Question about Sony Handycam CCD-TR517 Camcorder
The no close
The door of my camera don'tclose
  • Anonymous Dec 21, 2008
    door won't close
  • minnecilla May 10, 2009
Alguem pode traduzir isso aqui pra mim?????
Minha Camera esta com o zoom ligado direto, mesmo sem eu aciona-lo, e nãso está dando play, msmo quando eu viro a chave de RC para PLAY.
Parece que ela está com os circuitos fechados ao ser ligada.
tento reiniciar , mas sem sucesso.
aguardo sua ajuda.
Posted on Jun 30, 2011
  • 271 Answers
Sometimes there can be something stucked inside the levers and gears...even small objects can do so...becuz everything inside is very sensitive...or it's having an internal circuit problem
Posted on Aug 14, 2008
Battery door won't stay closed on Sony Cyber-Shot DSC-S90 Digital Camera
The battery door latch is most likely damaged/broken. Try using a piece of duct tape to keep it closed. I've done this on several cameras with battery door latch issues & the doors stayed shut just fine.
May 20, 2014 | Sony Cyber-Shot DSC-S90 Digital Camera
Battery door dosen't stay closed
After you close the door hold it closed then slide it forward
Nov 19, 2013 | Nikon Coolpix L22 L-22 Black Digital...
Having problems with my N90s
when you place the film in the camera & close the door does the film advance ?
Jun 06, 2013 | Nikon N90S 35mm SLR Camera
Cd drive won'tclose
i've already answered on your question "cd drive won't open"
solution is the same
Mar 12, 2012 | Gateway Computers & Internet
I accidentally dropped my samsung S1070 while I was taking a photo, and the lens is now stuck out. It won't turn on, and we've tried replacing the batteries and taking them out. I've also tried...
Check whether your batteries are actually making contact with the battery posts, and that these posts are clean. If not, bend the posts up/down a little, and maybe clean them with a little rubbing alcohol on a Q-tip.The next thing to try is examine both the battery and flash card door. There's usually a little switch on both doors (note some SD card doors do not have this switch) that activates when the doors are closed. If they don't, the camera won't start to prevent damage to the flash card or camera startup sequence. For most cameras its usually a little piece of plastic on the door that pushes in on a pin switch when the door is closed. Closely examine both doors to try to identify these switches. A lot of times that little plastic nib wears down or breaks off, but can easily be jury rigged with a small glued-on replacement.
If you've tried all of the above and still no luck, the problem is then likely to be internal to the camera. One example would be that if your camera uses Compact Flash, check to make sure all pins are present and aligned in the card slot (if bent, simply unbend/straighten them with a skinny "jewelers" screwdriver, then insert the flash card for final realignment).
Thank you!
Sep 04, 2011 | Samsung S1070 Digital Camera
Hi My camera (finpix S1000fd) 10.0 mega pixels, the door where you put the batteries when you open it there are some small things that hold it closed but two of them are broken. where can i go and fix it?
Sadly it will probably cost more to fix than it will to buy a new camera from Amazon. If you don't mind the "cosmetic smudge" use a bit of gaffa tape to keep the door shut.
May 23, 2011 | Fuji Cameras
Problem started with battery door
The door has an interlock on it. You probably broke the door. The door on some of these cameras can be replaced from the outside. You must make sure the interlock switch is not broken as well. The tabs on the housing of the camera can get bent or snapped off if enough force is used.
A broken door will be $75 there abouts, installed.
A broken detect switch, adds about $45 (A board).
A broken case may set you back an additional $75
Apr 16, 2010 | Canon PowerShot SX100 IS Digital Camera
Nikon Coolpix L1 Digital Camera
Happend to me after dropping the camera. Tape's good.
Aug 21, 2008 | Nikon Coolpix L1 Digital Camera
Not power on
Here are some simple things to try first for a camera that won't power on. They won't work for every case, but they're worth a try:
Recommend paying particular attention to that little switch and little plastic pushpiece that closes the switch when the battery door is closed.
Mar 27, 2008 | Canon PowerShot A560 Digital Camera
ACK DC30 Mains adapter doesn't work
I think these cameras have a small removable rubber cover which will allow you to put a lead in and still close the door. There is a switch on the battery door so it has to be closed for the camera to work!!
Nov 22, 2007 | Canon PowerShot SD550 / IXUS 750 Digital...
Sony Handycam CCD-TR517 Camcorder Logo
206 people viewed this question
Top Sony Video Cameras Experts
Larry Stiles
Larry Stiles
Are you a Sony Video Camera Expert? Answer questions, earn points and help others
