Microsoft xp start up disk hang - Computers & Internet
  • 3,051 Answers
Where is it hanging at may want to try it in a nother pc or you may have to get a replacement one from either your computers manufacturer or download it from microsoft,com
Posted on Aug 14, 2008
My motherboard is asrock h55m-le it is showing some problem.. on starting windows.. my windows sign hangs on startup.. please advice me what to do.. i think it is over heating problem..
where your screen hangs....
1 if using XP did it hangs when xp is bootig??
or any other time.
and if yes then it is not mother board problem ...rather it is a hard disk problem.
you will have to zero fill your hard disk.\
if helped ..please thum up
Jan 09, 2011 | Asrock H55M-LE LGA1156/ Intel H55/ DDR3/...
My xp pro os wont boot after running chkdisk at startup.. It checks the disk says ''clean'' then acts like it is going to boot up windows but just hangs there indefinitely .. tried safe mode and it hands...
Open XP in safe mode with command prompt.
Open a command window (start/run type cmd in the box then enter) and you will get the following.
Microsoft Windows XP [Version 5.1.2600]
(C) Copyright 1985-2001 Microsoft Corp.
You will then have a flasihg curser after
C:\Documents and Settings\PC name>
Type
CHKDSK /f /r
You will then get
C:\Documents and Settings\PC name>chkdsk /f /r
The type of the file system is NTFS.
Cannot lock current drive.
Chkdsk cannot run because the volume is in use by another
process. Would you like to schedule this volume to be
checked the next time the system restarts? (Y/N) y
This volume will be checked the next time the system restarts.
Type exit and restart.
make sure there is a space between each / and the previos word/command
The /f and /r do the following
/f: Fixes errors on the disk. The disk must be locked. If chkdsk cannot lock the drive, a message appears that asks you if you want to check the drive the next time you restart the computer.
/r: Locates bad sectors and recovers readable information. Again the disk must be locked.
Jul 30, 2010 | Microsoft Windows XP Professional SP3 Full...
Install XP, it hangs up with the message at the bottom ''Searching for previous versions of Microsoft Windows'' please help
Windows installer always formats the disk after checking the previous installation. There are two ways to overcome this problem. One, if windows still boots, then insert the installation disk in the drive and let it Auto Run, and ask you whether you want to upgrade the OS or install new. If you upgrade then the formatting will not take place as windows knows that there is already a window on the disk. But should you want a new installation then it will do all the checking and may hang again. So, upgrade. Two, dl you have a DOS bootup disk. If yes then boot up with DOS boot up disk and format the HDD with it. once it had formatted and windows checks up, let it. It will not hang now. as there in a very clean HDD.
Nov 09, 2009 | Microsoft Windows XP Professional with...
Window Xp Pro Setup Hangs at Logo Screen after reboot
You can try also to do reformat your hard drive as fresh unallocated one before doing formatting again to install windows. And check your installation disk for scratches.
May 07, 2009 | Microsoft MS Windows XP Professional SP2
Computer hangs during xp installation
make sure you have met the minimum hardware requierments when installing your XP...which is
• PC with 300 megahertz or higher processor clock speed recommended; 233 MHz minimum required (single or dual processor system);* Intel Pentium/Celeron family, or AMD K6/Athlon/Duron family, or compatible processor recommended
• 128 megabytes (MB) of RAM or higher recommended (64 MB minimum supported; may limit performance and some features)
• 1.5 gigabytes (GB) of available hard disk space*
• Super VGA (800 x 600) or higher-resolution video adapter and monitor
• CD-ROM or DVD drive
• Keyboard and Microsoft Mouse or compatible pointing device
Apr 11, 2009 | Microsoft Windows XP Professional for PC
HP Workstation xw6400 hang every 10 to 15 min.
Check for any virus. Check disk manager for any hard disk manager. if disk is ok  replace your memory with a new one
Apr 09, 2009 | Microsoft Windows XP Professional for PC
Intel Desktop bord D845GVSR with Windows XP hanging frequently
Sometime this happens when you use the drivers on XP you may need to down load the correct drivers and a good place to start is driverguide.com you may need to enter details for free registration
Jan 22, 2009 | Intel D845GVSR Motherboard
Have installed Canon software for Powershot A670 from its product disk - canon power tools 34.0. Result is I can't start my windows XP machine. Won't start in safe mode, won't start with XP system disk as...
do repair windows xp using bootable xp disk and choose repair option when asked. if it work then install cannon drivers for xp only. if not re-install xp and choose appropriate drivers.
Nov 21, 2008 | Computers & Internet
WindowsXP SP2Installation hangs in Compaq Presario 2000 series
minimum requirements for XP
Nov 07, 2008 | Microsoft Windows XP Professional With...
Hard disk partation not found
better to dump your data from main hard disk then once reformat your main hard disk then that external hard disk work properly .............
Feb 16, 2008 | Microsoft Windows XP Home Edition
Computers & Internet Logo
Brian Sullivan
Brian Sullivan
David Payne
David Payne
