Script error: index out of range
When I try to start one of the languages in Rosetta Stone I get a pop up window that says "index out of range." It asks me if I want to continue running scripts and if i click yes, it does the same exact thing again. If I click no, it shuts down the program. Can you please help me solve this problem?
  • benjyfox Feb 26, 2009
    I have installed Rosetta Stone and every time I try to run my Vietnamese lessons it just says the exact same thing as guyser's does. Still no one with a solution?
  • Anonymous Apr 28, 2009
    I recieve also Script error: index out of range when I start Rosetta
2 Suggested Answers
  • 88 Answers
SOURCE: Help, I am trying to run Rosetta Stone Spanish. I
This error identify that the script for Spanish language is not installed or corrupted it comes in separate CD
Posted on Sep 05, 2009
I got a Error 4118 with my Rosetta Stone program
Go to the Rosetta Stone website. They have some solutions posted for this problem.
Dec 27, 2014 | Rosetta Stone Computers & Internet
Error 9119 rosetta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure. Good luck and spread the word.
Dec 05, 2013 | Rosetta Stone V3 Spanish (Latin America)...
Error 9119 rosseta stone
When you install Rosetta Stone it puts its language files in a different folder. When you uninstall the program the language files are left intact and are never touched. If a problem occurs and one of the language files becomes corrupt and unreadable you're going to get that error 9119 every time when you try to re-install your language pack. Each language level has THOUSANDS of files in hundreds of sub-folders. Each file in those sub-folders has an hexadecimal name of 40 or more characters in length. So good luck trying to find the corrupt file(s). Also, because the file or files are corrupt, they can't be read or deleted. You're going to have to perform chkdsk on your hard drive to recover the bad sectors...eventually. The quickest and simplest way to fix your Rosetta Stone problem is to rename the folder where it puts its language files to something else. On an xp system the default name is "C:\Documents and Settings\All Users\Application Data\Rosetta Stone". I changed mine to "C:\Documents and Settings\All Users\Application Data\Garbage Files". That way when Rosetta Stone goes to install its language files it will recreate the folder cleanly instead of trying to overwrite the old folder and its corrupt files. That will solve your problem. You can then run chkdsk at your leisure and delete the Garbage Files. Good luck and spread the word.
Error 9119, 9114 rosetta stone
Dec 29, 2012 | Rosetta Stone Computers & Internet
Rosetta Stone Error 9120
language CD is the main problem to get error 9120. To fix this i got this link for you all Ask Question Rosetta Stone Community
Jan 15, 2012 | Rosetta Stone Chinese Mandarin Level I &...
Hi, I'm using Rosetta Stone 3 online through a school license. I keep getting a 'loading next screen' box popping up, but it gets stuck at three quarters loaded, and refuses to go any further! Any ideas on...
Do you have the issue with other levels or languages as well? Maybe you can try removing and then adding the languages again, and see if that helps. As a last resort, you can also try reinstalling Rosetta Stone if this occurs with all languages and levels you own.
Mar 12, 2011 | Rosetta Stone Version 3 Swedish Level 1 2...
Loaded Start disc. When installing my language disc 1, I get an 9123 error code and a message " there was an error in the application". I cannot uninstall, because I get messages "...
Version 3/4: Error 9123 during Language CD installation
This error message relates to Version 3 and Version4. If you receive a 9123 error message during language installation, try one of the following resolutions:
  • Clean the disc with alcohol/windex/water and a soft cloth and try installing again.
  • Disable your internet security program, especially Norton or Symantec Security and try installing again.
If you are still experiencing this error, please contact Rosetta Stone Support
Dec 23, 2010 | Rosetta Stone Chinese Mandarin Level I &...
Rosetta stone problem installing language discs
I just had the same problem. Rosetta Stone TOTALe French Level 1. I just ran it in Windows XP Service Pack 2 and it installed right away.
Apr 07, 2010 | Rosetta Stone Spanish (Latin American) -...
Help, I am trying to run Rosetta Stone Spanish. I keep getting a dialog box which says: ''Object Expected Script error. Continue yes no
Aug 31, 2009 | Rosetta Stone Spanish I & II Personal...
When i try to install language disk i am getting
Well if it works in XP and Vista then it is safe to say it isn't compatible with W7.
Remember, Windows 7 is not going to be released for another 2+ months.
I have found a large number of programs that just don't work with W7.
Your best bet is to check on Rosetta Stone's website to find out if they list W7 as a supported OS.
Aug 23, 2009 | Rosetta Stone Spanish Level 1-2-3 Full...
Computers & Internet Logo
1,106 people viewed this question
David Payne
David Payne
