How to use gamepads with pc games - Computers & Internet
    Novelist:
    Scholar:
  • 125 Answers
There are two types of gamepads you can connect to your computer. One is the game port on the sound card and the other is through USB port. Either way once you plug it into your computer you need to go to control panel and configure your device. Click on Switch to Classic View first if option is avaliable. Then double click on Game Controllers. Then you have two options, if a usb device has being detected then you will be able toclick on properties and configure the device. If not, you will have to click on add and select from a list of gamepads and select the one closets to your device. Then click on properties and configure the device. Follow on screen instructions.
Now once you have done the above you will also need to configure the controller gamepad in the game itself under options and under input devices/joysticks.
Good luck! Please rate after you are completed!
Posted on Aug 14, 2008
It doesnt work. the computer sees the gamepad, but the game it self not.
Have you gone into the game settings to make sure that the controls are set to gamepad?
Oct 24, 2013 | Trust 17735 GXT 30 Wireless Gamepad PC/PS3
I have a logitech gamepad gamepad that i want to
WW3 has begun.........
None the first and only.
Jun 20, 2010 | Logitech ChillStream Game Pad
Gamepad to usb adapters?
The adapter is out there. I happened upon one a while back, and got a nice joystick to work with it (win2k).
I can't seem to get my gamepad pro grip to work though. I think I may have bad controllers.
Jun 25, 2009 | Gravis GamePad Pro Game Pad
LOGITECH RUMBLEPAD2 ON VISTA PC
You can start from OPTIONS in the main menu of any game and then choose CONTROLS. There if you have both the options : keyboard/gamepad, then only you can use the gamepad.
Then if you have the Gamepad option there, then select it and configure/assign the gamepad keys for your game. You can do it by going onto an option; lets say ACTION and then click the Gamepad key you want to assign. Hold down that Gamepad key and double click the mouse. There you go.Your Gamepad is up and running for your game.
Cheers.
May 04, 2009 | Logitech Rumblepad 2 Game Pad
Spiderman WoS and Incredible Hulk (2008) don't respond to gamepad
its not problem with your gamepad. Its the problem with game both games. It has a bug problem. It cant install gamepad. dont try it again & again as it may damage the game pad internal configuration. pls rate for me .
Feb 05, 2009 | Logitech (9633260403) Game Pad
Gigaware controller on vista
You don't (and can't) disable DEP for the controller (a gamepad controller isn't an application, it's a device which uses a driver, Data Execution Protection applies to applications ie .exe files), it's the game or emulator you disable DEP for, so that you the game can run, completely free of security bindings, and then you would be able to go into the game configuration menu and select your gamepad, and calibrate it. Calibrating means the game detects you gamepad and applies the specific functions to each button.
One way to be sure is to disable DEP for everything, then install a game, and THEN plug in your gamepad. Then start the game/emulator and go to the configuration menu within the game/emulator and set up the gamepad calibration in there.
If it doesn't work, then you haven't installed the drivers for the gamepad properly, or haven't installed the correct driver.
Before doing any of that, you would have checked in Control Panel and Gamepad Controllers, double clicked the Gamepad in the list and pressed Calibrate, to enable generic gamepad functionality.
If you hadn't done that, do so now.
If it still doesn't work, then NOW disable the DEP (either all DEP or for the game/emulator you want to play). Unplug the Gamepad and load up a game. Then plug the game pad in. Set up the gamepad from within the game/emulator config menu, which differs from game to game, of course, but is more or less the same.
If it doesn't work.. re-install the correct driver for the gamepad.
Also make sure your operating system is fully updated and you're plugging the gamepad into a usb2.0 port. and have rebooted after installing the gamepad usb driver.
That's everything you need to know..
Good Luck!
Chris (ziraffa)
Dec 27, 2008 | Video Game Consoles & Games
Dekcell gamepad won't work for PC
return it and buy a gamepad that works (doesn't ****)
Nov 04, 2007 | DekCell (CPA-1040)
Driver
see if this is what you need - http://drivers.softpedia.com/get/JOYSTICK-GAMEPAD-WHEELS-and-TABLETS/OTHERS/Gravis-Gamepad-Pro-10.shtml
Sep 20, 2007 | Gravis GamePad Pro Game Pad
Computers & Internet Logo
154 people viewed this question
David Payne
David Payne
