Question about Dometic RM2652 Refrigerator
Dometic RM2652 not running
Hello, my dometic fridge is not running. The power button does not lite up at all. I checked the fuses and all were fine. I found a web site that said the power board might have gone out. It does act like it has not power, but all fuses are fine.
  • william_gree Aug 19, 2008
    Thanks for the info. Did not know about the reset button.
  • potatoflake Aug 23, 2008
    My unit lost all power as well. On/Off doesn't work, no lights inside. Checked all breakers and fuses in trailer and also the fuses in the control module of the refrigerator. All outlets were checked and all work fine. Disconnected from AC and used battery power only, but no difference. Thinking the ON/OFF control is separate and there is a fault there. Manual for refrigerator doesn't provide much help.
Dometic RM2652 will not run on gas... check light does not come on ... can hear the gas valve click
Posted on Sep 13, 2009
Mine is doing the same thing, I do not have the problem solved yet but I can tell you to start with the reset button located on the heater. (Thermofuse) small black button you push. then restart your troubleshooting. This button kills all power to the unit, lights, etc etc.
Posted on Aug 14, 2008
  • Dennis Anderson
    Dennis Anderson Aug 18, 2014
    Thanks for that I have a domestic RM4605 and had the same problem whole fridge dead after installing new 240V heater element and your post directed me to the eset of the tHermofuse. I have just run 12V Circuit to the fridge and the control panel lit up. Thanks again
  • 51 Answers
Check for voltage (DC) at the source input just before the board on the outside under the coils make sure the connections are not corroded. If you have less than 10.5it will not work. If you have correct voltage remove the board and test at repair center that sales boards.
Posted on Sep 07, 2008
Dometic RM2652 was working fine then stopped - no lights at the control panel above the doors.
Usually there is a short in the system when fuse is blown. Check the cord as sometimes mouse can damage the cord. It is a posibility.
Check power to the electronic board.
Jan 28, 2015 | Dometic RM2652 Refrigerator
My Dometic RM2652 fridge suddenly quit cooling. No amonia smell, no yellow residue around cooling unit. Gas ignites, lites work.
what is the yellow residue around heating element? my fridge just isnt working right and sometimes stops all together, the freezer worked until lastnight but fridge hasnt cooled right for a week or so.
Aug 03, 2012 | Dometic RM2652 Refrigerator
Hello, my dometic camper fridge runs great on gas but just clicks when i switch it to electric...??? any advice thanks Stephanie
The mains heater has a different thermostat. Check power to the heater, and the back coil is getting warm
Apr 27, 2012 | Dometic RM2652 Refrigerator
I Have a Dometic RM2652 it heats up in the back, but, neither the fridge or freeze will cool down.. I've checked the fuses, tried gas and electric.
First thing I would do is check this dometic site for recall information. Have model and serial number ready.
Jun 15, 2011 | Dometic RM2652 Refrigerator
Have dometic fridge in in 2007 all
Check your 12 volt ground
Check the fuses in the back under the cover
Other than that sound to be a bad control board
Oct 23, 2009 | Dometic RM2652 Refrigerator
Unplug the fridge. Remove the cover from the circuit board, unplug the 2 wires going to the heat element and do an Ohms reading should be 35-45 Ohms. If the Ohms is good then you need a circuit board as long as you have checked the 110 volt fuse on the circuit board.
Thanks for using Fixya
Mar 30, 2009 | Dometic RM2652 Refrigerator
Dometic RM2652 Refrigerator Logo
1,621 people viewed this question
Top Dometic Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Level 1 Expert
Are you a Dometic Refrigerator Expert? Answer questions, earn points and help others
