Question about Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum
I have a Bissel Pro Heat Plus and I used it once, one year ago. I may be using it wrong, as my carpets were wet and there was no return (dirty water). If I remember correctly, going forward wets and cleans the area and to dry the area you move backwards. Please help, as I can not find my manual anywhere (which is not like me). HELP!
    Brigadier General:
  • 3,301 Answers
It has only one tank that serves two purposes. It holds the clean water and collects the dirty water, so you only have to empty/fill one tank. If you check reviews of this machine you will see that they basically stop working correctly after a very short time, if I was you I would just contact their customer service at this number 1-800-237-7691
Posted on May 16, 2011
3 Suggested Answers
SOURCE:
SOURCE: not picking up water on a bissel proheat turbo 2x
If unit is not picking up solution it is most likely the small red plastic filter that is just above the small float door in the top piece just left of the tool switch.. pop it out clean muck out of it and it will work like new again.. have fun!!
Posted on Jan 31, 2010
  • 491 Answers
SOURCE: I have a Bissel Powersteam Pro Delux model
Have you tried here?
http://www.fixya.com/support/p49962-bissell_1697_7_powersteamer_pro_deluxe/solutions
Posted on Dec 17, 2010
My carpet was dirty in spots. after using my pro heat , the whole carpet is dirty. some of the dirty water came out at the sides and left blotches of dirt every where I pushed it. I am so disgusted. I've...
Dont fill water tank so full and change water more often. Home units are made for smaller jobs thats why rug doctors and others unit can be rented. Different systems altogether.
Apr 18, 2010 | Bissell 1698 PowerSteamer ProHeat Upright...
Bissel power wash pro heat
Look under neath there is a **** hole. It may be plugged
Feb 09, 2010 | Bissell Carpet Cleaner Powerbrush Deep...
Proheat2x carpet cleaner
Sometimes we will get a lemon even in small equiptment but I would encourge you to not allow call again but email tech. support too see if you get the right person that will see you thru to the end.
Dec 01, 2009 | Bissell ProHeat Turbo Deep Cleaner Upright...
Whare does the dirty water go in the bissel 12 amp pro heat carpet cleaner
the clean water goes into a "Bladder Bag" that is located inside the tank. The way it is designed to work, as the clean water dispenses from the bladder bag, the outer part around the bladder bag fills with the dirty water. It never touches the clean water. Seems wierd, but it works! I hope this helps, if it does, please give feedback, as it helps me to gain ratings. Thank you! Remember to have your cleaners serviced every year by a qualified tech! Rene (The Vacuum Doctor)
Nov 06, 2009 | Bissell Carpet Cleaner Powerbrush Deep...
Carpets soaking wet
turn dial in front on the water tank to floor not tools and thats should do it...go to bissell.com to read and print manual so you can double check everything
Feb 10, 2009 | Bissell 9500 ProHeat 2X CleanShot Upright...
Bissell 9500 ProHeat 2X CleanShot Upright Deep Cleaner, Red Berends Vacuum Logo
426 people viewed this question
Top Bissell Vacuums Experts
CJ C
CJ C
Are you a Bissell Vacuum Expert? Answer questions, earn points and help others
