Question about Dell E173FP 17" LCD Monitor
DELL 17' MONITOR STATUS LIGHT FLASHES, BUT WON'T COME ON
Hello, my dell monitor was working fine then one day, it tried to come on but shut back off. then the status light just blinks about every five seconds like its trying to kick back on. when you leave it plugged in for a while it would finally "click over" and come on, i can use it for about 2 days to a week, then it does it again. this time however, the blinking eventually stops and the solid green power on light comes on but has no picture. when you try to restart the computer you get an image for about 2 seconds then the blinking starts all over. i'm pretty good with electronics and i have a fluke multimeter. i just have no idea on where to start with this problem. please help
  • mchristopher Feb 16, 2009
    i have the same problem only mine just always does that i cant even use mine. i turn it on and then it stays good for about 2 seconds then goes to black. every time i restart my computer it does the same thing
  • 51 Answers
Sounds like capacitors in the power supply. Open it up and check for any swolen Caps.
Posted on Aug 14, 2008
Monitor problem
The power light is flashing green can indicate start/restart of the power supply due to shorts circuits or failing power supply due to bad caps, look for bad caps with bulging top first, see example of failed monitors due to bad caps: http://s807.photobucket.com/home/budm/allalbums
Post back what you see insdie so we can guide you furhter.
Feb 20, 2010 | Acer 17" AL1706B LCD Monitor
Just hooked up my pc yesterday worked fine. I shut down by going to start & turn off computor. Came back later to start back up. Monitor tells me in power safe mode. Tower doesn't seem to be starting...
You can try removing external devices like (ex. usb printer, external Hard drive) and try to start the computer again. And see if there are lights on the tower
Hope this helps
Jan 03, 2010 | Dell E173FP 17" LCD Monitor
Power almp blinks
i have this problems before its an inverter problem. pls. repair the inverter.
Jun 28, 2009 | Dell E173FP 17" LCD Monitor
Dell LCD TV won't turn on
check the cable who comes from the cpu
May 07, 2009 | Dell E173FP 17" LCD Flat Panel Monitor
Dell E173FPC Monitor stays black and the Power switch cycles
You need to disasemble and check for dry or burn capacitors first then check for the transistors near the inversors.Good luck
Apr 03, 2009 | Dell E173FPc 17" TFT LCD Flat Panel...
17 in dell monitor
Please disconnect the Monitor Data cable from Computer.
If you see Dell Colored bars, it means, monitor is working fine,
If still black, please ask for replacement, since Monitors have 3 years of warranty if not purchased with the computer.
Now connect the cable back to computer and turn the computer off by holding the power button on computer and turn it back on...
Blinking Green shows that computer is in sleep mode......
Hope this should resolve the issue.
Nov 06, 2008 | Dell UltraSharp 1704FPT 17" Flat Panel LCD...
Flashing yellow light on Dell Monitor - what does it mean?
It means the display is in power save mode. This status occurs when the display is on but not receiving any signal.
Aug 01, 2008 | Dell E173FP 17" LCD Flat Panel Monitor
Monitor won't turn on
The inverter power supply logic board has probably goe out. You can get it here or have it fixed.
http://www.lcdrepair.us/e176FPf-inverter-power-logic.html
Mar 30, 2008 | Dell E176FP 17" LCD Monitor
Flashing green power light - Black screen
I had the same problem with an AOPEN 17' lcd that was left behind at a rental property... I plugged it into my dell dimmension 4400 in place of my old analog. It worked fine the fist night, and got up and when turned it on again it had the famed green blinking power light. I switched back to the analog, and just disappointed I plugged in the AOPEN to another power source, and power came on a steady red light. I plugged it back into the puta and it came on again. I have not turned the monitor off again for fear of the blinks, and has been working great for close to a week now. Hope it helps someone else out there. Richard
Mar 27, 2008 | AOpen F75PS 17" Flat Panel LCD Monitor
Dell E173FP 17" LCD Monitor Logo
622 people viewed this question
Alun Cox
