Question about Nintendo 64 Console
Games what sort of games can i save with a controller pak for nintendo 64 with only 22 pages for my son whos 5 years of age?
  • Anonymous Sep 07, 2008
    IT IS OLD AND WHEN I PUT IT IN THE NINTENDO 64 IT WON'T *** ON
IT NEED TO BE CLEAN
Posted on Sep 07, 2008
Do you have a good recommendation for a Wii U game that is appropriate for all ages groups?
We use "Family Party" at my house. There are 30 different games that are fun and good for my 5 year old daughter as well as my 14 year old son. Here is a link to it on Nintendo's website
Jan 28, 2013 | Video Game Consoles & Games
Pokemon stadium said that i need pak but i have one
Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
If the issue persists, the Transfer Pak may need to be replaced. For information on locating replacements for older products, please click here.
Jan 02, 2013 | Nintendo 64 Console
When we change games, we have trouble getting some of them to come on. if we switch the system on and off a few times, it will come on. sometimes it doesn't come on at all and we give up. is this the...
Nintendo 64 - Game Pak Troubleshooting
Note: It is possible that the problem you have may be game play related. For example, if you cannot defeat a particular enemy, or are missing an item you need to complete an area, the problem is likely game play related and there is nothing wrong with your game. Please check our game play help for assistance.
Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
Make sure the Game Pak firmly clicks down into place.
Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
Check the list of specific game issues to see if there are any known problems for the game you are playing.
Due to the age of the system, we no longer offer factory repairs directly from Nintendo. Please click here to find out what options are available for repair or replacement of your product.
Feb 12, 2011 | Nintendo 64 Console
I can't get any game to work. We used to be able to wiggle the game or take it out and put it into the console on a different angle, but now it won;t work at all. The power light still comes on on the...
  1. Insert the Game Pak into the system. The Game Pak label should be facing the front of the Nintendo 64.
  2. Make sure the Game Pak firmly clicks down into place.
  3. Remove all accessories (with the exception of the N64 Expansion Pak) to see if the Game Pak works correctly without the accessory. If the game does work correctly once the accessory is removed, then the game pak and the accessory may not be compatible. Check the game pak instruction manual.
  4. Check the instruction manual for the game to see if it requires any special accessories, such as the Expansion Pak, to operate.
  5. Check the list of specific game issues to see if there are any known problems for the game you are playing.
  • Controller Error Messages (e.g. No Controller Detected)
    1. Make sure you are using all licensed accessories with your system. Make sure both the controller is licensed and any accessories you are using with the controller (Rumble Pak, Controller Pak) are licensed as well. Unlicensed products may not be fully compatible with our systems.
    2. Slide the Power Switch on the control deck to the OFF position and unplug the controller. Plug the controller back in, making sure the controller-plug is firmly inserted into socket one (on the left front ofthe control deck). Slide the power switch on the control deck to the ON position.
    3. If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
  • Character Won't Move or Moves on its Own
    1. The most common cause of this problem is when the control stick on the controller is not in the neutral position when the N64 system is turned on. The neutral position is when the control stick is centered, as it is when you hold the controller while not touching the control stick. Recalibrate the Controller by using one of the following methods:
      • Turn the power off on the system. Make sure the control stick on the controller is in the neutral (center) position, and slide the power switch to the ON position. Be sure not to touch the control stick for the first few seconds.
      • During game play you can press the L+R+START simultaneously while the control stick on the controller is in a neutral (center) position.
    2. Consult the Game Pak manual for information on the primary directional control for the game. Some game paks use the control pad rather than the control stick for character movement.
    3. Try cleaning the controller (See Below).
    4. If possible, try another controller in the left-hand port. If you have a second Controller, repeat Steps 1 through 3. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here..
  • N64 Sticky Buttons or Control Stick, or other controller problems Try the following cleaning procedures:
    1. Unplug the controller from the control deck.
    2. Get a clean toothbrush (no toothpaste) and a cup of warm tap water (not too hot). Do NOT pour or submerge the controller in any type of liquid.
    3. Slightly dip the toothbrush in the water (the toothbrush should not be dripping wet) and scrub the area of the controller around the buttons and control stick.
    4. Work the bristles down around the sides of the buttons and the control stick.
    5. After cleaning the controller, dry it off with a paper towel.
    6. Let the controller air dry for at least a couple of hours.
    7. Test the controller for proper response.
    If possible, try another controller in the left-hand port. If you have a second controller, repeat Steps 1 through 7. If the trouble disappears, the first controller may need to be replaced. For information on locating replacements for older products, please click here.
Transfer Pak
  1. Verify that only licensed accessories are being used with the system. Unlicensed products are not fully compatible with Nintendo systems, and may not work correctly.
  2. Check the game pak manual or packaging to verify that the game is designed to be used with the N64 Transfer Pak.
  3. Make sure the Game Boy game pak works properly in a Game Boy system. It may be a problem with the Game Boy game pak and not the Transfer Pak.
