Question about RCA F25422 25" TV
Problem with the volume
when i turn on my tv set the volume on my set is either off or full volume there is no in between. volume slide bar in any other position other than the lowest is still in full volume
picture is fine but volume is not
i dont want to buy a new tv please help
anyone have any idea what the issue is and how to fix it?
  • candie819 Aug 15, 2008
    the sound bar stays in the position its in but the volume gets higher and higher until i mute it then it goes back to no sound. When i take it off mute it goes back to full until i turn the tv off and on and it start over from no sound to full in about 10 or 15 minutes.
  • ElectroTechB Dec 18, 2008
    No audio. a friend of mine told me that it is the is "LA7612N" This is the audio IC for this TV
  • 1,011 Answers
What about sound bar in the tv that shows how much is vol.
is it remain normal or go at full ..
check if it remains normal then its another problem
if it goes also full then it might be software problem
Posted on Aug 14, 2008
How do i set up a new remote control for a samsung ht ws1 sound bar
2-Function Remote Stopped Controlling my Sound Bar - Verizon Forums
Apr 6, 2013 - It won't even control volume through the TV (Samsung). ... Did theremote ever turn on the sound bar, or have you been controlling ... Does the sound bar or TV have sound (sound but not volume control)? ... NO, UNFORTUNATELY THE FIOS REMOTE NEVER POWERED ON/OFF THE SOUNDBAR - I HAD ...
Your remote reprogramming woes solved - Rogers RedBoard
Rogers CommunicationsJun 18, 2014 - Once the TV turns off, press the SETUP button once to lock the code.... the Rogers remote to turn TV on/off but can't get the remote to control volume. ...New Samsung smart TV and I have entered all the proper codes but the ..... Doesanyone have a code for volume control of Samsung Soundbar HW-J250.
Wireless Genie remote Doesn't turn on/off the soundbar - AT&T ..
Jan 08, 2016 | Samsung HT-WS1 Speaker System
My Samsung Galaxy Prevail 2 has no sound. It was working fine, now there is no sound at all. How do I did this problem?
I had a similar problem with my Samsung S3 after a software update. I had to open up my volume settings and even though the slider bars indicated that the volume was at full I slid my finger across as if to turn it up to full. For some reason the slide indicators were wrong and this fixed my issue. I hope that helps.
Apr 23, 2015 | Samsung Cell Phones
Suddenly my yamaha Rx-v2300 only works to provide sound at nearly full volume to get any sound at all. This then comes with a background buzz. This only occurs while getting cable TV signal, using other...
I'm assuming you have a cable converter box (set-top box) that you have hooked to your receiver. Check the box volume using the cable company's remote control. These boxes frequently have variable audio output, and if you turn the volume down on the box you'll have the symptom you're describing. When you press the volume up or down buttons on the remote, you'll usually see a volume bar on the TV screen. As you raise the volume, there may be a point marked by an arrow, which is where you should set the volume. On some boxes, when you get to a certain level the words "best stereo" appear, and that's where to set it. If your box doesn't have some indication like this just leave the volume set 3/4 or full up. Then the volume on the receiver should function properly with the cable TV input.
Jan 12, 2011 | Audio Players & Recorders
Sound is low how do i turn it up
First of all, if you have volume controls on the keypad, please make sure you turn the volume up from that location.
Next, locate the Speaker icon next to the time in the lower right corner of the screen. Double or single Click on that and make sure the volume slide bar is all the way to the top. If you right click, you may be able to select volume mixer or something similar, there you will find multiple volume settings, turn all up.
Finally, if you are having this problem when using a media player (Windows Media Player, VLC, Quicktime, etc), there will be a separate volume control within the player itself. They are usually a slide bar underneath the video or graphics display. Turn this up also.
Please note that Laptop speakers are notoriously of poorer quality and lack the wattage of desktop speakers. In turn, it may not be a problem with your laptop. You may need to look into purchasing an inexpensive set of external speakers.
Feb 25, 2010 | Dell Inspiron 2200 Notebook
No control either by remote or manual.
Unplug your tv for at LEAST 4 hours. By doing this you are doing what we call a "master reset", the processor and memory inside are reset.
Let me know what has changed so I can further assist you from there.
Jan 17, 2009 | Insignia IS-LCDTV32 32 in. Television
Volume up then pic gone
Good Day;
The TV's front panel may be bad, manual buttons. TEMPT FIX; remove speaker, cloth covered, cover, disconnect cables. TV will work but only with remote.
Good Luck!
Jun 12, 2008 | Mitsubishi WD-52525 52" Rear Projection...
"snow" screen, full volume, remotes don"t work
good day
due to the long time the buttons were not used, they tend to get stuck and this causes channels eighter to stay in one station or continou scanning. it could be resolved by spraying WD40 on the buttons and press it many times then dry it before operating the unit.
Mar 25, 2008 | Sony FD Trinitron WEGA KV-34HS420 34" TV
Volume goes up on its own and stays up.
Aren you sure that the volume up button is not stuck in . It should feel just like the rest of them A little click? It could still be shorted,or the capacitor across the switch could be defective. If all this seems good then the eeprom, or the microprocessor,or the line or trace going to the volum button could be shorted. This is not a repair you should attempt unless your a tech. Now the button thong can be looked at after the set is unpluged and the back is off, gently slide out the chassis toward the rear of the set just a little and slide it back to see if the button is released. if that dosent help then you will need to take the set to The repair center. Good Luck
Jun 10, 2006 | RCA F31672ET TV
RCA F25422 25" TV Logo
191 people viewed this question
Top RCA Televison & Video Experts
matt martin
matt martin
Are you a RCA Televison and Video Expert? Answer questions, earn points and help others
