Question about Norcent Technologies LT-2090WBK 20 in. LCD Television
Does this TV receive digatal or analog signals
  • Norcent Tech... Master
  • 8,457 Answers
Digital.All LCD and Plama tvs now are able to receive DTV free air digital signal broadcating from with a good roof or a good digital antena,99.9% tv broadcasting tv signals in the world are now broadcasting in digital tv signal now.
Posted on May 16, 2011
SOURCE:
What does DTA mean on my tv/dvd 22" tv
DTA is a Digital Television Adapter (digital-to-analog converter box) It is a television tuner that receives a digital television transmission and converts the digital signal into an analog signal that can be received and displayed on a older analog tv.
Jun 06, 2013 | Televison & Video
All ready used box once. Now going back to antenna. Not receiving display or menu on T.V. screen.
All TV over the air is transmitted as a digital signal now. In order to see it on an older TV (read Analog), you must have a signal that you can receive(antenna hook up) and a digital to analog converter box. That box allows you to see your digital signal on older TVs. The signal is sent from the antenna to the box via a RF connection, and decoded to channel 3 or 4 (your choice). for further information see Consumer Report at:
http://www.consumerreports.org/cro/electronics-computers/tvs-services/non-digital-tvs/digital-converter-boxes/digital-tv-converter-boxes-first-look-3-08/overview/digital-tv-converter-boxes-first-look.htm
Jan 09, 2011 | Insignia Digital-to-Analog Converter for...
Getting digatal no analog
There is not enough information to give you an answer. How do you know you are getting digital and not analog. Most LCDs are only digital even on their TV antenna connection using the ATSC tuner, so I don't really have enough information. If you are referring to the TV antenna, I assume that you have an antenna designed for this purpose.
Nov 30, 2010 | Acer AT3705-MGW 37 in. LCD Television
Do i need a converter box for my rca true flat 27 in? if not how do i connect a digatal antenna i have lost my manual
Your TV will require a Digital Converter Box to recieve over the air Digital Television Signals. You will need to hook up the antenna to the converter box and then hook your converter box to the TV. Hooking your television directly to a digital antenna will not get you Digital signals...only analog signals.
Jun 25, 2010 | RCA TruFlat 27F520T 27" TV
HP pc with built-in tv tuner
Have 9, 5 and 13 turned entirely digital as yet, so as to leave you without their signal?
From what you say, the tv tuner in your HP receives analog signals better than or instead of digital signals the stations you can receive may be analog while 9, 5, and 13 may have dispensed with their analog transmitters.
They don't have to until June, since the changeover was delayed from the original February cutoff date by Act of Congress. It is actually easier to receive a digital signal than an equally powered analog equivalent so the fact that your system worked so well with analog signals bodes well for the efficiency of your indoor antenna arrangement, though you may have to replace the possibly analog receiver in your pc with a usb digital thumbdrive like model to continue after the changeover is final.
Here's a tip...if the receiver in your pc resembles a square aluminum tin can, mounted on a PCI card in one of your slots, it is very likely analog and not digital.
Usually these receivers (or actually TUNERS) are heavily sheilded while digital receivers do not require the same amount of sheilding to avoid interference with other components, which is the concept of the big square tin can, that a digital tuner does not require.
Mar 27, 2009 | Computers & Internet
Does anyone know if this tv is analog
the tuner on this tv will pick up the analog and the digital broadcast stations.
so yes you can get the analog stations , but you also get the digital or hd broadcast stations that are available
Mar 02, 2009 | RCA D52130 52" Rear Projection Television
I have a DirectTV DVR HR10-250 that I stopped the monthly service, and use it to watch free Off-the-Air broadcast HD channels. I can not seem to record them by default. Is there any way or "hack" that I...
in feb when free air signels become digatal you should then be able to record your programs because your box is set to a digatal format and will not record the old analog signels
Dec 07, 2008 | Hughes HR10-250 DirecTV / TiVo 200-Hours...
How do I tell my 53FDX20B to recognize digital instead of analog?
You may have been lied too! there should be a test in your area and if you tv does not pass your local test your tv is not digatal ready!you may have to buy a converter
Dec 06, 2008 | Hitachi 53FDX20B 53" Rear Projection...
Receiving HD (fios) signals on an analog TV
You can receive the signals over Fios the same as cable.
Dan
Oct 29, 2008 | Sony FD Trinitron WEGA KV-36FS120 36" TV
Norcent Technologies LT-2090WBK 20 in. LCD Television Logo
185 people viewed this question
Top Norcent Technologies Televison & Video Experts
Jaime Hernandez
Audrey Messer
Audrey Messer
Are you a Norcent Technologies Televison and Video Expert? Answer questions, earn points and help others
