Unable to connect sanyo projector to sony laptop error is no signal Thanks in advance shaik
You need to use the Fn key on your computer to change the signal so your monitor signal projects through the projector.
On my computer I use the Fn key and F4 and it will then send the signal through the computer to the projector.
Posted on Aug 14, 2008
Does the Sanyo multimedia prox-III hook to direct tv
Sanyo connect directv Multimedia Projectors Questions ...
www.fixya.com > Forum > Tags > connect directv > Multimedia Projectors
Sanyo multimedia projectors connect directv related questions and answers. ... 3Answers ... configuration hey...i have a sanyo PLC-SU30 PRO-X MULTIVERSEPROJECTOR and i can't connect it to my laptop,i have connected the cable and ...
Sanyo Pro-X multiverse projector - YouTube
? 1:46
https://www.youtube.com/watch?v=awwXqdPRkNw
Feb 27, 2013 - Uploaded by WeeePC
Sanyo Pro-X multiverse projector start up. ... It was Sanyo at first sight!! ... 3:49. How we setup our LCD projector to reflect onto the kitchen table ...Missing: directv
db:: 5.32::MBP and Sanyo Z2 Projector 19
www.hivmr.com/db/199a98kjjjjz33k9kzk9p8kdfc1cdfjs
i have a hp g60 laptop and want to connect it to a sanyo pro-x projector, but i cant find it on the ... problem: I have a Macbook Pro 2009 running 10.6.3 and an Epson Projector.... You should hook up your projector to the DVI or the VGA. ..... I just bought a Sanyo Multimedia Projector (PLC-XU25A) and I can't get the projector ...
Jan 20, 2016 | Sanyo Office Equipment & Supplies
I follow the set up proceedure to connect the projector to my acer laptop. I then switch on power to the projector and boot the laptop. After the 30 second count-down I et a no signal message which stays...
Not wishing to show Grandmother how to **** eggs, but there are three VGA sockets. One of them is VGA out.
Can you select the inputs on the menu system?
Hope that helps.
Feb 23, 2011 | Sanyo PLC XU30 Multimedia Projector
Unable to play live tv from lap top to projector
Is it just the live tv or the laptop in general you are not getting a signal from? Using 15 pin VGA cable correct from laptop to projector?
When booted to projector, on laptop, select "FN" key and either F5, F7 or F8 depending on your laptop. Look for the monitor logo on the F keys. This is telling the computer that you have hooked up an additional external monitor (the projector). Once will send image to projector, twice will display on both, a third time will return to just image on laptop.
Jun 17, 2010 | Sanyo PLC-XU51 Multimedia Projector
Can you connect a Mac ProBook laptop to a ProxTrax Multiverse?
Hello. There is no "device" needed to connect the units together...You'll need a cable that is"mini display port to vga". In order to connect the projector to the laptop, the cable has to have the special Apple connector which fits into a specific socket on the back of the laptop. The other end is just a standard vga connector which is plugged into the computer input on the projector. Hope I helped you!
Aug 20, 2009 | Sanyo PLC XU35 Multimedia Projector
Macbook compatibilty with Sanyo PLC-XU32 projector
Force the frequency on the mac to 60hz. The projector can't respond to the high clock rate of the mac. Contact sanyo for a firmware upgrade to this product as well
Jan 27, 2009 | Sanyo PLC XU32 Multimedia Projector
Pc setting for sony bravia
'Unsupported Signal' Error indicates that TV is accepting the signals for Video but not able to display because resolution doesn't matches. Else the message would be 'No Signal'.
Follow the steps-
NOTE- Make sure cable is 15 pin(at both ends) VGA cable, working fine between PC & Monitor.
1.The standard resolution of laptop(any) which would support is 1024*768.
2. Toggle the display output from Laptop Fn Keys depending on Laptop Brand.
3. Connect the cable after settings made.
Also PC Settings will not be highlighted until connection is made.
Jan 20, 2009 | Sony BRAVIA XBR KDL-V26XBR1 26 in. LCD...
Using a Sanyo PLC WXU30 Multiverse Projector
should be able to download manual online, you cant just use a flash drive must be connected to laptop via vga cable, also I am not too sure about the mac, as i use a cheaper type laptop, but the display must be set for dual.
on windows this is done by right click, properties, advanced menu
Dec 16, 2008 | Sanyo PLC-WXU30 Projector
Power Point Presentation Using Sanyo Pro Xtra X Multiverse Projector
Don't forget to select the Fn key and F4 on HP laptops. It could also be the Fn key and F8 depending on the laptop brand. It is the apple key and the F7 key on a Mac notebook. On Laptops this will toggle the video to the aux port where the monitor cable connects to the projector. There are 3 modes. video on the laptop screen, video on the laptop and projector, or video to the projector only.
Master Rod
Mar 11, 2008 | Sanyo PLC XU35 Multimedia Projector
Sanyo Projector==No signal
Hi, Perhaps you can try lowering the screen resolution first of the laptop before plugging in the projector and then the Fn + F8. Thereafter, gradually increase the screen resolution until projector stops displaying. The idea is that your current screen resolution maybe too much for the projector to handle. This of course is assuming that there is no hardware problem with the projector. Hope this be of some help/idea. Post back how things turn up or should you need further information. Good luck and kind regards.
Sep 10, 2007 | NEC MultiSync GT1150 Multimedia Projector
1,207 people viewed this question
jasbo
jasbo
