Question about Toshiba Computers & Internet
Need BIOS type and serial number - Toshiba Computers & Internet
  • Toshiba Master
  • 3,051 Answers
If you boot the computer into bios it will tell you there
regards mike
Posted on Aug 14, 2008
SOURCE:
Where to find serial number of laptop in bios
Only a few brands of laptop put the serial number in bios. If you are able to get into Windows, there are a number of freeware programs that are able to get the serial numbers. Search Google for "Freeware serial number finder".
Jan 06, 2014 | Dell Vostro 1510 Laptop
Where is serial number
Usually serial number you can find written in sticker back of your laptop. If not
1. Go to command prompt
OR
1. Press and hold window key and press key "R"
2. Type:- cmd and Enter
3. Type:- wmic bios get serialnumber and Enter
May 11, 2013 | Computers & Internet
Serial number on a asus vivo tab rt
- Turn on your tablet
- Go in "desktop mode"
- In the "search bar" (swipe outside right to inside going left, tap "Search")
- Type "run" and tap the "Run" app icon
- In the textbox of the "run app", type "cmd" then tap "Ok"
- Type "wmic bios get serialnumber" in the command prompt
- Serial number will appear
There is also a sticker at the back of the tablet containing the serial number (bottom left). This number should match the one obtained from the wmic command.
Nov 30, 2012 | ASUS VivoTab RT
Need serial number
If running Windows you can find you serial number via the Windows Command Line Interface (CLI)
HowTo:
Start --> Run --> CMD --> OK
at the ">" prompt type: WMIC BIOS get serialnumber
Notes and Tips:
Help! I don't see the Run Command at the Base Right of my Start Menu
Select the Windows Key 5efscqsiutc36pracwwi8vi8xg8fotfo1h4qiww+19xaygba7ieowaaaabjru5erkjggg== plus R together on the Keyboard
This will launch the "run" box , type in CMD {short for "command"} and click OK
now at the ">" prompt type: WMIC BIOS get serialnumber
and the return result is your machine serial number.
May 07, 2011 | Computers & Internet
My samsung laptop was stolen. It was recovered and I need to prove that it is my via the serial number tomorrow. If the serial number sticker has been taken off the bottom of the laptop, is there another...
If you can get into windows go to start -> run -> type cmd and press enter, type this command it usually returns the serial number wmic bios get serialnumber I have tried this on dell's and hp's and it works great, i cant imagine a samsung would be any different.
Mar 12, 2011 | Samsung R580JBB2 Notebook
Lost my motherboard driver disk of asus k8v-vm, where i can downloard it
go= http://support.asus.com/download/download.aspx?SLanguage=en-us
go download>select>mother board>2nd select socket 754>3rd k8v vm and search and download
Name ASUS K8V-VM Description VIA K8M890, VIA VT8237A, DDR RAM, Micro ATX, Graphics card, Sound card, Network card Form factor Micro ATX CPU Type AMD Ahtlon 64/Sempron Number of CPUs Single Socket Socket 754 Front side bus 800 MHz MHz Chipset VIA K8M890, VIA VT8237A Memory type DDR RAM Number of DIMM-Slots 2 Number of RIMM-Slots 0 Max memory 2048 MB Memory speed DDR400, DDR333, DDR266 Serial Attached SCSI (SAS) No Serial ATA (SATA) Yes Serial ATA ports 2 Serial ATA 2 (SATA II) No Serial ATA 2 (SATA II) ports None IDE Ports 2 IDE Speed 33/66/100/133 MB/sec MB/sec Built in SCSI controller No Built in RAID controller Yes Built in graphics card Yes Built in sound card Yes Built in network card Yes Multiple GPU support No Crossfire support No SLI support No RoHS Compliant No AGP interface No AGP-slots 1 PCI-e (PCI-express) Yes PCI-e slots 2 PCI-e type 16x/1x PCI slots 2 PCI-X No CNR-slot 0 AMR-slot 0 eSATA No Bluetooth No WiFi No FireWire (IEEE1394) No Number of FireWire ports 0 USB type USB 2.0 Number of USB-ports 4 Number of parallel ports 1 Number of serial ports 1 RJ-45 (Ethernet) 1 PS/2 Keyboard 1 PS/2 Mouse 1 Line-out 1 Line-in 1 Microphone Yes Bios 4 Mb Flash ROM, AMI BIOS, (TCAV), PnP, DMI2.0, WfM2.0, SM BIOS 2.3, PXE Boot BIOS Miscellaneous Audio:- Realtek ALC660 6-Channel Codec, LAN:- Realtek RTL8201CL 10/100M LAN PHY
Nov 22, 2010 | ASUS K8V-VM (K8V-VM GREEN) Motherboard
How to change bios settings, i.e model/type serial number, enable.disable memory banks
Boot the system
Press F1 to enter the Configuration/Setup Utility
Oct 06, 2009 | IBM xSeries 366 Server
Where can i get the sound driver for my motherboard intel d865gkd
The sound driver you need is the SoundMAX Cadenza driver. according
IBM YOUR IS http://www-307.ibm.com/pc/support/site.wss/document.do?sitestyle=lenovo&lndocid=MIGR-51191&velxr-layout=printLenovo
Thank you.
Mar 26, 2009 | Computers & Internet
Serial number 557s notebooks ECS
Maybe with the Everest software you could get the serial number, I'm not really sure, but if you only need drivers for this model check this link
http://www.ecsusa.com/ECSWebSite/Products/ProductsDetail.aspx?detailid=479&CategoryID=3&DetailName=Driver&MenuID=1&LanID=0
If this was helpful to you, please rate me.
Dec 27, 2008 | Balance CN6555 Notebook
Computers & Internet Logo
19 people viewed this question
Top Toshiba Computers & Internet Experts
Ekse
Alun Cox
Are you a Toshiba Computer and Internet Expert? Answer questions, earn points and help others
