Question about Brother HL 5140 Laser Printer
Brother HL-5140 cleaning page?
I need to do a cleaning page on the above printer as it has background smudges after changing the drum. How do i do this?
  • 138 Answers
There isn't a cleaning page on a Brother 5140. If the smudges are about 3.5 inches give or take a little and the same each time in a line it's probably the drum is damaged. If they are closer like 1-3/8" to 1-1/2" it will likely be the toner cartridge.
If it spaces out a more, something like 2-1/2 it will be the fuser.
Sounds more like toner cartridge though.
Hope that helps you.
Posted on Aug 26, 2008
Brother HL 5140 has black specks on the page
There's probably something wrong with the drum unit. I would check the manual on how to change the drum unit. Good luck!
Dec 30, 2011 | Brother HL 5140 Laser Printer
I have a brother HL 5140 and I put in a new drum and now the left side of the page does not print.
Hello
Probablly the laser sendiing unit is dirty. Take out the toner look up at inside there is a place in the top inside above the drum in the middle carfully wipe inside small **** with a cloth and blow out with canned air
If that doesnt solve the problem then you have a bad laser,its hard to tell with out me testing them but the image is put one the paper with the laser- drum- toner-fuser working together so that should be the culprit
Jun 29, 2011 | Brother HL 5140 Laser Printer
Brother hl 5140 drum light comes on then off every 4
With the front cover open, press and hold down Go button until all 4 LEDs are lit. Once all 4 LEDs are lit, release the go button, then close the front cover.
This will reset the drum counter.
Mar 27, 2010 | Brother HL 5140 Laser Printer
Brother HL 2040 prints extremely light and seems to smudge? Just changed out the tone cartridge and no change.
I'm not sure if the drum is going out or not. How many toners have you used? The drum is rated at 12,000 pages and the toner is supposed to yeild 2500 pages, so 4 or 5 toners ought to finish the drum. Did you clean the area around the drum? I don't think you're supposed to touch it, but I've never had to touch my 7240 in 4 years, except to change the toner.
The good news is the toner will fit in more than one Brother machine and the printers are inexpensive. It almost makes buying a new machine more economical than a drum :-}
The HL printer is Manufacturer Discontinued, the new ones use a 360 series drum and toner, and the MFC's (7220 etc.) are about $200 vs. $116 for the drum. Hmmm.
Might be time to upgrade.
Carl
Jan 08, 2010 | Brother HL-2040 Laser Printer
Ghosting on prints
Wrong paper type can cause this, also if it is damp or too thick. Also check that you have the correct type of paper (thickness) selected in the driver. Ghosting can also be caused by a faulty drum unit, since you just replaced it maybe there is warranty left on it?.
May 24, 2009 | Brother HL 5140 Laser Printer
MY brother HL-5140 quits printing,and also has a black vertical line down the page before it quits. After a while, say 30 to 45 minutes, it will start printing again. But there are black smudges on the...
Sounds like a fusing error ... If your able to wipe the toner off the page its a fuser unit problem (replace fuser unit) If toner is sticking to paper but the print quality is poor , replace the drum unit  (PCU)  good luck
Feb 21, 2009 | Brother HL 5140 Laser Printer
Printing black smudges across the page at 10 cm intervals
Most likely cause by the drum unit. Replace drum or upgrade printer.
Jan 24, 2009 | Brother HL 1030 Laser Printer
Brother HL 5140 Laser Printer Logo
482 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
