Question about Gaggia Titanium Espresso Machine
Steamer will not work
With the machine on and functioning normally otherwise, I go to turn the steam valve open to heat the milk and nothing happens. It makes no sound either. Any ideas?
  • 4 more comments
  • rtmumper Aug 27, 2008
    That is not the problem as with a blocked frother you would still hear the pump running. In this case nothing happens. It is as though the knob is a dummy knob.
  • Anonymous Sep 07, 2008
    I have the same issue after "Ventilate" message. Did you find what it was?
  • Anonymous Sep 30, 2008
    yes same problem after about a year of use we are hitting this one. referred to elsewhere as "ventilate" problem. That is ventilate warning message displays, and mchine will not steam or make coffee. Solution described in manual has no effect. Trying various of the suggested solutions but little joy so far. Leaving machine for a few hours seems to allow it to produce coffee again, but as soon as we attempt to steam we hit the dreaded V message again
  • chrisg666 Nov 10, 2008
    Same as RT Thumper .... the factory settings resets the coffee machine part, but zero from the steam part... as if it was a dummy knob .... well put.
  • Pejayar Feb 04, 2009
    Problem very similar, except that to get rid of the VENTILATE command and to get the machine making coffee again, have to do a factory reset.
    The ventilate button felt a bit soggy, so stripped back that part of the machine.  Not any help!
  • Anonymous Feb 16, 2009
    My machine said to ventilate, it did not work so i did factory setting now my coffee comes out but my steamer does not work. I turned on the knob but nothing happens it makes no noise at all. What else can i do
    Problem Solver:
  • 4 Answers
In order to produce steam, the steam knob has to activate a "working" microswitch when you turn it. If this microswitch has malfunctioned, the pump will not activate.
Posted on Feb 18, 2009
  • 3 Answers
Sounds more like the ring clip has come off. Should be easy to replace with a screw driver and pair of pliers.
You'll need to remove the mains cable. Remove the water tank, take out the "bypass" hopper (screws) and remove the bean hopper (screws, make sure you get as many beans out as possible first!) then two more screws at the back hold the hotplate on top. Once you've lifted the hotplate detach the power to the hotplate heater element (put some tape on the wire connector and stick it so it doesn't get lost inside).
Other side of steam knob has a spring clip holding it onto a valve assembly (I had to replace this resin valve with a new one, the new one sent was metal and a lot better constructed).
HTH
pbhj
Posted on Nov 13, 2008
Here is what I have found to correct the Ventilate issue, go to the front panel and say yes to factory settings.push the hot water button and open and close steam knob until hot water starts flowng,let it drain in the sink and fill the bin 3 or 4 times . this will get out the air bubbles and you will be able to make coffee and steam milk,worked for me.
Bennett
Posted on Oct 15, 2008
  • Gaggia Expert
  • 109 Answers
Make sure your milk frother is not blocked.
Posted on Aug 26, 2008
I have an Ariete coffee machine the steamer takes along time to heat up not much steam coming out
if the steamer is not been in use for a ling time is possible tha the valve got stuck. You can try to open and close the steam handle repeating that very often while steam get out. if it does not work try to make a cicle of water mixed with salt, just start the coffe maker, warm up and start WITHOUT COFFEE, you repeat that several time to obtain clean water from the fiter, warm up for steam function and start to open-close the steam handle on the right of the coffee maker body. If that doese not helps you must change or repair the rubinet-valve of steamer, apply to assistence.
Sep 08, 2013 | Ariete Cafe Retro Espresso Machine
The steamer dosen't work at all. When the knob is
First you should remove the end tip of the steam hose and try to clean the steam holes with a pin. The steam should come frealy withou the end tip. If not then you shoul desasemble the steam tap , clean it and put it back together. The problem is only caused by dry milk or milk with chocolate. Even if you manage to have some steam then the problem can be solve by using the steamer warming just water in a glass and leave it all nigh long inside the boiling water in glass this will meld the dirt and will gos away.
