Question about Xerox DocuColor 12 Color Copier
Dc 12 print light no glazzing
  • siva36 Aug 18, 2008
    dear sir i am siva 36 when i connected to fery x12 turn print on message coming no test print
  • siva36 Aug 23, 2008
    my new problem is white page is comming for printer as test page and evry thing white zerox is comming colors
  • 79 Answers
Clen drum charge grit, ibt assay and 2nt btr unit...
Posted on Aug 18, 2008
  • jai kumar
    jai kumar Aug 19, 2008
    pls check and do defalt settings in ur fiery...i think u turned on start up page on ur fiery. just turn off that..
Too much power and now lorex camera wont turn on
CAMMERA DESTROYED !! MOTION LIGHTS USE 120 VOLT AC POWER
CAMERAS USE 12 VOLT DC POWER
WRONG TYPE AND AMOUNT OF POWER !!!
Jan 16, 2014 | Lorex Home Security
Why does my truck makes a loud squeaking sound when the wheel is turned max to the left or to the right?
sounds like your belts are worn /glazzed or loose. check your belts. if the have cracks everywhere, then replace them. if no cracks are seen, then adjust them/tighten them. if they are glazzed/very shiny on contact surfaces then you will need to replace them. but it sounds like your power steering belt is either loose or its time to replace it.
Jan 13, 2011 | 1995 Nissan Pickup
I HAVE CONNECTED EX 12 TO xEROX DC 12.It is taking more time for ripping the print job compared with x12.Do you have any suggestion to improve the same.
use fx model for ripping the print job. Its much faster. Alernatively if the computer can convert the print job in eps format and releasing the converted(in eps format) and them sent for ripping, the spooling will be quicker in the same ex 12 equipment being currently used by you.................sodeep
Jul 26, 2009 | Office Equipment & Supplies
Printing to a Xerox DC12/DCS50
you can't print via serial to it. You will have to check the settings in your rip to see what the ip address is. Lights will blink all the time to indicate it is on a network, its just not talking to it. Then you go into your add printers section click the + sign and it should come up in there if the ip address is in line with your mac ip
Dec 16, 2008 | Xerox DocuColor 12 Printer
High Contrast in Printing Photographs from DC-12
sir
u do one thing press 0+ start & go to max setup
trc adjustment press start u can get a3 print
next trc toner concentration start
ofter u can get some defference
Dec 11, 2008 | Xerox DocuColor 12 Printer
Xerox Docucolor 12 : Four colors ( CMYK) dots printed each time on paper on 3 separate area
Your Problem is the cartridge printer Mx, In spanish algun balero de las developers units esta dañado pudiera estar golpeando el cilindro de imagen
Nov 03, 2008 | Xerox DocuColor 12 Printer
Xerox docu color 12
u check drum,ibt belt,2nt btr roller and fuser life... then do full service, then calibrate ur fiery also.. first u check developer bios plate.. if its have more dust print comes like that.. all the best..
Aug 14, 2008 | Xerox DocuColor 12 Color Copier
Fiery cannot transfer the printing jobs to dc-12
have you tried replacing the cables maybe they are in a incorrect position wen you do this switch off the fiery and the machin.
Mar 25, 2008 | Xerox DocuColor 12 Printer
Top Margin print cut
If you are using the bypass (tray 5), you need to move the limit of your tray from the normal position to 12" position.
Hope this help.
Nov 29, 2007 | Xerox DocuColor 12 Printer
Xerox DocuColor 12 Color Copier Logo
85 people viewed this question
Top Xerox Office Equipment & Supplies Experts
Michel
Xeroxrep
Level 1 Expert
Philip Hughes
Are you a Xerox Office Equipment and Supply Expert? Answer questions, earn points and help others
