Question about Christie LX45 Multimedia Projector
Christie Roadrunner 100
I turned on the Christie RR100 and it comes on for about 5 min. then the lamp warning light comes on. It will then turn off including the fan.
Could it be a bad fan?
  • 2,237 Answers
Check to see if the fans are moving. if not, replace the fans. if the fans don't come up, the projector shuts down to protect the circuitry and the lamp. if the fans are fine, most likely the power supply/ballast is not producing enough power to keep the lamp lit and shuts down.
Posted on Feb 04, 2010
Christie LX32 Lamp
1,Check the fans ,whether the fan is running,when you turn on the projector
2,if the fans run, then ,check the lamp or lamp ballast
Have a good day!
We supply original projector parts: lamp, bulb, Lcd panel, Lens, DMD chip, color wheel,
motherboard, powersupply ... with high quality and competitive price.
Jerry Lampdeng Limited
Mar 09, 2014 | Christie LX32 Lamp
I need a main PC board for my Christie RoadRunner 10k Projector!
Christie RoadRunner 10k ,Mainboard
Have a good day!
Nov 01, 2013 | Christie Office Equipment & Supplies
Hi, I have a Christie RoadRunner L6 Projector. When I turn it on the lamp light turns red and it does nothing. This unit does have dual lamps and a lamp replacement lamp light as well. I figured if it was...
I have a Christie RoadRunner L8 that fires up,lamps turn on and about 5 seconds after the lamps fire up it shuts down and both the warning temp. and ready lights flash at the same time. It seems to me it must be a sensor that tells it to shut down thinking that the machine is too hot-all the fans work and all of the filters are clean and it is moving serious air any clue and if so where do I start to look for such items? Thanks in advance Kirk
Aug 16, 2010 | Christie RoadRunner L8 Multimedia...
Turn on the roadrunner L6 the preparation display
This is an indication that either the lamp is bad or the ballast is bad. I would try a new lamp first. Also, there are air flow sensors in the lamp area that should be cleaned. If you have access to compresed nitrogen, try blowing out the entire unit to remove all dust and debris. Check to be sure that the fans are turning freely as well.
Please keep us posted.
Mar 03, 2010 | Christie RoadRunner L6 Multimedia...
Christie error message "Lamp Interlock Fault"
the switch itself may be broken. check continuity.
May 14, 2009 | Christie Roadster X9 Multimedia Projector
Check that you replaced the lamp in the right way, and also that the unit is well reassembled, you may also need to reset lamp counter from menu on some model.
Mar 07, 2009 | Dell 2300MP Multimedia Projector
Christie DS+60 projector turns off spontaneously
Here is a list of error codes for your unit:
12 Software bug. Contact dealer/factory.
13 Flash memory corrupted. Download new software.
14 Engineering only programming is complete. Call Christie, replace TIPM.
15 Attempting to download code without being in boot mode
16 Invalid interrupt. Power off/on. If it persists, contact dealer/factory.
17 Forced boot mode. Keys held down too long.
18 Attempting to program boot mode without jumper
21 Lamp compartment too hot
25 Lamp 1 not installed
26 Lamp 1 Interlock: door open, lamp not installed
27 Unable to turn lamp 1 ON
28 Lamp 1 shut off unexpectedly
29 Lamp 1 driver overheated
2A Lamp 1 driver operation error (e.g. too hot can’t start)
2C Lamp 1 driver UART communications failure
30 Lamp 2 not installed
31 Lamp 2 door open
32 Unable to turn lamp 2 ON (unknown reason)
33 Lamp 2 shut off unexpectedly
34 Lamp 2 driver overheated
35 Lamp 2 driver reports operation error (e.g. too hot can’t start)
36 Lamp 2 driver UART communications failure
37 Lamp Watchdog Tripped – Unless lamps turn on again after 3 minutes, assume software hung.
Jan 16, 2009 | Christie DS+60 Multimedia Projector
A couple of things...
If the fan is not working, the lamp will not fire. If you have the owner's manual, it should indicate what the flashing lights mean. Check to make sure that the panels are seated properly. When you replaced the lamp, the outer cover was removed. If that is not seated back 100%, the unit will not work. There are a number of safety "checks" built into the unit to prevent damage and possibly fire as the lamps get really hot.
Check the items above and let us know your progress.
Jun 19, 2008 | Dell 2300MP Multimedia Projector
Christie LX45 Multimedia Projector Logo
303 people viewed this question
Top Christie Office Equipment & Supplies Experts
Lawrence Oravetz
Are you a Christie Office Equipment and Supply Expert? Answer questions, earn points and help others