  4. Verify that the game paks are inserted in both the control deck and the N64 Transfer Pak. If they are not, insert them and then turn the control deck power off and back on again.
  5. Verify that the controller is plugged into the proper controller socket on the front of the control deck. If it is not, secure it and then press reset on your control deck.
  6. Remove and re-insert the N64 Transfer Pak, making sure the pak is fully inserted into the bottom of the controller. If it is not, secure it and then press reset on the control deck.
  7. If possible, try another controller. If the Transfer Pak works in another controller, it may be the controller that is having a problem. Check out controller troubleshooting (click here).
Controller Pak
  • Deleting Saved Information From Controller Paks Depending on the game you own, there are a couple of different ways to delete the saved information on a Controller Pak.
    1. While turning on the Control Deck, hold down the START button on Controller #1. If the programmers utilized this feature, a Controller Pak menu should appear. This menu will allow you to view and delete the contents of the Controller Pak.
    2. If the first option doesn't work, then the game pak will have a feature that can only be accessed from a game menu. For example, in Wayne Gretzky's 3D Hockey, you delete saved info from the Options screen.
    To find out the specifics of how the Controller Pak works with a particular game, check the game's instruction manual.
Expansion Pak
  • For assistance with installing the Expansion Pak, click here.
Jan 19, 2011 | Nintendo 64 Console
How do you erase memory from the memory pak
  • Plug an N64 controller into the "Player 1" port on the Nintendo 64.
  • 2 Place the N64 Controller Pack into the memory card slot on the Nintendo 64 controller.
  • 3 Insert a Nintendo 64 game into the cartridge slot on the N64.
  • 4 Hold down "Start" on the N64 controller.
  • 5 Turn the Nintendo 64 on via the "Power" switch on the device. After the console loads, the Controller Pack menu will appear on the screen.
  • 6 Release the "Start" button on the N64 controller.
  • 7 Browse through the saves listed, using the N64 controller's directional pad.
  • 8 Highlight the game you want to erase.
  • 9 Select the "Delete" option. The pages that were occupied by the game save will be erased from the Controller Pack.
  • 10 Repeat Steps 7 though 9 until you're finished erasing pages on the Controller Pak. Restart the N64 if you wish to play the game that was inserted into the device, or turn the Nintendo 64 off if you are done using the console.
  • Read more: How to Erase Pages on an N64 Controller Pack ' eHow.com http://www.ehow.com/how_6566153_erase-pages-n64-controller-pack.html#ixzz15ZouU9Pe
    Nov 17, 2010 | Nintendo 64 Console
    Nintendo 64 controller pak doesnt save games.
    Well it sounds like that they are bad memory cards then. I had a problem with my memory cards for perfect dark saying that they are corrupted attempt to fix so I had cleaned out the memory cards and the part in the controller that they connect into and where find after they were cleaned out with qutips and rubbing alcohol. It could be the same issue that I had or they are just old or bad memory cards. The worst case could be the console or controllers could be having issues.
    Dec 23, 2009 | Nintendo 64 Console
    Ds lite saying no ds card and no game pak inserted
    Defecttive Slot 1
    Look inside with a litte light. You will almost certainly see bend pins. You son has almost certain play with someting sharp inside the connector.
    Slot1 must be replaced
    Apr 21, 2009 | Nintendo DS Lite
    How to save a game in a game pak n64
    You dont actually save it to the gamepak (n64 memory card) it gets saved to the n64 cartridge via a transfer pack that plugs into where the memory goes into the controller then you can import your save with pokemon stadium into the n64 gamepack.
    Jan 08, 2009 | Nintendo 64 Console
    Transfer pack
    I believe he is talking about the memory card or the expansion pak.
    The Nintendo 64 has memory units that plug into the slot in the back of the controllers. This is used for saving game information. Here is a picture:
    There is also a memory unit upgrade called the Expansion Pak that some games took advantage of for slightly better graphics. See this listing at amazon by clicking HERE.
    Let me know if that helped.
    Take Care,
    -WN
    Aug 28, 2008 | Nintendo 64 Console
    Controller Pak Abnormality???
    Sorry evilpacman, but you're wrong.
    The N64 Controller Pak does indeed have SRAM as you state, but SRAM _does_ require a battery to retain its contents. The battery in question is a standard CR2032 or "coin-cell". The only gotcha is that it is a PCB mount variety, with the legs already attached to the battery casing. I'm currently looking for a replacement myself... farnell may have them but I need to check the footprint...
    Jul 13, 2008 | Nintendo 64 Console
    Nintendo 64 Console Logo
    27 people viewed this question
    Top Nintendo Video Game Consoles & Games Experts
    Bee Santiago
    Raj Patel
    Julian Wainwright
    Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
