Question about Lexmark Office Equipment & Supplies
Power is on but it reads Cover Open on screen. It will not power off or anything unless I unplug the cord. I checked the cover and it is not open? What can I do?
    Problem Solver:
  • 25 Answers
There may be a stuck flag in the way of the door/open sensor. Open the door slow, and look to see if all parts that are supposed to move, are actually moving.
Posted on Aug 14, 2008
Cover open lexmark3480
It could be that one of the cartridges is not seated properly in the cartridge carrier. Please try this approach to fix the problem.
1. Make sure the printer is on.
2. Open the printer cover. The print cartridge carrier moves and stops at the loading position, unless the All-in-One is busy. Note: If the carrier does not automatically move to the center, turn off the printer/unplug the printer from the power source and then slide the carrier to the center.
3. Remove both cartridges from the carrier.
4. Close the printer cover.
5. Re-brick your printer. Pull out the power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds.
6. When the printer turns on, reinsert one cartridge first.
7. Close the printer cover and check for any errors.
8. If no error appears, reinsert the other cartridge. Close the printer cover.
9. Replace whichever cartridge is causing the error to appear with a new cartridge. Then try to print a document again to verify that the problem is fixed.
Dec 21, 2011 | Lexmark X3480 All-In-One Printer
Lexmark 3400 printer display says cover is open. Cover is not open. apparently it is mis reading status. will not print or turn off. Its stuck. What do I do? D.S.T
do a hard shut down..unplug power cord...that would make it go off. them leave it off for 2-3 minutes..then turn it back on and let me know the status
Jun 05, 2008 | Office Equipment & Supplies
Tip
Canon Service Error 5202
Service Error 5202 solution for ip1800 / ip1900<br /> <br /> Steps: <br /> 1. turn-on printer, still blinking and a error message on screen, open cover. <br /> 2. While printer cover is open, unplug the power cord at the back. Of course it <br /> turns off. <br /> 3. Remove all cartridges, clean the contact points and then insert them back <br /> properly. Move the entire cartridge to its parking area. <br /> 4. Close the printer's cover, plug the power source, turn the printer on. <br /> <br /> 5. It should be working fine now. Mabuhay!!!
on Mar 24, 2011 | Office Equipment & Supplies
Message reads "cartridge short press power key"
The error indicates that one or both of the cartridges has a short circuit. Please follow the steps below to identify and fix the problem:
5. Rebrick (pull out power supply, black box where the power cord is plugged in at the back of the printer, and put it back after 30 seconds).
If problem continues, please contact Lexmark Technical Support Center for additional assistance.
Sep 11, 2011 | Lexmark X83 All-In-One InkJet Printer
Canon copier ir3300 shows front cover open
Your Canon copier ir3300 shows front cover open, but actually it is not. It could be the sensor problem, try with this Power off the printer then unplug the printer's power cord, wait 5 seconds then replug the power cord in. Hold the Power button for 6 Beeps and release the Power Button. This will reset the printer and should resolve your problem.
Mar 26, 2011 | Canon imageRUNNER 3300 All-In-One Laser...
It tells me the cartridges are empty, then when i open the lid it says no cartridge! its not been used for a few months, and i refill them with generic refills...any thoughts? tried the switch off and on -...
Hello ,
Start by opening your ink cover and read the LCD screen; this will alert you as to which ink cartridge is not being recognized; make sure the cartridge that it is telling you is empty has been changed.
If the unit is still not recognizing the cartridge you have changed, follow the steps below.
  1. Unplug the power cord for the printer unit.
  2. Open the ink cartridge cover and remove all ink cartridges.
  3. Close the ink cartridge cover.
  4. Plug the power cord back in.
  5. Reinstall the ink cartridges.
Make sure that your ink cartridges are full and that they are genuine brother inks; refills or generic ink cartridges are not guaranteed to work properly.
Thanks,
Pat
Mar 29, 2010 | Brother MFC-620CN All-In-One InkJet...
Message no cartridge when installing new cartridge. I have installed new ink cartridges but the printer keeps coming up with the message 'No Cartridge' Reinstall the cartridge. I have done this three or...
Hello ,
Thank you,
Pat
Mar 28, 2010 | Office Equipment & Supplies
SCREEN SAYS BACK COVER OPEN.WHERE IS BACK COVER?
Hello rtbris182,
The "back cover open" message is usually caused by a paper jam inside the printer.
Follow these steps to rectify the problem.
1. Unplug the power to the printer.
2. Open the back and front cover.
3. Remove the drum and toner, this may be difficult because it may be stuck; don't be afraid to pull hard, you wont break anything.
4. Check for any foreign objects, most likely a peice of paper.
5. Reinstall the drum and toner.
6. Make sure to close the front and back covers.
7. Turn the power back on.
If the message stays after all this, there may be a sensor not working.
Thanks,
Pat
Mar 25, 2010 | Brother MFC-7820N Printer
Canon ip1800 printer not working
when the yellow led flashes is never a good signal... you should check the manual's printer to find out the error code meaning "4 yellow flashes and 1 green)
Usally it's the waste tank that is full, in this case you need to:
  1. Push “resume” for 5 seconds for canon IPXXXX.
  2. Push Power switch then remove power cord.
  3. Insert plug power cord while pressing “power switch” at the same time.
  4. Push Start/reset by step 2 continue Wait display shown “0′
  5. Push + change display from “0′ to “1′
  6. Push color button 2 times
  7. Push Power switch again , Printer will print 1 page
  8. Open cover
  9. Unplug power cord
  10. Take out ink cartridge #40 and #41
  11. Insert plug again
  12. Push power switch
  13. Open cover (scan cover)
  14. Insert ink cartridge #40 and #41 again
Jul 18, 2009 | Canon PIXMA iP1800 InkJet Photo Printer
Zvonko jelusic from belgrade
The print carriage is stuck.
Solution
  1. Open the top access door on the printer.
  2. Remove the print cartridges.
  3. Close the print cartridge flaps after removing the print cartridges.
  4. Turn the printer off and then on again.
  5. Replace the print cartridges.
  6. Close the top access door.
If the resume light continues to blink after the print cartridges are released,
OR
the print carriage is stuck or makes a grinding noise, follow these steps.
Solution
  1. Lift the top cover to the printer.
  2. Turn the printer off and then on again.
  3. Unplug the power cord from the back of the printer when the grinding noise starts. Unplug the power cord from the wall outlet.
  4. Move the print carriage towards the middle of the printer (this procedure may take a couple of tries to get the timing correct).
  5. Take out the print cartridges and close the top cover.
  6. Plug the power cord into the wall outlet. Plug the power cord into the back of the printer.
  7. Open the top cover, reinstall the print cartridges, and then close the top cover
Solution
  1. Open the top cover.
  2. Unplug the power cord from the back of the printer. Unplug the power cord from the wall outlet. Wait a minute or so.
  3. Plug the power cord into the back of the printer. Plug the power cord into the wall outlet
Sep 22, 2008 | HP DeskJet 5550 InkJet Printer
47 people viewed this question
Top Lexmark Office Equipment & Supplies Experts
Roopesh S
Roopesh S
Sanath Kumar V
Are you a Lexmark Office Equipment and Supply Expert? Answer questions, earn points and help others
