Question about ASUS Intel 850 Chipset P4T-E (P4T-E/WOA) Motherboard
Power shutting down
After finished my work normaly I shutting down my system every day but when I came back for continue work suddenly it is rebooting how I can fix my problem please I am seeking from you good solution
  • 69 Answers
Check your power-save settings they could be turning the computer off. it could also be a bad chipset that is getting shorted or a bad fan that is causing the pc to overheat and turn off. hope this helps.
Posted on Aug 14, 2008
SOURCE:
Gateway MT6840 unexpectedly shut down and wouldn't
First - re-seat the hard disk and reboot the computer. If the computer does not boot up then reboot and go into the BIOS configuration to see if the BIOS detects the hard drive. If it doesn't detect the hard drive then it could be faulty.
Then the hard drive needs to be replaced in the computer/laptop, Windows installed and the computer or laptop's device drivers plus your programs etc. to get a functioning computer/laptop again.
Feb 12, 2013 | Computers & Internet
Caps lock Flashing when trying to boot the system
Take the laptop back, this sounds like a motherboard issue or improper factory install.
Apr 30, 2012 | HP Compaq Presario CQ57-229WM Notebook PC
No power on will shutdown
Hello
First of all press ALT+CTRL+DEL and start Task Manager, there is probably some application (or other process) that is not reponding. You can kill them to let the shutdown continue, and know what is causing the problem and maybe find an update for it.
Also this means that your computer has not been rebooted properly since the installation of important system updates. If you have "Automatic Updates" scheduled on your machine, these updates could have downloaded and installed without your knowledge. To fix this issue, let the updates finish installing, reboot and then shut down your computer as normal.
Click "Start."
Click "Windows Update." Click "Install Updates" to begin the installation of any updates that have been downloaded to your Compaq Presario. When the "Restart Now" button becomes available, click it once. Your Compaq Presario will shut down Windows, finish installing the updates and then reboot your computer.
Click "Shut Down." Because the updates have finished installing and have been installed properly, your Compaq Presario will now shut down normally and will not immediately boot back up.
Feb 17, 2011 | Compaq Presario 700 470024-192 Notebook
HP had blue screen and said it would shut down. Problem is that it does turn off, so that it can be re-booted. Have tried to shut off PC, but continues to come on and not start.
Hold the power button in for 10 to 15 seconds for hard shut down if that doesn't work unplug power for about 5 minutes then plug power back in and see what happens
Jan 06, 2011 | HP Pavilion a1000n (PS567AA) PC Desktop
Conputer is shutting down but it does not shut down
Hold the power button until the computer shuts down.
Restart and press F8 key repeatedly until you get a start up menu.
Select safe mode from the menu.
After the computer boots up, and you are at the desktop, go to my computer and select properties of the C drive (your system drive). Select tools from the tabs, then defrag. When defrag finishes, select check drive for errors and select the box, to automatically fix errors, and then ok, and yes at next window, allowing the computer to schedule the error check at next boot.
Reboot and allow computer to scan the drive.
After it finishes, you will continue into windows. Allow windows to boot. After it finishes, attempt to shut down again.
If it works, you fixed it. If not, you have a driver or program that will not quit, and you will have to research further to find out what is running and why it won't quit.
Dec 16, 2010 | Acer Aspire 5735 Notebook
It Says "Installing Updates" but never shuts down
If you are updating windows xp and it says installing updates when you are shutting down your computer, you should let it finish, even if it tales overnight. depenind on how many updates you have, better to go to the updates web site and do it from there. after they have installed then you should be able to do a restart on your computer and compleate. Any thing ells you are best off contacting MicroSoft
Aug 17, 2009 | Microsoft Windows XP Home Edition English...
Iam using lennovo y410 series.my lapton suddenly making some beep sound continuously on running and its not getting turned off. i removed battery and shutted down,i have been running laptop continuously ...
1 short beep
Normal POST - system is ok 2 short beeps POST Error - error code shown on screen No beep Power supply or system board problem Continuous beep Power supply, system board, or keyboard problem Repeating short beeps Power supply or system board problem 1 long, 1 short beep System board problem 1 long, 2 short beeps Display adapter problem (MDA, CGA) 1 long, 3 short beeps Enhanced Graphics Adapter (EGA) 3 long beeps 3270 keyboard card
Feb 22, 2009 | Lenovo 3000 Y410 Notebook
Hi suddenly my sound is not working in my newly bought laptop model is compaq presario cq 40 newly bought
Try this:
Shut down the laptop, disconnect anything plugged into it, remove the battery and hold down the power switch for 15 seconds (with no power or anything attached to laptop).
Reconnect A/C power and power it back up. See if that works for you.
If not, when you get booted into Window, go to Start > Programs > Accessories > System Tools and click on System Restore.
Follow the prompts and choose a bold date back to a time prior to when you lost sound. When it reboots, you will probably have sound.
Let me know if you need further help.
Honest1abe
Jan 10, 2009 | Computers & Internet
Power of
This happens because your CPU is overheating, open your PC and blow any dust off the openings and CPU/Power supply fans, if you think one of the fans is not working... replace it.
Jan 24, 2008 | Computers & Internet
ASUS Intel 850 Chipset P4T-E (P4T-E/WOA) Motherboard Logo
65 people viewed this question
Top ASUS Computers & Internet Experts
Ekse
Alun Cox
Are you an ASUS Computer and Internet Expert? Answer questions, earn points and help others
