RCA 52 I was told that I need to replace a fuse fl231. 2 questions...where is it located in the tv and what does it look like? When I opened the tv, I found what was marked fl231 and it is a red, flat, square plastic thing that is soldered into the board. It was located in the bottom left corner area of the board. It looks more like a copassitor than a fuse. Can you help me? Also, unable to find the part at car store or Radio Shack.
    An expert whose answer gotĀ voted for 100 times.
    Champion:
  • 317 Answers
That the part.
Posted on Aug 14, 2008
RCA D52W26- 52 " rear projectio- 3d
try to inspect the convergerce power supply and the convergence output module for cold solder joints around the mos fets...i had seen many of them on the same condition.
Jan 22, 2010 | RCA D52W20 52" Rear Projection HDTV-Ready...
I have an RCA D52W23 TV convergence problem
bd pt no is 264103 check your local rca dist and servicers
Oct 23, 2009 | RCA D52W23 52" HDTV CRT TV
RCA P52755BA 52 inch tv looks 3D
You have a problem with convergence and all you may need to do is replace a fuse. Look up convergence for your tv model and hopefully you will get an answer as to where the fuse is located and how to replace it. Very common for RCA tv's
Aug 30, 2009 | RCA P52926 52" Rear Projection Television
52 inch rca projection tv turn tv on and there are horizontal
Go to menu then setup look for convergence if you Do NOt see convergence then you have a open fuse FL231 Located on right side of FBT there is 3 in a roll small brown rectrangle looking caps but they are Fuses it will be in the one in the middle.
Aug 18, 2009 | RCA D52W20 52" Rear Projection HDTV-Ready...
Rca 52 inch convergence
You have a opened fuse FL231 next to flyback transfomer are 3 Fuses they look like small brown squares/ Fuse in the middle is bad when you do not have convergence listed in menu.You can pull the top off of these fuses .
Nov 06, 2008 | RCA P52960 52" Rear Projection Television
Adjust projection tv does not appear in the sceen menu
Its right next to the Flyback which is a large transformer about the size of a fist with a large red wire coming out of it. The fuses are located near that they are 3 fuses fuse FL231 is the center fuse.
May 19, 2008 | RCA P52926 52" Rear Projection Television
RCA R52WM24 52 in. HDTV convergence IC location
the rca itc222 chasis uses no stk the convergence is controled with transistors... the convergence amp board is located above the main signal board(green board)... it can be identified as the one with several heat sink fins on it. FL231 is related to convergence.. there has been a problem with this fuse when it blows the processor doesnt know it is a projection set so it turns it into a regular tube tv. Here at the shop we have found number one reason this fuse blows is poor solder connection on the flyback. So replace the fuse and reflow the solder connection on the flyback and around that area also the horizontal transistor and then see if that doesnt fix the problem.. if you have an more trouble ..... willie@fordtv.com
Feb 29, 2008 | RCA R52WM24 52" HDTV Projection Television
Power outage fried my TV
Usually,the AC fuse is located by following the AC cord into the tv and the culprit will be close to where the cord attaches.Note:if the replacement fuse blows,then additional parts need to be changed.
Sep 30, 2007 | RCA D52W20 52" Rear Projection HDTV-Ready...
It is dead
Of course it is very difficult to say what is wrong when all I am told is that it is dead. First I would check the main fuse and if it is good then I would look for and replace a 1000uF 25V cap on the secondary side of the switching power transformer. This should be done by someone with experience.
Jun 25, 2007 | JVC AV-27260 27" TV
RCA 52" Big Screen TV model;P52920BL Chassis;PTK195KB PICTURE BOWED AFTER FUSE BLOWN.
You have bad convergence IC's.. If your not experienced in troubleshooting electronics or soldering, you should have a trained tech take a gander at the set. Its not worth risking life and limb to save a few bucks, Good Luck
Jul 30, 2006 | RCA P52920BL 52" Rear Projection...
Televison & Video Logo
115 people viewed this question
Top Televison & Video Experts
