Question about Brother 925D Serger
Presser foot where can I buy a press foot for my 925d serger
  • Anonymous Dec 29, 2008
    I lost it,where can I buy a new one
Http://www.smscanada.com/search.php
Posted on Mar 24, 2009
Does anyone have a suggestion? I have threaded the machine correctly but I cannot get the machine to sew.
You have a nice serger, so let's start with some basics:
Is your serger cleaned?
Go back to the instruction book and set the entire machine to the factory settings. For example, set all the dials to tension 4. Use quality thread which is made for your spool holder. Usually cones of thread work best. Use an appropriate fabric, not sheer, not very heavy drapery fabric. Make absolutely sure it's threaded properly. Finally, make sure all the threads are under the presser foot.....then start serging. If the serger still won't serge without tangling, it might be good to have it serviced. I find that buying a new serger is more useful than having a worn out one serviced. Good luck!
May 05, 2014 | Brother 925D Serger
I have a Bernina Bernette serger 004D/004 and the presser foot has fallen off the machine can I fix this myself?
The presser foot is a 2 piece thing, remove the foot, then remove the top bit that the foot attaches to (the shank). Look at the bottom of the shank while pressing the little lever or button on the back of it, you will see how the foot attaches to the shank.
Oct 18, 2011 | Bernina Bernette 75
My needles hit and seperate on top loop when I try to use my Brother 925D serger. What can I do to fix this?
Make sure that you thread your machine in the exact sequence your manual tells you to, and that when you thread your machine, it is powered off, and the presser foot is up. If, you have a hard time seeing your manual, go to www.brother-usa.com support and then choose home sewing and embroidery, and then select your model # 925d and download your free manual. I have the 1034d and did not thread the upper looper first (3rd from the left) and it caused me grief. Now, I remember to follow the instructions exactly. Seems that the thread will loop around the lower looper if you don't do it right. Try this and if that does not work call Brother at 1-877-276-8437 and ask them.
Apr 16, 2011 | Brother 925D Serger
Foot on a Brother 925D serger fell off. How do you put it back on?
It looks like you just screw it on. It had to be loose to begin with. If, that isn't right, call Brother at 1-877-276-8437 and ask them. To me it doesn't look any different than a regular sewing machine foot. Good Luck
Oct 06, 2010 | Brother 925D Serger
I dont know how to thread this serger. i dont
Have you opened the front of the serger to see if there is a threading guide.
Basically:
Lift the thread antenna to it's highest position.
Lift the presser foot and set the tensions to zero.
Turn the handwheel so the loopers are at their highest point.
Begin with the upper looper (first thread cone on the right/ end of looper is pointing toward the presser foot). .
Second spool is for the lower looper (end of looper is pointing away from the presser foot).
Third spool, right needle; fourth spool, left needle.
Be careful that the threads do not cross during the threading of the loopers.Follow all the guides, taking the thread under the presser foot and to the left side of the serger.
Set the tensions back to 3 - 6 and lower the presser foot. Sew a few inches and if the threads knit into a chain, you can then do a test sew with fabric.
Simplicity's Simply The Best Sewing Book has good information with regard to using a serger that you may find beneficial.
Feb 24, 2010 | Sewing Machines
I don't have a manual for my Baby lock Pro line model # BL4-738 NS. It was given to me and I have threaded it accordingly to the diagram on the machine but it won't pick up the stitch.
You will have to order the manual from a Baby Lock dealer.
This model may have to be threaded in a certain order.
Try raising the presser foot and setting the tensions to zero.
Turn the handwheel so the upper looper (the curved one) is at it's highest position - there may be a mark on the side of the serger where you align the handwheel for this.
Thread the upper looper and then the lower looper and then the needles.
Pull the threads under the presser foot and toward the side of the serger.
Set the tensions back to 4 - 6, lower the presser foot.
Hold onto the thread tails and gently press the power pedal to begin a thread chain before serging fabric.
Feb 16, 2010 | Baby Lock Eclipse Serger
No manual
google brother 925d user manual and it will take you to the brother site to download the manual i had to do the same thing! good luck its just time consuming to print it off. hope this helps
Sep 01, 2008 | Brother 925D Serger
Sewing Machines Logo
Top Brother Sewing Machines Experts
Tally Girl
Tally Girl
Irene Tulloch
Are you a Brother Sewing Machine Expert? Answer questions, earn points and help others
