Question about Fuji Office Equipment & Supplies
Just replaced toner cartidge on fuji laser 203A, now the paper light keeps flashing even though paper is full. Of coourse wont print while this happening
  • idylbookcafe Aug 15, 2008
    I have just replaced the ink cartridge in my fuji 203a ink jet printer. Now the paper button keeps flashing and I am unable to use it. I am using exactly the same paper that I have been using for months. (Standard A4 copy paper) I have no doubt that this problem is caused by something I have done incorrectly but I have no idea what it is and would appreciate a better solution than the one I have just received. Many thanks
    checked paper feed, can't see any obstruction. Beginning to think maybe you guys are not my solution to this problem. could have called my 8 year old brother for these solutions.
    Master:
  • 521 Answers
In the tray where you place the paper there is a black or steel colour sensor which detects whether there is paper in the printer or not.that sensor is not in the perfect position or broken or quite possible loosened up.it is at the end of the tray where the paper reaches.just that tray problem.no need to open the printer you can just check from outside.rate the solution if helped or made you understand your problem.
thanks
Posted on Aug 15, 2008
  • 928 Answers
Try removing the cartridge and then putting it back on. After that turn off the printer for about a min then turn it back on. Try pressing the paper button as well when you have paper in the tray. Also if you have any print jobs on your computer purge them as well. If that still does not work. Take off the connection from the printer to the computer then turn it off then wait about 5 mins then turn it on. You want to make sure that there are no print jobs saved on the printer internal memory. Turning it off will purge that.
  • 69 Answers
Check the feed rollers make sure there is no blockage and that they are clean. Try taking the cartridge out and put it back in. If all else fails, try to find a reset button or pull the power cord for 15-20 minutes. Hope this helps!
    Champion:
  • 232 Answers
Check ur paper tray for obstruction or anything that could alter the sensor function
  • 120 Answers
Did u check whether cartidge is fixed properly
Posted on Aug 14, 2008
  • Aiswaria Sekar
    Aiswaria Sekar Aug 14, 2008
    Your printer isn’t always at fault. The wrong paper or the wrong
    printer-driver settings can also cause a bad print. You’ll usually get
    the best results—and encounter fewer problems—if you stick with your
    printer manufacturer’s inks and papers. But if you’re trying to be
    creative or save money by trying alternative media or third-party
    papers, the following tips should help.
    Your paper may be damp, or you may have loaded it with the wrong side
    facing up. Most papers have only one side designed for printing—usually
    the brighter or shinier side.
    If you loaded the paper correctly, try using a different
    paper setting. Your printer may be using too much ink for the selected
    paper. (Uncoated papers absorb more ink than coated, or glossy,
    papers.) In the printer driver, switch to a lower-quality setting, or
    turn off options that use more ink
  • Aiswaria Sekar
    Also please check your paper sensor.. it may have gone faulty..
My fuji xerox printer docuprint 203 A's drum lights/blinks when i turned on my printer to print. help.
Press the button until all the lights are on..then let go the button, this will reset your drum counter.
Feb 18, 2010 | Xerox DocuPrint 203A Laser Printer
My Fuji Xerox Printers DocuPrint 203 A got problem, after printing one paper, the LED turn to red and cannot print anymore.......i has check it but it's still the same problem. Can anyone help me to solve...
the drum or toner LED? if it's the drum, then just press the button until all the LED are ON then let go and this will reset the drum..
if it's toner, you need to take out the toner and on the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, re screw the whole cover and install back to the printer, this will reset your toner, make sure there is toner in the cart.
Feb 08, 2010 | Xerox DocuPrint 203A Laser Printer
Our Fuji Xerox 204a will not print, and continues to display the paper light, even though the tray is full. I have just changed the toner.
Go through your toner change procedure again, it could be that something is just not quite back in place correctly.
Feb 05, 2010 | Fuji Rod Repair Kit
Yellow light on Toner light on) Cannot print a thing
take out the toner.. at the left side of the toner, there is a level, unscrew the 3 screws and turn the level to the other side, this will reset your toner.
make sure the printer is on when you put back the toner.
Jan 18, 2010 | Xerox DocuPrint 203A Laser Printer
The red light is flashing on the printer. I cannot find any paper stuck in the printer.fuji xerox docuprint 203a
take out the drum unit and clean it, normally when the drum unit is dirty with toner, it will give you error.
Jan 17, 2010 | Xerox DocuPrint 203A Laser Printer
Hi guys!My fuji xerox 203a the toner indicator light upplease help!thanks!
refer my other posting on how to reset the toner.
left side of the toner cartrige, unscrew and turn the level other side.
Nov 15, 2009 | Xerox DocuPrint 203A Laser Printer
Toner is not out of ink but it lights up, refusing to print
In most cases cartridges have a special chip that remembers the toner cartridge serial number an amount of pages printed from it. This means, that even though there still might be some toner left in the cartridge, the chip's counter reaches it's predefined limit and informs printer, that the toner has run out. Just like that, suddenly.
It may also be the case, that the chip loses contact with the printer's electrical terminals - try reseating the cartridge in the printer. If that doesn't help, it's time to replace it I'm afraid.
Usually the printer will inform "toner low" for some time before it becomes "toner out" and refuses to print. If you get "toner low", then it's time to purchase a new cartridge to have it ready.
Oct 27, 2009 | Fujitsu Office Equipment & Supplies
Fuji xerox won't pick up paper for printing.
Managed to get it going ,pulled all the toner cartridge out and reset and all is sweet.....!
Aug 30, 2009 | Xerox DocuPrint 203A Laser Printer
88 people viewed this question
Top Fuji Office Equipment & Supplies Experts
billconfused
mukhtar21 shaikh
mukhtar21 shaikh
Dave Busselle
Level 1 Expert
Are you a Fuji Office Equipment and Supply Expert? Answer questions, earn points and help others
