Question about Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Rear break locking up. - Harley Davidson Harley-Davidson Motorcycle Desktop Telephone
Check the hose as i had one that came apart inside and the little flap was acting like a check valve preventing the fluid to return to the master cylinder in a normal fashion. second, i had one brake that the piston was cocking in the bore and not returning. make sure the caliper is floating on its pin (not stuck). other than that, you will have to check the master cylinder, you could have a broken return spring inside that returns the plunger.
Posted on Aug 14, 2008
SOURCE:
How to open a deadlocked rear door.
Hi. remove the rear seat and door pad. You can access the lock through a small hole, break the top inner corner of the lock and it will release the dead lock and open the door.
Jan 29, 2014 | 2004 Volkswagen Golf
Remove the seat and door pad. You can access the lock through a small hole. Break the top inner corner of the lock to release the dead lock and open the door.
Jan 24, 2014 | 2004 Volkswagen Golf
Rear doors dont lock with auto lock switch on ram 2500 slt
Check the wiring harness into the rear doors - they tend to get crimped and break the wires
Feb 04, 2013 | 2006 Dodge Ram 2500
1993 ford f250 xlt rear breakes locking up
I would suspect you have a problem with ABS control valve if you are sure grease from the rear diff isn't getting on the shoes.
Jun 17, 2012 | 1993 Ford F250
My rear breaks lock up at 20 mph
check the rubber hose they sometimes break inside causing it not to let fluid to to retract therefore it keeps pressure on the caliper
Mar 29, 2012 | 2000 Mercury Grand Marquis
Rear breaks lock up at slow speeds. when traveling from 0 to 10 MPH if breaks are applied abruptly 1 or both of the rear wheels will lock up before the front breaks seem to engage, especially on wet road....
`right one of two problems ,firstly remove the rear drums and check for a fluid leak as a slight smear of fluid will cause the exact problems you describe ,if the rear shoes are dry then push the cylinder each side to make sure its not seized ,secondly check the load sensing valve which will be under the chassis above the back axle,if that appears ok and not seized then remove the master cylinder and take the piston out and check the rubbers and the cylinder bore for wear ,but mainly this fault is caused by the brake shoes having a slight amount of brake fluid contamination and it causes the brakes to grab
Apr 09, 2011 | 2001 Mazda Tribute
Rear breaks locked up on my 1986 honda four trax
If rust locking brakes try tapping with wooden mallet and turning wheel backwards.
Aug 18, 2009 | Sport & Outdoor - Others
Flat tire due to what mechanic said was a problem with the rear breaks locking.
as if breaks locking up means something wrong with calipers it would wreck your brakes not tires
Jul 07, 2009 | 2001 Hyundai Accent
Break calpier 2000 v 316
If rear, then parking brake possible cause.
But front and rear calipers often lock from corrosion on piston or binding on sliding parts.
Remove caliper, remove piston with compressed air or greasegun, clean corrosion, clean all grease out, replace seals. (compressed air is dangerous!)
Jun 26, 2009 | 2001 BMW 325
2000 Chevy Tahoe
no. It would be the other way around. If something went wrong in the rear end and it locked up, you could break the drive shaft universal joints trying to force it to go. if your rear end locked up, I'd be willing to bet there was no oil in it.
Jan 12, 2009 | 2000 Chevrolet Tahoe
Lands Phones Logo
60 people viewed this question
Top Harley Davidson Lands Phones Experts
Tom Diffin
Sheldon Dedek
WTF Chuck.....
WTF Chuck.....
Are you a Harley Davidson Lands Phone Expert? Answer questions, earn points and help others
