Question about Cat5e 10ft White 350MHz Stranded Snagless Patch Cord (CC71110WH)
Cat5e 350mhz wire
How can i use this wire to play online with my ps3 cause my wireless is too laggy for online play
  • 83 Answers
What you can do with the cat5 cables is plug the wire into the PS3 and the other end into your home router or switch. This might be a problem if your router or switch is in another room or so but it will most likely give you less lag.
Hope this helps, let me know if ya have problems connecting if you decide to use the cat5 wire but it should be about the same setup as using wireless.
Posted on Nov 11, 2008
  • gboardnvidia Nov 11, 2008
My ps3 freezes when i try to play online
Alexander, you left out some important info, so this is just guess work. Can you play games fine off line? If yes, then you are having a connection issue. First, WIRED? or WIFI? Connecting with the Wireless, will alwayes have a weaker signal, and lower bandwidth(mbps) Than if you are (HARD WIRED). Try using a CAT5 Ethernet cable and wiring directly into your ISP'S modem. When you do a speed test on the system, you are looking for around 10mbps or greater download speed. If you can't get at least 10mbps, then you will have system lags and hang-ups.
Mar 16, 2014 | Sony Playstation 3 (PS3) Console
Tip
My cat 5e
how to terminat cat5e cable either crossover or direct terminiting and how to arrange them fix it with the rj45
on Apr 16, 2008 | Cat5e 100 Foot Shielded STP 350mhz Network...
How to go online on playstation 3 to connect with friends and play games
Make sure an ethernet wire (CAT5) is connected from an active router or cable modem into your ps3. There are orange and green LED's on both your router and ps3. If they are blinking on the ps3 you know there is communication. Go into system -> network settings and run the auto configure. You should not have any more problems. Your CAT5 cable may need to be replaced if it old or has alot of kinks in it.
Oct 08, 2011 | Sony Playstation 3 (PS3) Console
I just bought my first ps3 in order to play some friends in madden online. I have everything connected and can go on the internet and watch netflix, the only things i can not do is access the playstation...
First make sure that your PS3 connects with your acces point eather wireless or with wire, te second step is configurate your PS3 for wire connection or wireless connection.
These settings are found under the network settings.
Also see the manual to see how you need to configurate the PS3 in detail.
Allso make sure when the PS3 is connected corectly to the acces point that the firewall of the acces point is not interfearing the connection.
May 21, 2011 | Sony Playstation 3 (PS3) Console
My D-link dir-825 router has been giving me poor signal
Hi Friend,
Firstly,u need to do following settings to u'rs belkin router: Default ip address of D-link dir-825 is 192.168.0.1
,so you can login to router setup page by http://192.168.0.1
1> You need to reduce MTU<Max.Transmission Unit> to 1400
2> Change wireless channel to 9/11
3> Wireless MAC ADDRESS CONTROL should be disabled for u're xbox
4> Reduce beacon interval to 50/75
5> Fragmentation Threshold:2306, RTS Threshold:2307
6> Disable the security/firewall of u're router
7> Do the port forwarding/trigerring;port numbers for xbox are:53,80,88,543,3478-3479,3658,5223,10070-10080
it will be good if u change wireless network name(SSID) as well as upgrade the firmware of u'rs router;so that it will reflect the effect & power down u're x-box while doing the changes in router.
If u need technical help in order to do the above changes in router have a words with belkin technical suppoprt.
Mar 19, 2010 | Computers & Internet
I was playing my ps3 online but when I changed the game I got a message IP address failed
This is a network connectivity problem so to resolve this check the network connection of your PS3 to your network whether its connected with a CAT5 cable or via wireless...make sure the network connection is still good and also restart your PS3 to establish the connection again....
Jan 03, 2010 | Sony Playstation 3 (PS3) Console
I have been playing previously before with no issues logging onto the madden 10 online. Now all of a sudden I cant even get in and servers always kick me out. Please help. Frustrated Madden 10 player...
It could be that they are doing server maintanence on the servers. I play Socom online and they have scheduled maintanence everyday. Did the game seem laggy the last time you played? Are you having any issues on PSN?
Oct 23, 2009 | Sony Playstation 3 (PS3) Console
Ps3 online
ps3 has a built in wireless adapter.rather than having wires all over, get a wireless router.connect the router to your modem with an ethernet.once you have the wireless router up and running,you will have whats called an "access point" for any devices to connect to wirelessly (within a reasonable distance),such as the ps3.
Dec 30, 2007 | Sony Playstation 3 (PS3) Console
Cat5e 10ft White 350MHz Stranded Snagless Patch Cord (CC71110WH) Logo
91 people viewed this question
Top Cat5e Computers & Internet Experts
KG John Justin
KG John Justin
Vuk B
Rishi Solutions
Rishi Solutions
Are you a Cat5e Computer and Internet Expert? Answer questions, earn points and help others
