Question about HP Officejet Pro L7680 All-In-One Printer
L7680+ can't scan pictures
I can't scan pictures to put on my web page!!!
  • claire45colt Oct 28, 2008
    can't scan
  • Hashir Tasleem
    Hashir Tasleem May 11, 2010
    Hi .. is there any error message generated when u try to scan the pictures....
    Novelist:
  • 183 Answers
Resetting the All-in-One
  • Press the On (L7680+ can't scan pictures - fa37665.gif) button to turn off the unit.
  • Disconnect the power cord from the back of the unit.
  • Connect the power cord to the back of the unit.
  • Press the On (a477fdf.gif) button to turn on the unit.
Posted on Aug 19, 2008
I cannot scan a document as a PDF. How can I change the scan profile to allow this
In Windows you can usually do that from the Printer Properties dialog box. There is a lot of information on the HP web site, HERE.
Sep 14, 2010 | HP Officejet Pro L7680 All-In-One Printer
I use Adobe Standard 9 to scan documents for archive. When I scan from the glass it works just fine. When I scan multiple pages from the document feeder, I get errors. I've updated my hp software for the...
Hi! I will be glad to assist you in this issue, here is the solution that will help:
http://h10025.www1.hp.com/ewfrf/wc/document?docname=c01537611&tmp_task=solveCategory&lc=en&dlc=en&cc=us&lang=en&product=2512009
Nov 04, 2009 | HP Officejet Pro L7680 All-In-One Printer
Need to set it up to scan documents
If you wish to scan to a computer drive, get the IP address of the printer by using the printer menu and scrolling down to network configuration. Hit enter and you'll be prompted to print a page. Use the computer you wish to scan and open a web browser, type in the printers IP address. Then select digital imaging. As long as you are not under a lot of security and passwords, add a scanning address (your pcs nickname or ip address) in the listing. If you download your manual at http://h10025.www1.hp.com/ewfrf/wc/manualCategory?lc=en&dlc=en&cc=us&lang=en&product=2512009& you'll find the step by step procedure under digital imaging.
Oct 29, 2009 | HP Officejet Pro L7680 InkJet Printer
HP L7680 issues
the papre in frint pages and out air in pages
and put in the trey and your used paper sige cuting in used this systim
Sep 12, 2009 | HP Officejet Pro L7680 All-In-One Printer
Partial scanning from an HP Officejet Pro L7680
Either download the User Guide by using the link below or get your own one out of the drawer
When you have a copy turn to page 57 and set the scan to A4 you have probably got it on Letter
Click on the link
http://h10032.www1.hp.com/ctg/Manual/c00863866.pdf
Jun 16, 2009 | HP Officejet Pro L7680 All-In-One Printer
Can I scan multiple pages by using the document handler on the HP L7680 Inkjet All-in-One Printer?
Yes, you can do this by knocking together the sheets you want to scan into a small, lined-up stack and then put them face up, in the ADF loader.
Bear in mind it can only handle so many sheets at a time (think it's 15?) so don't stuff it with too much or it'll choke.
Remember also that it needs nice straight edges, not dog-eared bits of scrap paper otherwise it'll mis-feed or crumple your source documents.
Oh and you'll need to make sure the software you're using can actually make use of the ADF... The HP provided software can, but it may take a little bit of experimentation to figure out the best, most-appropriate settings.
Hope that helps..
Martin
Mar 30, 2009 | HP Officejet Pro L7680 All-In-One Printer
L7680 all in one W/big & wide dark vertical line
Open the document feeder and clean the scanner glass.
Feb 16, 2009 | HP OfficeJet 7310 All-In-One InkJet...
Scanning docs & size of pdf files on Mac w/HP l7680 All-in-one
The scanner produces a "picture" of the document, much as if you laid it flat on a table and took a picture of it with your digital camera. If you did this, your .jpg from the camera would be several hundred K at a minimum - comparable to the file size off the scanner. That's why the file is so big, it contains a picture and not text data - even though it's still a .jpg file.
If you reduce the scan resolution you will save space, but at the expense of legibility of the document image. To get it down to the smallest possible size, you will need to run the scanned image through OCR ( Optical Character Recognition ) into a Word document for example, and then print it out to a .pdf file. If you have a clean source document with few graphics this isn't as difficult as it may seem. Microsoft Office has an excellent OCR process known as Document Imaging. You need to carefully proof read the result but with a clean input Document Imaging is amazingly accurate in Office 2007.
In short, there is no easy solution to your problem.
Dec 30, 2008 | HP Officejet Pro L7680 All-In-One Printer
Won't stay connected to network for scanning
TRY WITH SCAN SOFTWARE INSTEAD OF SCAN BUTTON ON THE PRINTER
Jun 27, 2008 | HP Officejet Pro L7680 All-In-One Printer
HP Officejet Pro L7680 All-In-One Printer Logo
87 people viewed this question
Seeker5211
Seeker5211
