Question about Alpine MRV-1507 Car Audio Amplifier
Alpine MRV-1507 "low Voltage"
Alpine MRV-1507. Indicator LED indicates "Low Voltage". Worked fine, had it loud then stopped instantly. Light also indicates "RCA Ground Floated". How do i fix these problems. The battery is at 14.5 volts as indicated on the DIC in my Aurora. Thanks
  • royceman87 Aug 16, 2008
    *UPDATE* Installed this amplifier in my pals car, same wiring kit, same everything almost except different car. Worked fine, then back into my car it went, same thing over again the damn lights blink.
  • royceman87 Aug 17, 2008
    now if i get a new headunit would that be just as good? and what about the "low voltage" issue?
  • 631 Answers
If it indicates that you have an open shield ground, read through the following page. It will show you how to test the shield ground connection of your head unit..
Temporary RCA Shield Repair
Posted on Aug 17, 2008
COLEMAN INVERTER PMP1200 JUST BEEPS WHEN TURNED ON
It is most likely the low voltage alarm. Suggest connecting when the car is running with no load (110 volts not connected). If the alarm continues turn the unit off and on to reset.
Hope this helps?
Inverter Protection Features
• Short Circuit Protection. The inverter will automatically shut down until short is removed.
• Low Voltage Alarm. An alarm will sound when the voltage from the battery discharges to 10.5 +/- 0.5 volts DC. This is an indication that the battery needs to be recharged.
• Over Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input exceeds 16.5 +/- 1 volt DC.
• Under Voltage Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the input is less than 10.0 +/- 0.5 volts DC.
• Overload Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the continuous draw of the equipment being operated exceeds 1200 watts or the surge draw of the equipment exceeds 2400 watts.
• Thermal Protection. The RED LED Indicator Light will illuminate and the inverter will automatically turn itself off when the circuit temperature exceeds 150° F
Sep 13, 2016 | Electronics - Others
Amp
I honestly don't have a solid answer for you. I can say check your fuses. Check your battery to amp wire. And also check your ground. Make sure the fuse on your amp is also not blown
Feb 26, 2010 | Alpine MRV-1507 Car Audio Amplifier
Alpine mrv-f401
hi, there is a possibilty of the volume control being foulty pls get the volume control nobe changed . voltage does not interfere with control nobes
Jul 10, 2009 | Alpine MRV-T420 Car Audio Amplifier
How do i run it 2 ohm stable
This is how 2 type r's are wired to one amp at 2ohms hope this helps dont forget to rate me thanks
Upfront Audio :)
Apr 06, 2009 | Alpine MRV-1507 Car Audio Amplifier
Low Voltage Post
The head unit doesn't need to be replaced. It can be repaired if the shield is open.
If the amp still give an indication of low voltage and the voltage isn't too low, the amp probably has an internal fault.
Aug 17, 2008 | Alpine MRV-1507 Car Audio Amplifier
V12 MRV-1507 or Xplod? Amplifier - XM-ZR1252 good quality sound
Alpine is just a better brand in general. I have the older MRV-1507, sounds GREAT, i have had friends who has had the Explode line, but it was always a temporary system until they got something better, like the alpine or kenwood.
Aug 14, 2008 | Car Audio & Video
MRV - 1507 Question ...
The MRV-1507 is a two channel amplifier, below I've pasted important info from the manual:
Battery Lead (Sold Separately)
Be sure to add a 80 amp fuse as close as possible
to the battery’s positive (+) terminal. This fuse will
protect your vehicle’s electrical system in case of a
short circuit. If you need to extend this lead, the wire
gauge should be AWG8 or larger.
MRV-1507 ... 80A amp fuse
Power Output: RMS Continuous Power (at 12.0V, 20 Hz to 20
kHz)
MRV-1507
Per channel into 4 ohms ......................... 150W, 0.08% THD
Per channel into 2 ohms .......................... 300W, 0.3% THD
Bridged into 4 ohms ................................ 600W, 0.3% THD
You can find a manual for this amp here:
http://www.alpine-usa.com/US-en/support/support_search.php?modelname=mrv-1507
Jul 07, 2008 | Alpine MRV-1507 Car Audio Amplifier
Alpine mrv-1507
Your amp. got damaged the audio amplifiers IC's thats why it's going on protect mode.
Jun 05, 2008 | Alpine MRV-1507 Car Audio Amplifier
Alpine 1507
I would either try a bigger fuse, if possible, or turn the power output dial on the back of your amp down. This can be done with jus a simple flathead screwdriver. I suggestion would be to go out and buy a power monitoring cap. Wal-mart, or Tweeter usually distributes them. It'll have a LED reading on the top, with two wire hook-ups either on the bottom or the top for positive and negative, place this in between your amp and your subs in the wiring set-up.
Feb 25, 2008 | Alpine MRV-1507 Car Audio Amplifier
Car Audio & Video Logo
310 people viewed this question
Top Alpine Car Audio & Video Experts
xxxxxx xxx
hoyzee1
Tygh Duval
Tygh Duval
Are you an Alpine Car Audio and Video Expert? Answer questions, earn points and help others