Feb 09, 2010 | Rancilio S24 Espresso Machine
Francis francis milk steamer not operating
Steamer tubes can get plugged up with dried milk and/or calified water deposits in the tube.
With the machine unplugged, turn the tube up to check it, Clean it with a small guage wire.
Soak it in a small cup of vinegar, if needed.
Further cleaning, you can add a bit of vinegar to the water and steam it thru...
Let me know how it goes.
K
Jun 03, 2009 | FrancisFrancis! X1 - Stainless Steel...
Check the end/nozzle of the steam wand, if you open the wand and while getting nothing it is hot, then the nozzle is blocked use a paperclip to clear the hole at the end of tip. If you have done this already and still no steam then it is clogged where the steam valve connects to the boiler.
May 19, 2009 | FrancisFrancis! X1 - Stainless Steel...
Steamer is not getting hot enough.
Try using the milk clamp on the tube going into the milk.Tightening it will make your milk hotter.
Your steam wand however, is a different problem.
First, check in the programming that the steam temp. is 125 celcius.
If it is, and none of the tubes from the steam wand to the boiler valve are blocked, your boiler temp. sensor may be faulty, in which case, you will need to replace that.
Mar 13, 2009 | Nuova Simonelli Microbar Espresso Machine
Milk froths at 1st then doesn't after 1 week
Ensure first that you are using the steam pipe in the correct way to froth the milk.
If it still does not work, that means that the steamer is not generating enough pressure steam.
This happens either because there is not enough heat, or if you release the steam when pressure is not enough.
If you think you are doing everything in the right way, then contact the company and insist for having the machine fixed or replaced.
Nov 07, 2008 | Krups XP 1500 Espresso Machine & Coffee...
Steamer on gaggia titanium
a. Possible air in the system. Switch to hot water iso steam, let warm water pas for a minute by turning the knob fully open. Stop tapping warm water (close the knob) and switch the machine to steam iso water. Try to get the steam by fully opening the knob (pump should start running).
b. Solidified milk in the system blocking internal tubes. To avoid this always purge the system (shortly open the steam to an empty cup or a towel) after you steamed milk to avoid milk being sucked back into the system due to condensation of steam (this creates a vacuum and reverse flow). To resolve the blocked tubing: clean the nozzle and try flushing the system (tapping warm water).
Aug 24, 2008 | Gaggia Titanium Espresso Machine
Steamer function doesn't work properly
We just had the very same issue and I went back to the product directions--we took things apart and thoroughly cleaned everything, especially each part of the sleeve. Once we put it back together we sat it next to the sink and ran it on steam with the water/steam going into the sink until it was running cleanly with a good steady flow. Fixed!! I'm so pleased because we love this machine...I'm totally addicted! Good luck.
Apr 19, 2008 | Nespresso C190 Espresso Machine
Hamilton Beach Espresso Machine not working
When you turn on the steam switch, does the steam light turn on, then eventually turn off when it comes up to temp?
If so, your wand may be plugged with a dried plug. I have resolved this by pouring boiling water into my steaming pitcher and soaking the wand for several minutes, then fire up the machine and heat for steam, then blast it out.
Might take a few tries. You may also need to run a thin wire, like a guitar string, up the wand to help free up the plug.
Jan 07, 2008 | Hamilton Beach 40729 Espresso Machine
Briel espresso machine
Try opening the frothing valve by turning the dial and force water through it instead of steam by pressing the middle, coffee button. You may be experiencing vapor lock. Once the water comes through the steamer valve, turn the steamer knob off and release the coffee button. Then try the steamer button with the steamer dial open. This may do the trick.
Dec 02, 2007 | Briel Domus Due Espresso Machine & Coffee...
Open Questions:
See all Gaggia Titanium Espresso Machine Questions
Gaggia Titanium Espresso Machine Logo
449 people viewed this question
Top Gaggia Coffee Makers & Espresso Machines Experts
Oloyede Monsuru
Michael Vincent Cruz
Are you a Gaggia Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
