Question about Samsung SCX-4216F All-In-One Laser Printer
Settings reset I like the printer quite well save for one problem: once a week or so, it resets all the settings to default. This is a problem because I use it as a fax machine, and it suddenly starts answering all the calls to that line. Also, it forgets the time and date, which is annoying. Anyone have any ideas? It's not losing power-- the computer next to it stays on just fine-- but perhaps replacing something like a bios battery would do the trick?
  • 161 Answers
Unfortunately, you are right. The BIOS batery is welded to the main board of the unit and it cannot be replaced. Therefore, any power outage makes it reset. Since your unit consumes 6.0 amps, try connecting it to an UPS battery backup 750VA or more. If you wish, I can quote you a new mainboard for replacement.
Posted on Aug 27, 2008
How to delete previous owner WiFi data and security code
Resetting the Printer to Factory Default
Settings
Resetting the printer to factory default settings can be useful when
you are troubleshooting with the printer.
CAUTION Resetting factory defaults clears the page buffer, removes downloaded
fonts and macros, and returns all print menu settings to factory defaults.
To reset the printer to factory default settings
1 Press MENU until RESETS MENU displays.
2 Press ITEM until RESTORE FACTORY SETTINGS displays.
3 Press SELECT until the following message appears:
RESTORING
FACTORY SETTINGS
This message displays until the printer has completed the
initialization
Mar 26, 2015 | HP LaserJet 4500 Printer
How do I factory reset a Lexmark x658de?
When you first enter the printer menus from the operator panel, you may notice an asterisk (*)
next to a value in the menus. This asterisk indicates the factory default setting. These settings
are the original printer settings. (Factory defaults may vary for different countries.)
When you select a new setting from the operator panel, the Saved message appears. When
the Saved message disappears, an asterisk appears next to the setting to identify it as the
current user default setting. These settings are active until new ones are stored or the factory
defaults are restored.
To restore the original printer factory default settings:
1 Make sure the printer is on and the Ready message appears.
2 Press Menu until you see Utilities Menu, and then press Select.
3 Press Menu until you see Factory Defaults, and then press Select.
4 Restore appears on the second line of the display.
5 Press Select.
The message Restoring Factory Defaults appears followed by the Ready
message.
When you select Restore:
No other button actions are available on the operator panel while Restoring
Factory Defaults appears.....
May 01, 2014 | Lexmark X658DE All-In-One Laser Printer
Reset printer
Please print printer settings configuration page. The page will explain the printer menus and change values. Menus are represented by Continue, Ready/Data, Toner Low and Load/Remove Paper light sequences. Menu Items and their values are indicated by Paper Jam and Error Light sequences
Here are the instructions to do that:
1. Turn off the printer.
2. Open the front access cover
3. Press and hold the red Stop button while powering up the printer.
4. The lights should cycle, release it when the light stops cycling.
5. Close the cover once the ! light displays
6. The lights should cycle again.
7. Then press the Continue button.
8. This should print a Printer Diagnostics page.
9. On the Printer diagnostic page, Use the Utilities menu to troubleshoot printer problems
- Return the printer settings to factory default values.
- Sometimes resetting the printer to the original settings solves formatting problems.
- All menu items are reset to the factory default values except:
- All settings in the Parallel menu, Network menu, and USB menu.
- All downloaded resources (fonts, macros, and symbol sets) in printer memory (RAM) are deleted.
- Resources in flash memory are unaffected.
10. Please locate the value that would say "Factory Defaults".
11. We would need to follow the exact light sequence that you see for the "Factory Defaults".
12. Press and release the Cancel button to advance through the menus and the menu items to the one we would need.
13. Press and hold the Continue button until all the lights cycle to save the function/value.
14. Restart the printer.
Jun 16, 2011 | Lexmark E260dn Laser Printer
Have HP Photosmart C5280 installed and have been using it for several year. For some reason now will not talk to computer, have checked all connections - what else can I check. Computer and printer have...
Please perform this reset
A semi-full reset will do the following:
The user settings to the factory defaults, Language and country settings on some models.
Reset the All-in-One to the factory default settings by using these instructions:
1. Unplug the power cable from printer when the printer is powered on.
2. Press and hold OK and HELP buttons while plugging in the power cord.
Sep 19, 2010 | Office Equipment & Supplies
Printer will only print one copy when when multiple copy number is entered. HP Laserjet 4200 printer
The best way I have found to remedy this type of issue is to reset the printer to factory settings. Push the check mark button (green) and scroll down to the resets and restore to factory settings. This will reset everything and you can start over. Also on the computer you are printing from there are default settings under the printing preferences that should be set to default printer settings. You can try one or the other but I usually do both because it saves time in the long run.
Mar 10, 2010 | HP LaserJet 4200 Printer
I want to reset my Epson PictureMate personal photo lab printer tofactory defaults. I found this once and can not find solution now. Needto have it in order to use because it keeps loosing the settings and...
From EPSON FAQ
Q: Does PictureMate have a factory reset button?
A: Yes, you can reset the print settings to their original, default values. Press and hold down the Cancel button for 3 seconds. When the message to reset the printer to default settings appears, press OK to reset the print settings.
Note: This reset does not affect LCD contrast, Print Confirmation, or PictureMate Print Wizard settings.
Jul 27, 2009 | Office Equipment & Supplies
Dimly label
Hi Cvetan, could you reset the printer to it's default settings. To do this you need to access the Menu, once you have accessed the menu you need to exit it. You will be presented with Save Permanent, cycle around until you find Load Defaults and press exit, it should say loading defaults. restart the printer and see how it goes. If the print quality is too light, change the settings in the driver under Head settings. Once you send the print you printer will pickup the new settings.
I hope this helps
Jul 03, 2009 | Zebra Z4M Printer
Want to reset my Zebra 140XiIII back to factory settings?
I resolved the problem by going into the setup program and then exiting and at that point I was prompted to save my changes and one of the options was to load Default settings. Once I chose this I was able to print on the 4X6 labels correctly, before that the configuration was feeding a label and 1/2 and print across two labels.
May 04, 2009 | Zebra 140XiIII Plus Thermal Label Printer
Reseting the default settings
set printer to black and white, press utility, user settings, save and select current settings then press set, should work
Sep 10, 2008 | Konica Minolta bizhub C450P Laser Printer
Lexmark t420 all leds are on
What this light sequence means:
• The printer is processing a request to cancel the current print
job.
• The printer is resetting to the user default settings. Any active
print jobs are canceled. A user default setting is one you select
and save which is different from the factory default setting. A
user default setting remains in effect until you make another
selection and apply it or until you restore factory default settings.
What you can do:
Wait for the message to clear. It clears when the printer finishes
processing the cancellation request or when it resets to the user
default settings.
Oct 24, 2007 | Brother HL 1430 Laser Printer
Samsung SCX-4216F All-In-One Laser Printer Logo
276 people viewed this question
Top Samsung Office Equipment & Supplies Experts
mukhtar21 shaikh
mukhtar21 shaikh
HEMANT GROVER
Victorman
Victorman
Are you a Samsung Office Equipment and Supply Expert? Answer questions, earn points and help others
