Question about LG KU990 Viewty
Changing menu display
Somehow the menu is now permanently a big grid in the middle of my screen, how do i get rid of it!!! I cant see any pics or anything anymore :(
Can you notice the two faint, ...chevrons left and right about two thirds of the way down the screen? tap one of those and it slides the front page back on and puts that shortcut menu back out of the way. I had that problem too for a couple of days.
Raist
Posted on Aug 14, 2008
Nikon coolpix s3300, no screen to take pics but screen works fine to view and use the menu
The only possible thing I can find, is the brightness of the screen. Perhaps it is adjusted to complete dark.
You also could try to press the button with the little camera on it. When you have a USB cable connected to the camera, the screen will be blank too. On my Powershot from Canon, there is a display button, when pressing it I can cycle between normal screen, Grid on the screen and screen off. I can't find anything similar in the manual of the 3300, but perhaps there is a function like that on your camera too?
Nov 10, 2013 | Nikon Coolpix S3300
How do you change language from Spanish to English on this phone? I put it on spanish somehow and i cant get it back to english.
Hello
Using Settings
Settings contains many submenus that let you customize your phone.
Display/Info Features The Display/Info menu controls how the keypad and display appear: - changes the wallpaper that • Wallpaper appears on the idle screen. - sets the size of text on the display. • Text Size - changes the look of the display. • Theme - controls whether main menu • Home Icons icons appear on the idle screen. - controls backlight illumination. • Backlight133 Customizing Your Phone - controls whether the time and date • Clock appear on the idle screen; sets time and date format; sets year. - controls whether the items on • Menu View your main menu and Java applications menu appear as large icons or a list. - sets large digits to appear on • Large Dialing the idle screen when you enter a number. - sets the language that your phone • Language displays.
for more information Get the manual from here http://www.motorola.com/staticfiles/Support/US-EN/Mobile%20Phones/i850/US-EN/_Documents/Static%20File/i850_UG.pdf
Hope this helps if so do rate the solution
Jan 05, 2011 | Motorola Mobility i850 Cellular Phone
My LC320SLX keeps displaying some weird screen randomly and at random times when I press any button on my remote that displays the following words from top to bottom. Code: ZS77SC320SA-134, Pic Code: US...
you should be able to exit using the power button. Funai needs to address this issue, using many universal remotes with their TV's can access this menu, this menu is used for diagnostics and is not supposed to be accessible by consumers.
Oct 02, 2010 | Sylvania LC320SLX 32 in. LCD TV
How do you get rid of the black box in the middle of the screen?
Somehow you have turned on the Closed Captioning. Navigate the menues to the section controlling that and turn it off. That should resolve this.
Dan
May 24, 2010 | JVC AV-27230 27" TV
I accidentally pressed the 2nd button and then the left side arrow button and now I have this black grid on my screen that I cant figure out how to get rid of if I tilt the screen I can see what I'm trying...
Displaying the grid on the screen is a graphing option accessed through the command GridOn. To turn the grid off, press [2nd][ZOOM] (FORMAT). Use down arrow to reach the 3rd line. Highlight GridOff and press [ENTER]. Press Graph to return to the graph screen.
How you activated the GridOn command by a single press of a button is a prowess. I wish you could teach me this legerdemain.
Hope it helps.
Nov 05, 2009 | Texas Instruments TI-83 Plus Calculator
How do I get rid of the icons on the main screen on my nokia 6210
Go to settings and look for menu display. there set the menu displau to text and not grid.
Jun 30, 2009 | Nokia 6210 Navigator Cell Phone
Accidentally changed height somehow while using remote, now "squeezed"
ou will need to adjust that via the service menu. Toshiba has 2 ways to access it on various models I will post them both. first way
1. TV turned on
2. Press 'Mute' button on the remote.
3. Press 'Mute' button on the remote again and hold.
4. Press the 'Menu' button at the TV.
You are now in the Adjustment mode
4. Use the 'Channel up'or"Channel dwn' to select the item.
5. Write down the old value of the item before changing.
6. Use Volume up and down adjust the value.
7. When you have made all the adjustments you want turn the set off to exit.
Feb 10, 2008 | Toshiba TZ50V51 50" Rear Projection...
Screen not displaying whole letters because of horizontal and vertical lines
I've had the same problem. A temporary fix that I have found is to turn up the contrast all the way (press [2nd] then hold down the up arrow) until the screen becomes mostly black. Then turn the contrast back down (press [2nd] then hold down the down arrow) until it is at a normal level. If you can get rid of all the white lines when you turn up the contrast the screen will be back to normal. Unfortunately this does not permanently fix the problem because I cannot get rid of all the lines and it seems to be getting progressively worse each time it start up the calculator.
Oct 24, 2007 | Texas Instruments TI-83 Plus Calculator
LG KU990 Viewty Logo
91 people viewed this question
Top LG Computers & Internet Experts
Alun Cox
Are you a LG Computer and Internet Expert? Answer questions, earn points and help others
