance if I'm traying to power up on battery or AC-adapter.
Before this problem appeared I had problems where the laptop was powering off, with no warning, and I had to restart it. This happened several times and was going on for about a week before it died totally. Can it be the CMOS battery on the mother board? Anyone having clue what the problem could be?
Mar 31, 2010 | Gateway 450ROG Notebook
Power problem?
My thought would be motherboard if the PSU has been tested. Prime candidate would be the capacitors.
If you take a look at the caps on the board, if any of them are bulging and/or leaking then we have a winner. Caps can be replaced but you do need some skill with a soldering iron!
Dec 15, 2009 | Gateway 310X PC Desktop
MOTHER BOARD NOT POWERING ON
I want you to try first swap the power supply box  of the PC if no change ?
go to the CPU socket remove the CPU check if any component is burnt that area if ok put a new CPU  then on it .
If still behaving the same ,then the mother board is bad get a new mother board
Good luck
Oct 01, 2009 | Foxconn P9657AA-8EKRS2H (6938279104065)...
No display, no cpu fan running, no any beep but led on mother board is on.I replace power supply but no result
Do the following to check motherboard.
1. Take out all cards from motherboard except video card. Unplug ribbons to CD-Roms, hard drives and floppy drives.
2. The only thing plugged into your motherboard should be video, keyboard and ram.
3. Check once again that all the power connectors from the power supply are properly plugged in. There may be two or three of them depending on the type of motherboard. Try turning on system. If you get no response then try next option.
4. Find the wire coming from your power on button and trace it to the motherboard. Pull the wire off and use a screwdrive to short between the two posts. If the power button is bad this should start the computer. If not your motherboard is probably toast.
Sep 30, 2009 | Intel D845GVSR Motherboard
Amber light on power button
Check to see if there are any loose connections to the memory cards on the memory board. Make sure the data cable to the drives are connected properly. Is the fan in the power supply on?
Jul 27, 2008 | Dell Dimension 8300 PC Desktop
Emachine desktop
I understand that your cpu is not turning on and the repairer confirmed that it is the issue with the mother board. I suggest you to please check the smps fan spinning or not. If its spinning then then the issue could be with the mother board. If not try changing the power cables.
Next check whether your cd rom light is glowing. Even if there is an issue with the mother board, as the power is supplied by the smps the light  should glow if the light is not glowing its clear that something must be wrong with smps.
Please provide us the result of the above steps so that I could assist you further.
Nov 08, 2007 | E-Machines eMachines Desktop PC
Help
My only sulutionis to buy a external sound card that has 2 sound ports on cd in aux in place the cd+rw on the cd aux in and have the dvd burner on cd in disable on board sound for the external sound card to have the IRQ setting of the on board sound card the best soundcard to go for is soundblaster live or any one in this range as you are going to play dvds on pc the best program for this is Powerdvd from Cyberlink
Aug 13, 2007 | Lite On LTR 52246S CD-RW Burner
E-Machines eMachines Desktop PC Logo
90 people viewed this question
Top E-Machines Computers & Internet Experts
Alun Cox
Are you an E-Machines Computer and Internet Expert? Answer questions, earn points and help others
