Question about Hitachi 43UWX10B 43" Rear Projection Television
Blackout screens I recently upgraded to U-verse AT&T and I am getting blackout screens for a few seconds at a time primarily when there are explosion, high action or adds. I have had the TV for about 5 years I already fixed the convergence about 2 years ago, and other than the convergence - I have had no problems with the unit. I had standard definition cable TV and a Humax STB getting 1080i OTA for all this time (at least since the convergence fix) with no issues. However, since U-verse (2 months ago) I continually get blackout screens. AT&T is convinced that it is the TV. When i change th setting to standard Definition i have no isses - only at HiDef. the AT&T box is connected via component. I learned on the Internet that there was a different Hitachi model that had similar issues with progressive DVD playbacks - but could not find absolutely no information on my model with my specific issue. Help? Thank you! Chester Wojna
  • 2 more comments
  • mcchico Sep 06, 2008
    I got my problem solved. It was actually the TV. I called the Hitachi Rep in my area and asked them if they had a service bulletin issued for my specific symptoms and they said YES. So the Tech came and just changed the Horizontal POS from "0" to "1" and now everything works perfect - $95 dollars later.
    Thank you all!, Chester
    -Chico
    I actually had it fixed and it was actually the TV. I called the service REP in my area for Hitachi and asked them if they has a service bulleting for my specific symptoms and they checked and said YES. So the Tech came and changed the Horizontal POS from "0" to "1" and all the problems went away - $95 Dollars later.
    Thank you all! , Chester
    -Chico
  • Daniel Sorrels Sep 07, 2008
    I have this same problem all the time and also have ATT Uverse. Does anyone have the steps to change this "horizontal POS"? I do have the repair manual for the TV, would it be called this if I looked in the manual? Thanks for the help!
  • jimxprez Mar 08, 2009
    I have the same problem.Can you change the Horizontal POS yourself or do you have to call a serviceman ?
  • 927 Answers
Good Day;
I would suspect U-VERSE. I had it installed recently ...had problems. They came out and changed "wires". Now okay. Please call them first. Good Luck, big IRISH.
Posted on Sep 06, 2008
  • MICHAEL MULLINS Sep 07, 2008
    Good Day; I'm glad you solved your concern was fixed at a decent price. God Bless, big Irish.
AUTOMATIC SCREEN BLACKOUT after power on
The power supply is not latching. This is common on those machines when they have bad capacitors. You can change the whole power supply out if you are versed in electronic disassembly.
Dec 16, 2013 | Sanyo 32K40 32 inch Multi-System LCD TV
KV-HP212M83 greenish blackout blinks 2 times
Measure B+ on the set , If normal check G2 voltage
G2 adjustment is on the Flyback Transformer
Oct 14, 2012 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Screen blackout
what is brand and model number? If had to turn on several times to get it on...........?
May 16, 2012 | Televison & Video
Am using verizon 9530 unlocked. phone is working, the backlight is active on buttons...!! the screen is not active.. i could answer / receive calls.. can hear the notifications of receiving emails /...
When you get your blackberry screen blackout? After your blackberry 9530 unlocked or a few days after you unlocked your phone? Did you get my point? If you get that blackout screen after blackberry unlocked process try to reset your phone to default factory setting and if still not working try to reinstall your blackberry os, but if you get that blackout screen a few days after you unlock your phone looks like your screen already broken and you need to replace it in your nearest local mobile repair shop.
Jun 11, 2011 | RIM BlackBerry Storm 9530 Smartphone
Everything works great except after you touch a button or something there is like a 5 second delay and the screen turns black. but lights up everytime you do something to it....
Blackout Mode On and Off
When the Blackout mode is turned on, the display will
turn off to reduce power consumption.
This additional power enhances the sound quality.
1 Press and hold the B.OUT button for at least 3
seconds to start the blackout mode. By doing so the
display will turn off.
NOTE
If any button on the unit is pressed during the blackout mode, the
function will be displayed for 5 seconds to show the operation
before returning to Blackout mode.
To cancel the blackout mode, press and hold the
B.OUT button for at least 3 seconds.
Mar 31, 2011 | Alpine CDA-9827 CD Player
Black Screen at full brightness
It sounds like your backlight or inverter is failing, and soon you won't be able to see a picture on any setting. This is common for LCD screens over time, they start out with the occasional blackout and then progressively get worse. You can take it to be repaired, but the cost severely outweighs the cost of purchasing a new laptop.
Sep 16, 2009 | Dell InspironTM 1501 Notebook
Got an alpine cda 9855 the screen keeps goin black but if you touch the button it comes back on it has like a 5 sec delay then it goes black but still plays any help
Blackout Display Mode: When the Blackout mode is activated, the display turns off to reduce power consumption. The additional power made available by turning off the display helps enhance sound quality. If a button is pressed during the Blackout mode, the display will illuminate for 5 seconds before blacking out again. Blackout Mode On and Off (CDA-9855 only) When Blackout mode is turned on, the display will turn off to reduce power consumption. This additional power enhances the sound quality. Press and hold FUNC. for at least 2 seconds to activate the blackout mode. The display will turn off. If any button on the unit is pressed during the blackout mode, the function will be displayed for 5 seconds to show the operation before returning to Blackout mode. To cancel Blackout mode, press and hold FUNC. for at least 2 seconds.
Copied from the alpine user manual..
Hope this helps
Aug 01, 2009 | Alpine Car Audio & Video
SCREEN WON,T STAY LIT UNLESS I TOUCH IT
You are simply in blackout mode. This is so at night you aren't blinded by the glow of a screen. Here are instructions right from the manual to turn on or off.
When Blackout mode is turned on, the monitor display will turn off to
1 Touch [VISUAL] on the main source screen.
The VISUAL selection screen is displayed.
2 Touch [OFF].
The backlit-display portion goes out.
3 Touch [OFF] again to cancel the display backlight.
To make the setting, set to “Setting the VISUAL Touch Button” (page
34).
If any button on the unit is pressed during Blackout mode, the
While the backlighting is turned off, the function indicator
Jan 24, 2009 | Alpine IVA-D310 Car DVD Player
Asus Geforce4 Ti 4200 video garphic card gets hot while in proces
Hmm... sometimes it happen to me also, be sure that you've installed your software or else it may cause the troble. I suggest that you try to upgrade your ram, maybe your video card has been force to over work than normal just because your ram has to low.
Nov 23, 2008 | Computers & Internet
Hitachi 43UWX10B 43" Rear Projection Television Logo
167 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
