Question about LG WD-14124RD Front Load Washer / Dryer
Trom Front Load Washer
Dear Expert,
Some one told me that you could clean a front load washer with: 1st cooking oil and then 2nd vinegar. Is this true? I have not wanted to take that change since the instructions say to use bleach only.
Also, how many times can you use the cleaning cycle (clean drum) using bleach? I'm having trouble with bad odor (like moldy smell). I only use about 1 tablespoon per load of He laundry soap.
Thanks.
Zanna.
    New Friend:
  • 60 Answers
I have never heard of cooking oil but I have heard of vinegar. If you have had your washer for a while (over a year) it could take several times of cleaning to get rid of the odor. Also be aware that liquid softner actually builds up worse inside the tub then the soap does so only use 1 tablespoon of softner. If you run the washer with nothing in it and you see lots of bubbles in the water you still have the build up inside the tub. The last item I've heard of is something called "whirlout" (not sure on the spellng) that you can get from a hot tub dealer.
Posted on Aug 15, 2008
Own a lg wm1832cw front load washer doesnt seem to clean properly when wearing tee shirts for an hour smells like they never were washed paid alot of money for this thing seems cheaper top load machines...
Hi
The smell usually comes when the washer is unable to drain water completely, you can run your washer at its hottest temperature setting with 1 cup of vinegar inside the unit. After this take off the bottom front panel and clean it completely, also clean the drain hose and drain pump filter, the smell should disappear after doing all this. Hope this helps...please post back for further assistance.
Daniel
Sep 12, 2011 | LG WM1814CW Front Load Washer
I have lost manual can you run something thru a load to clean machine such as vinegar or baking soda my machine smells musty
Hi
Daniel
Aug 29, 2011 | Kenmore Front Load Washer
Is it alright to add vinegar in the Kenmore front load washer. I find this removes smoking odors the best.
The answer is YES but keep in mind that like all Front Load Washing machines, use less vinegar than you would a typical top load washer. If you would usually use 1/2 cup of vinegar (4oz) try using half of that.
Apr 27, 2011 | Kenmore 43142 Front Load Washer
My washer isn't working the washer is an LG TROM WM2277HB the washer shows OC I don't know what that means
Hi dear.As I know there is a OE code on LG washers,if it's Check the followings.OE is drain fault.Check your machine filter there must be blockage(Coin,pin,fluff etc.)clean it.Also check for any kink on drain hose.I hope that helps.Thanks.
Aug 28, 2010 | LG WM-2277HW Front Load Washer
Front loader smells like stale cigarettes during cycle
Make sure that you are using high efficiency (he) detergent. Pour 2 cups of vinegar in the tub and fill the detergent tray with vinegar. Run it on the hottest, longest cycle. You can also use a Front load cleaner such as Afresh, made by Whirpool. I think that Tide makes one too. Vinegar is usually readily available. At the end of washing for the day, leave the door to the washer slightly open so that fresh air can get in and dry it out keeping moldy, milduey smell down. If it mildews, use a rag and bleach water to clean the boot seal. Hope this helps.
Apr 02, 2009 | Kenmore HE2 Plus Front Load Washer
Bosch front load washer bleach compartment fills with water.
you could running some vinegar through it. Vinegar is good for cutting residue build up.
Jan 01, 2009 | Bosch Axxis WFL 2060 Front Load Washer
Foul smell coming from washer
Run a vinegar wash periodically. My mother has an upright that was doing the same thing and all the repair man told us was to not use powder detergent, clean the gasket, and do the vinegar washes periodically.
Aug 26, 2008 | Kenmore Elite 45986 Front Load Washer
Maytag Neptune rinse cycle doesn't start.
cold water valve screen plugged or bad valve, just check it!
Aug 06, 2008 | Maytag Neptune MAH6500A Front Load Washer
LG TROM STEAM WASHER-WM2487 HRM
You are probably using too much soap and softner. You only need about 1 Tablespoon of each for a full load with a front load machine. Run it with nothing it in except bleach. If you see bubbles inside that means there's left over soap in the tub. Keep running it empty (with bleach) until you don't see bubbles anymore then start using less soap and softner.
Jul 31, 2008 | LG WD-14124RD Front Load Washer / Dryer
LG washing m/c trom model
Hi, clean the sosp drain hose clug ,push with clean stick the hole of the hose.
Jan 27, 2008 | LG WD-12126RD Front Load Washer / Dryer
LG WD-14124RD Front Load Washer / Dryer Logo
219 people viewed this question
Top LG Washing Machines Experts
Dan Webster
Dan Webster
Gerry Harvey
Gerry Harvey
Are you a LG Washing Machine Expert? Answer questions, earn points and help others
