Question about Canon Office Equipment & Supplies
The feed rollers on printer bj5100 ocasional fail to fully feed thru to printed dicharge phase . The next sheet is then drawn into the printer causing a jam up What do you suggest?
    Problem Solver:
  • 25 Answers
Sometimes isopropyl alcohol will aid in cleaning the rollers.
Posted on Aug 14, 2008
Lexmark X4550 all-in-one Paper feeds only half way then jams
Frances;
I'm not Lexmark certified; however, paper motion fails are generic in nature. Paper motion fail can be a bit difficult to diagnose at a distance...
* If it jams at every sheet then check to insure there is not a bit-o-paper stuck from a previous jam.
* If it has been an issue that has been increasingly getting worse than I'd replace the pick-up roller(s)
* Lexmark's support page for your printer is below. (You can also find a service prover too)
* Parts order for your printer is also below. You can determine at the support page if your comfortable replacing pick-up rollers in that model printer.
support lexmark com Service Parts
Note:
* Frequently people tear a jammed sheet when it comes out leaving pieces behind. BAD! When you get a torn sheet in your printer insure you retrieve all the pieces. Those left behind guarantee a jam on your next try.
* Paper jams not caused by debris in the path or worn pick-up roller(s) is beyond user maintenance.
Mar 03, 2015 | Lexmark X4550 Wireless All-in-One Photo...
Epson Stylus CX4800 prints blank pages
Alex_Garton:
I'm not familiar with the Epson Stylus printers, but I'm going to hazard a guess. If the paper does not move at all, the paper pickup feed mechanism is at fault. One of two methods is used to pick up the sheet. Either the front lower portion of the tray is lifted up to force the top sheet into the feed roller, or the feed roller is connected to a drop-swivel to drop the feed roller onto the top sheet of paper. You'll need to look carefully at the feed mechanism to determine if a gear or clutch is failing. If the paper moves into the machine about 1/2 inch and then stops, either the first paper feed roller past the pickup roller may be at fault. Also check to see if the paper sensor between the paper pickup roller and the first feed roller is working properly.
Sep 22, 2012 | Epson Stylus CX4800 All-In-One InkJet...
The printer thinks there is a paper jam-when we ask it to print it doesn't "grab" the next piece of paper-it clicks and then give a "paper jam" message please help
Typically these failure-to-feed problems are due to worn rollers - the feed roller is so worn
that it fails to feed the sheet of paper, which the printer misinterprets as a paper jam (because a
sensor tells the print processor that the sheet of paper is not present where is should be, and
therefore the printer microprocessor software issues a "PAPER JAM" error message).
The printer repair tech solution to this problem is to install a "roller kit," which entails the
replacement of every roller in the printer (since they all wear at about the same rate, replacing
just one is less effective than replacing them all).
Your quickie (temporary) solution - get the roller damp (this makes it grip a little better), then
load the paper tray to its maximum (pushing the paper into the paper pickup roller), then print a
couple precious pages while you order the roller kit online, and text your handy geek friend
who can change out all the rollers in your printer for a pizza.
Feb 18, 2011 | Canon PIXMA iP1600 Printer
My printer won't feed the paper through. the spindle rolls but won't grab the paper in the paper feeder
One common cause of paper feed issues is a build up of dust on the printer's rear paper feed roller. This roller consists of a plastic axle white roller. This is located in the automatic sheet feeder and is referred to as the "Pick Roller." As dust builds up on the rubber rollers, they become less tacky and therefore unable to grab a single sheet of paper.
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned.
Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
Next, try this printer self-test by following the steps given below:
1. Turn the printer ON.
2. Press the down arrow button till the screen displays “Maintenance". .
3. Press the "Check" button.
4. Press the "Down arrow" button till the screen displays “Print Test Page.”
5. Press the "Check" button.
The self-test should at least print out a set of either black or color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, try it again without cartridges installed.  If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with the color cartridge installed by itself. (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed.) If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, let us know. This includes any print quality issues, we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
If the self-test prints your test bar(s) clearly, the printer hardware is not at fault.
Oct 02, 2009 | Lexmark X7550 InkJet Printer
Paper not feeding through getting stuck halfway
To prevent and/or cure this type of paper feed problem, these rubber rollers should be cleaned. Unplug the printer's power cord and remove the paper from the automatic sheet feeder. Please remove the paper access door from back of the printer and clean the white rollers inside with a cloth dampened with warm water (be sure there is no excess water on the cloth as it may drip into the machine). After these are free of any dust, close the paper access door. Reload the paper and plug the power cord back in. The paper should then feed normally.
1. Power the printer off.
2. Press and hold the "Paper Feed" button.
3. While still holding the "Paper Feed" button, press and release the "Power" button. Continue holding the "Paper Feed" button.
4. When the printer starts pulling paper, release the "Paper Feed" button. It should print a test page at this point.
5. Power the printer off, as this test is continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridges installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without any cartridges installed, run the self-test again with only a color cartridge installed (If you have both black and color cartridges, after this test, run the test again with just the black cartridge installed). If you find that either cartridge causes the self-test to fail, please let us know.
If the self-test prints, but has lines or smudges or other print quality issues, please let us know. This includes any print quality issues - we need to know if the problems you have with your black or color are based in the printer, or communications with your computer, or the computer's software.
Apr 10, 2009 | Lexmark X1270 All-In-One InkJet Printer
I put paper in it and try to print and it pulls it kinda crooked
Next, try this printer self-test by following the steps given below: 1. Turn off the printer.
2. Press and hold the power button for at least 5 seconds, then release the power button.
3. The Self-Test will print. The test is not continuous.
The self-test should at least print out a set of either a solid black or solid color bars, if not both (if you have a printer with both color and black installed simultaneously). Should this test fail, please try it again without cartridge installed. If the self-test still fails to take paper in and make sounds like the carrier is moving across the paper, this is a hardware issue, and the printer will require service. If the self-test completes without the cartridge installed, run the self-test again with only a color cartridge installed. If you find that either cartridge causes the self-test to fail, please let us know.
Apr 09, 2009 | Lexmark Z2300 InkJet Printer
HP paper jam
That is usually caused by the paper feed rollers being cover with paper dust. Take a clean cotton pad and alcohol and clean the rollers :turninig each roller as you clean it. if it has a rear dor, open it to get better access to the rollers.
Please remember to rate all users who assist you for free :)
Sep 03, 2008 | HP PSC 1610 All-in-One Printer, Scanner,...
Lexmark X85 Printer
i tried cleaning the rollers off with lens-cloth & paint thinner & got TONS of ink off the rollers, still same problem thoough, but very slight improvement.
Jul 23, 2008 | Lexmark X85 All-In-One InkJet Printer
Automatic Paper feed
Check the feeder roller inside the printer for any foreign substance stuck to the roller, this may cause it not to grip properly. You can also try a few sheets at a time and make sure the paper tray is gripping the paper, but not too hard. If this fails, the roller may be out of place somewhat, try to reposition it. Let me know how you get on.
Sep 06, 2007 | Samsung ML 1210 Laser Printer
Printer will not feed paper
Mine did that too.
I found that propping the paper feed cassette up at the end away from the printer worked.
May 13, 2007 | Canon Selphy CP510 Thermal Photo Printer
55 people viewed this question
old marine
old marine
