Question about Sharp Televison & Video
Tv Repair What for IC XO 250 is used
Take of in a second
Posted on Aug 14, 2008
Need to know which optocoupler ic is used in str 6267 based power supply in sony trintron crt tv
Sony FD Trinitron WEGA... Repair Questions - Fixya
www.fixya.com/.../p228979-sony_fd_trinitron_wega_kv_36fv310_36_t...
Hello, i have a sony FD Trinitron WEGA #KV-36FV310 ... Need to know whichoptocoupler ic is used in str 6267 based power supply in sony trintron crt tv.
Sony KV-TG21M61 21" TV Repair Questions,... - Fixya
www.fixya.com > Forum > Standard (CRT) Televisions > Sony
Need to know which optocoupler ic is used in str 6267 based power supply in ... My sony crt Tv totally dead when touch any components and the IC strs6307 ...
Tv code hi i'm looking for a 3 diget programming code for my ...
Dec 21, 2015 | Sony Televison & Video
Tv goes off by itself every few minutes
You have bad solder grounds in your TV. There will also be some bad capacitors. Look for capacitors in the range of 160 volts to 250 volts at 1Mf to 2.2, 3.3, or 4.7Mfs that are bad now. Another common capacitor that goes down are the 25 volt or 35 volt 100Mf ones. The next area would be your vertical IC , it will need resoldered. This is true any most cases of any brand. The capacitors next to the vertical IC will need checked and replaced. A bad cap here will heat the vertical IC and separate the pins from the board. Last and be sure to do this. Check the small board connected to the picture tube. By now this board (CRT) will have many bad grounds. Heat is the enemy of any television. Hope I could clue you in to a repair. Thanks for asking and show a few hands of support!
Mar 20, 2011 | Toshiba 32AF45 32" TV
There is a yellowish tint in one corner of the picture. What is the problem?
the problem u have is the convegence ic , try to do auto focus , if this dont work , u need to replace the convergence ic , stk392-560 - or 392-040 , but i would recoment to hire a tv tech because to replace this part u have to take everything apart and this wires are not mark , normal repair on this unit is about $250 - 300
Dec 01, 2010 | Sony KP-46WT510 46" Rear Projection HDTV
The manual converge is all unaligned and I can't get it back together and now I can't watch tv without seeing all colors
need to repair the comvergence ic , and maybe replace 2 resistor , this repair is about $250 , i would recomend u to hire a tv tech for this job , because after they replace the ic they may has to do some aligments
Aug 26, 2010 | Philips 51PW9303 51" Rear Projection...
My tv picture seems ok, but there is blue, arching streaks running horizontally, and a blue outline around words on screen. What is wrong with my tv? Please help.
u have a bad convergence ic , if u have same soldering skill u can do this repair , but i would recoment u to hire a tv tech normal repair is about $250
Aug 26, 2010 | Sony KP-57WS500 57" Rear Projection...
Our tv has blue and yellow ghosting what can we do
u have convergence ic ploblem , this job $250 to repair
Apr 16, 2010 | Hitachi 46F500 46" Rear Projection...
Horizontal/vertical hold is off, picture is moving fom left to right Mitsubishi big screen vs-60607
You better take this fellow to a doctor. You have a stamp size IC with about 250 pins that is bad. Only a tech can replace this or reinstall a remanufactured board into this TV. You may ask the tech to use a freeze spray to find this IC first and then he wil decide how to operate!l
Jan 24, 2010 | Mitsubishi VS-60607 TV
Is there an adaptor to receive the digital tv signals on the xo vision xt-7000? Once the tv channels changed to digital I don't have a reception with the xo vision tuner
the analog to digital converters are for home based TV systems not mobile, you can try contacting the maker of the unit and seeing if they have a solution for you
Aug 14, 2009 | XO Vision XT-7000 Car Video Player
Hello my tv power comes on but nothing else
250 is actually really cheap to get the tv fixed...the ic board and all that have to be checked by a pro and the transformer also has to be cheked by a pro unless you know how to work on tvs id send it for repair...
Jan 21, 2009 | Hitachi 53UDX10B 53" Rear Projection...
Color
It needs repaired. I can think of many different possibilities causing the problem: 1. Shorted video luminance driver transistor. Should be under $200 total repair if you take set in. 2. Shorted green kine bias transistor. $200 3. Failed jungle ic. $250 4. Shorted green gun in the picture tube. More than you paid for tv set... Rca picture tubes commonly run 25% more than the tv set did new!!!!!!!
Nov 27, 2005 | RCA F27625 27" TV
Televison & Video Logo
15 people viewed this question
Top Sharp Televison & Video Experts
Jaime Hernandez
Are you a Sharp Televison and Video Expert? Answer questions, earn points and help others
